#1 | ||
![]() Join Date: Aug 2017
Another Vin Tag question
Deleted VIN tag swapping question. Not allowed per the Administrators of this web site. Quotes from Administration: Quote:
Re: Another Vin Tag question
The second you removed tags means you need to call your state inspector and find out how to have a new vin for your vehicle as those are not to ever be removed. They will retitle it as an 2021
I have contacted them. They said since this is a "hobbyist" vehicle I can do whatever I want. All the vins are matching and there are no issues....first thing I found out. It is titled and plated as a highly modified hobbyist truck. Interestingly enough, hobbyist plates can even be applied to "homemade vehicles". Anyhow, does anyone have an answer to my original question?
![]() Join Date: Oct 2009
Hmm. I’d say you’re pretty lucky. However, unless similarly registered, the guy that bought your original cab with no VIN tag (hopefully not with a swapped tag from your good donor) is probably screwed.
Generally speaking, a rule of thumb is that humans outside the GM plant that built it should never touch a rosette rivet. |
#5 | |
There are ways to legally remove and reinstall vin plates . Did it numerous times when I worked at my uncle's body shop in the late 70 early 80s . Replaced many drivers side door pillars due to damage. State police get involved check all paperwork and inspect vehicle before and after repairs. You would get a certified letter of repair from them in a few weeks. There has to intent to defraud to make it a crime even the federal regs have work arounds.
Not sure how it would be for somebody doing it at home . I would weld the holes and repaint the area . Shouldn't be that hard for a good bodyman
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. |
The Older Generation
Swapping VIN tag questions are not allowed on this forum... PERIOD. Watch the video in this thread posted yesterday. http://67-72chevytrucks.com/vboard/s...d.php?t=827513 LockDoc, Moderator
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 11-05-2021 at 10:20 AM. |
