Old 08-15-2021, 11:06 PM   #1
Montierth
Montierth's Avatar
Diy kick panel speaker
Was at home depot in roofing and found these. Decided to give them a try. Think it cost about $12 for both sides. There is writing at the bottom but figuring I may wrap them.
1970 GMC C1500 short fleet
Sellers Regret
- 1950 GMC
- 1967 Chevy C10
- 1970 GMC C2500 Dually Flat Bed
- 2003 Silverado
Montierth is offline   Reply With Quote
Old 08-15-2021, 11:08 PM   #2
Montierth
Montierth's Avatar
Re: Diy kick panel speaker
They also have metal one but probably not deep enough for a speaker and would need to add a spacer ring.
Sellers Regret
- 1950 GMC
- 1967 Chevy C10
- 2003 Silverado
Old 08-15-2021, 11:45 PM   #3
CWW
CWW's Avatar
I would never have thought of using sewer vent flashing for speakers
CWW is offline   Reply With Quote
Old 08-15-2021, 11:51 PM   #4
53burb
53burb's Avatar
awesome idea!!
Are you still able to use the emergency/parking brake??
53burb is offline   Reply With Quote
Old 08-16-2021, 12:08 AM   #5
Montierth
Montierth's Avatar
I think I saw someone on here with same idea but 6 inch speakers fit perfect. I'll post pics once I get them finished and installed
Sellers Regret
- 1950 GMC
- 1967 Chevy C10
- 2003 Silverado
Old 08-16-2021, 12:11 AM   #6
Montierth
Montierth's Avatar
Originally Posted by 53burb View Post
awesome idea!!
I will check this week but I don't use the ebrake and it isn't hooked up.
Sellers Regret
- 1950 GMC
- 1967 Chevy C10
- 2003 Silverado
Old 08-16-2021, 05:06 PM   #7
Caddylackn
Caddylackn's Avatar
That is a good idea, I hope it will clear the e-brake handle.
You may be able to move the e-brake handle over a few inches by relocating the mounting hardware.
1969 Custom Camper C20; Factree Air, 350/TH400/Dana 70U with C30 wheel cylinders, Disk brakes, H4 conversion, headlight relay mod, 3G 135 amp alternator. 7500 GVW
Caddylackn is offline   Reply With Quote
Old 08-16-2021, 06:03 PM   #8
slikside
slikside's Avatar
Me either…just make sure it hasn’t been “used” already!
1972 Chevy C-10, SWB, Fleet, 350/350, PS, PB, HEI, mostly stock, Survivor.
slikside is offline   Reply With Quote
Old 08-16-2021, 10:19 PM   #9
Peanut74
Interesting idea. Keep us posted on your progress. I will be interested to see if you go with the rubber one or the metal.
1967 C10 "Snowball" (Currently in a thousand pieces down from a bazillion)
1989 Toyota DLX pickup "The Hulk"
Peanut74 is offline   Reply With Quote
Old 08-16-2021, 10:44 PM   #10
Blue GMC
Blue GMC's Avatar
I would think the metal one would rate like a sob with any type of volume
Blue GMC is offline   Reply With Quote
Old 08-17-2021, 01:22 AM   #11
Montierth
Montierth's Avatar
If I used the metal one then I would line it with kill mat. Right now I'm In the middle of prepping truck for rewire, new fuel pump and vintage air. Here is a pic with e brake pushed. Would probably clear with no or low profile speaker grill.
Sellers Regret
- 1950 GMC
- 1967 Chevy C10
- 2003 Silverado
Old 08-17-2021, 04:03 PM   #12
Good idea. The thing looks great!
Old 08-17-2021, 09:16 PM   #13
Husker
Husker's Avatar
Great idea.
Ron
Member #111
68 C-10 Daily Driver
70 4x4 Project
76 Jeep CJ-5
Help Support the Board:
http://67-72chevytrucks.com/vboard/payments.php
He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors.
Thomas Jefferson
Husker is offline   Reply With Quote
Old 08-18-2021, 12:34 PM   #14
Caddylackn
Caddylackn's Avatar
I have one of those speaker kick panels you buy for way too much money. It only works with a shallow 6.5" speaker without the grill
Looks like you win the inventive genius award for the month.
Old 08-18-2021, 01:08 PM   #15
Lethal Tendencies
Lethal Tendencies's Avatar
Very Cool
Lethal Tendencies is offline   Reply With Quote
Old 08-18-2021, 01:48 PM   #16
spmtamu11
Awesome... Going to go buy a set tonight.
spmtamu11 is offline   Reply With Quote
Old 08-18-2021, 01:59 PM   #17
CWW
CWW's Avatar
What size speaker are you using and what size pipe flashing are you using?
Old 08-18-2021, 02:14 PM   #18
Montierth
Montierth's Avatar
Using this one: Kicker DSC650 DS Series 6.5" 4-Ohm Coaxial Speakers - Pair
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Fits like it was made for it. After looking at it and thinking about it, it would be easy to cut the bottom off where the lettering is and lower the speaker to the floor which may give even more clearance for a speaker.
The plastic one number is CMIHB34 for a 4 inch. I cut out most of the rubber. It works really nice and gives a cushion to the speaker. Online shows $6.98
https://www.homedepot.com/p/Gibralta...HB34/100319899
Would like to see what others try with this. I can think of a couple other ways to cut these to clear the brake.
Sellers Regret
- 1950 GMC
- 1967 Chevy C10
- 2003 Silverado
Old 08-18-2021, 02:32 PM   #19
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
Very Flashy! Nice job!
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 08-18-2021, 09:26 PM   #20
spmtamu11
I see what you did there. Very punny...
Old 08-19-2021, 01:26 PM   #21
spmartin11
By no means perfect. But just bust out your orbital sander to get rid of the writing. Sanded the whole thing with an 80 grit disc. Will probably go back over with a 100 grit to clean it up.
Also, confirmed the parking brake will clear as well with a low profile screen. Will definitely have to move the brights though.
spmartin11 is offline   Reply With Quote
Old 08-19-2021, 01:43 PM   #22
Montierth
Montierth's Avatar
Looks clean. Are you going to wrap it? I like how you cut the top. I had already moved my brights. I actually can't remember the last time I used bright in any vehicles so not a big deal to me.
Sellers Regret
- 1950 GMC
- 1967 Chevy C10
- 2003 Silverado
Old 08-19-2021, 01:55 PM   #23
spmtamu11
I'm going to see how I like it first and then will probably order some extra carpet when I replace mine in the next few months and then wrap it.
Ordered a set of these as well. Going to put down sound deadener/heat barrier with the carpet, but figured this would work in the meantime...
Old 08-19-2021, 03:16 PM   #24
68 C10 Driver
Very ingenious idea.
Being sewer pipe flashing, does it make you radio sound like crap?
68 C10 Driver is offline   Reply With Quote
Old 08-20-2021, 07:17 AM   #25
Lethal Tendencies
