Old 07-25-2021, 09:35 PM   #2276
Hotcorner
Hotcorner's Avatar
Re: What did you do to your truck today.The 3rd chapter
Originally Posted by Chevys4life View Post
Managed to get something done this weekend. Fixed rust places in the cab with patch panels. I put a little seam sealer in some areas of the floor. I had some Por-15 left over from something I did, so I just put it on the entire floor. Also, installed the factory sound deadening stuff and installed my rubber floor mat. It is nice to finally see some progress after putting in the hours. Thank God it is not a show truck and I have to do everything to factory specs!!!
Which floor mat is that? Did you have to trim it?
1969 GMC K25
2007 Chevy 2500HD Classic Duramax
1999 Tahoe 2DR 4WD Base Model 5.7l
Hotcorner is offline   Reply With Quote
Old 07-26-2021, 09:24 AM   #2277
maverickmk
maverickmk's Avatar
Pulled the motor, trans and almost have the crossmember out to replace the crossmember, add power steering & power brakes.
Also looks like I will need to replace the flywheel
Die with memories, not dreams.
Not to brag, but I don't need alcohol to make really bad decisions.
1969 GMC Short Step Side
maverickmk is offline   Reply With Quote
Old 07-26-2021, 09:30 AM   #2278
BigBird05
Hope the machine shop can save that fly wheel.
BigBird05 is offline   Reply With Quote
Old 07-26-2021, 09:32 AM   #2279
maverickmk
maverickmk's Avatar
There's no saving that, I'm going to replace it.
Old 07-26-2021, 01:10 PM   #2280
Chevys4life
That floor mat came from USA1 Industries down in North Carolina. You don't have to do anything to it at all except punch out the holes for where it fits in the cab.
Chevys4life is offline   Reply With Quote
Old 07-26-2021, 06:24 PM   #2281
lyrikz
PITbut
lyrikz's Avatar
Originally Posted by Liz View Post
Chapter 2 is now complete, bring on 3. What did you do to your truck today?
Not today, but recently.
I dont know how to post videos ON the forum. How do you direct link youtube vids so they play on the site?
https://www.youtube.com/watch?v=D46QO0mG-GM
https://www.youtube.com/watch?v=RkwIW-4djgs
https://youtu.be/Kt3vbcqMt-4
New project. 1971 Twin Turbo blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=676047
My new YOUTUBE channel.. Videos of my truck and a current walk around.
Lyrikz74 Youtube channel DONE! SOLD!
My 1971 stepside build thread
My Build Thread UPDATED 6/11. DONE
and sold.
lyrikz is offline   Reply With Quote
Old 07-27-2021, 05:04 PM   #2282
Sparky dave
O turned gen 6 valve covers from this to this. Impressed how good the stock ones can look
69 longbed 350 700r4 3.73 POSI cruiser
Sparky dave is offline   Reply With Quote
Old 07-27-2021, 09:31 PM   #2283
72c20customcamper
72c20customcamper's Avatar
Put the leafs and overload leaf back in the 72. Now she sits up in the rear and rides much harsher but I'm putting the hitch on tomorrow so it needed to be done
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 07-30-2021, 01:11 PM   #2284
72c20customcamper
Yesterday . Had the hitch fabricated all 1/4 inch square tube was able to tuck it in nice to the bumper. Just need to weld on the safety chain eyelets and wire it up
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 07-30-2021, 02:56 PM   #2285
SoCoC10
SoCoC10's Avatar
Last visit @ paint shop. Should be coming with me next time.
07' Extcab Silverado Z71 Silver Birch, 5.3L HO
71' Cheyenne C10 Hugger Orange on Saddle SWB
Besides these two, too Many to count
SoCoC10 is offline   Reply With Quote
Old 07-30-2021, 09:40 PM   #2286
72c20customcamper
Installed the 679 Hayden rapid cool trans cooler pretty easy on this didn’t need to take anything of other than loosen the shroud I may make a couple of brackets so it not in the rad so to speak. Also mocked up where I may put the gauges . They look good in the console but I loose the cubby hole . The oil pressure guage will be replaced with a trans fluid temp gauge
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 07-31-2021, 05:09 PM   #2287
pjmoreland
pjmoreland's Avatar
When I bought my truck a year ago, it came with a single newer key that fit the ignition but not the door locks. I have since replaced the door locks and ignition with a set from LockDoc. Today I was chasing down a rattle in my hood, and I found a Hide-A-Key magnetic box inside it, next to the striker plate. It had a key inside it, and it works with the original door locks! I don't think this is the original key based on it having a locksmith name stamped in it (WAGNER), but I still thought it was a cool find.
pjmoreland is offline   Reply With Quote
Old 08-01-2021, 12:44 PM   #2288
cab4word67
cab4word67's Avatar
I think that is cool. I always fear I will forget where I hide mine.
cab4word67 is offline   Reply With Quote
Old 08-01-2021, 01:50 PM   #2289
67C10Step
67C10Step's Avatar
Got a solid start on finishing my bed wood. These six pieces have the bottoms and edges done in black sealer and three coats of gunstock color stain. Will do the clear coat when I get the edge pieces ready.
1967 C10
1980 Jeep CJ5
2020 Toyota 4Runner
2024 Toyota Tundra
67C10Step is offline   Reply With Quote
Old 08-01-2021, 03:45 PM   #2290
72c20customcamper
^^ looks great
I finished up the tow package on the 72 only thing I have to do is the gauges . Tows really well the factory temp gauge is a tad higher under power than without the trailer
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 08-01-2021, 11:21 PM   #2291
55Nomad
...today I caught mine on fire... a bit of a belch from the carb..... it's ok.... I put it out quick, just a burned up air filter and a crunchy hose.... already replaced and running in less than 30 minutes
55Nomad is offline   Reply With Quote
Old 08-02-2021, 06:27 PM   #2292
CS1972
CS1972's Avatar
Radiator overflow bottle/bracket/hoses installed!
I used an old windshield washer bottle so it would look like it belonged there (the yellowing old look) instead of having a brand new white bottle. I also found a black "Engine coolant only" cap to match the windshield washer bottle cap.
Ron
1972 Cheyenne Super 1/2 ton LWB 4x4 - Grapefruit Yellow / White
CS1972 is offline   Reply With Quote
Old 08-02-2021, 07:05 PM   #2293
72c20customcamper
Plumbed in the manifold for the transmission temp sender no leaks just need to drill some holes for the mounting screws I have good continuity checked it because I had to use a little Teflon tape . Left half the fitting bare to help make a good contact . Tomorrow I’ll mount the gauges and wire it up .
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 08-02-2021, 07:12 PM   #2294
OregonNed
OregonNed's Avatar
Finally, after waiting several weeks for parts, I was able to finish rebuilding my doors. All new internals, plus new vent windows and door glass. Last hurdle was the setting tape, that was way too thin. I ended up putting that tape against the glass, and backed it with tool box liner - worked like a champ. Under the door panels I added sections of Fat Mat to reduce vibrations. What a difference! Much quieter, and no more rattle. Nice, clear glass is also a welcome upgrade.
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop
OregonNed is offline   Reply With Quote
Old 08-02-2021, 07:13 PM   #2295
OregonNed
OregonNed's Avatar
One window set -
Old 08-02-2021, 07:14 PM   #2296
OregonNed
OregonNed's Avatar
Finished doors
Old 08-02-2021, 10:51 PM   #2297
Peanut74
Well I put in the automatic transmission linkage. Twice got it working smooth then had to take it apart a third time. The hole for the linkage bushing was to small and I had to drill it out. Hope the third time is the charm
1967 C10 "Snowball" (Currently in a million pieces down from a bazillion)
1989 Toyota DLX pickup "The Hulk"
2012 Jeep JKU "Crush"
1976 Chevy short bed with a 327 and 3 on the tree (Sold it to buy the Blazer)
1971 Chevy Blazer (Sold it)
Peanut74 is offline   Reply With Quote
Old 08-06-2021, 07:05 PM   #2298
Peanut74
Well today I worked on getting brake fluid in the lines and find a fitting for the brake booster vacuum hose. found the fitting and got it installed and got three of the calipers bled. Broke the bleeder valve, on the last one, so now I have to order a new one. This truck is going to drive me over the edge at this rate.
Old 08-06-2021, 08:09 PM   #2299
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Originally Posted by OregonNed View Post
Finished doors
Doors look great!
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
Old 08-06-2021, 08:53 PM   #2300
OregonNed
OregonNed's Avatar
Originally Posted by Ol Blue K20 View Post
Doors look great!
Thank you! I ordered rear glass today to complete the project
