11-06-2021, 09:50 PM | #1 |
GEARHEAD
Cab Roof Replacement
I'm helping a friend out with rust repair on his cab. Started out with the usual problem areas. Rockers, lower kick panels, bottom of the kick panel vents from leaves and rodent nests, small floor patches, etc. The cab had a spot light through the middle of the roof. The cab had been sitting outside for several years and it leaked. So the middle of the inner roof panel was rusted. Then we found pinholes above both doors. There was also damage to the drip rails and outer edge of the roof where the cab was lifted using a strap that rolled up the drip rail and dented the outer roof.
Neither of us have attempted a roof replacement before but he decided to spend another $500 on new roof panels and we gave it a shot. Removing the old panels wasn't that hard, just a lot of spot weld drilling. When we got the outer skin removed, mouse nests fell out of both sides above the doors. Most of the damage to this cab was caused by sitting outside. Nice and moisture. This was a nice rust free cab before that.
If no one knows what you're doing, they can't tell you you're doing it wrong HG's Dream Car Build - Shelby Cobra Kit Build your own adjustable track bar 71 Long Fleet C/10 72 Jimmy 4x4 (Junkyard Jimmy) HG's Plow Truck '78 K35 Dually Bigass Farm Truck HG's thread of miscellaneous stuff Last edited by hgs_notes; 11-06-2021 at 10:53 PM. |
11-06-2021, 10:23 PM | #2 |
GEARHEAD
Re: Cab Roof Replacement
I'm using 3M panel adhesive to secure the new parts. The cab is mounted on a dolly. The frame around the doors and windshield are pretty stout so we didn't feel the need to add more support. We ground down all of the spot weld areas and cleaned up the surface rust, especially on the areas where the adhesive will go. We pre-fit the inner roof panel first and it looked like a really good fit.
This is where we made a mistake but didn't realize it until later. Having no experience doing this and finding nothing online or on the forum we figured that the inner panel had to go in first because it's the only way to get it in over the top of the A pillars and the rear inner cab panel. Then put the outer skin on. Attaching the inner roof panel was easy enough. We used a few self tapping screws in the rear pinch weld area and clamped the front and sides to the inner structure. Everything looked great. But then getting the rear pinch weld together for the outer skin is difficult. I managed to get it together pretty well but it could have been better if we changed up our plan. What we should have done is also remove the rear inner panel around the rear window. I believe that's how it was done at the factory. If you take that out, then you can put the outer roof skin on first and be able to clamp or weld that rear seam. Then you weld or glue the inner roof panel to the inner rear window panel together. Get that done then install those into the cab as a single piece. But we didn't do that so getting the rear seam aligned and tight was a little more difficult. Learn from our mistake!
If no one knows what you're doing, they can't tell you you're doing it wrong HG's Dream Car Build - Shelby Cobra Kit Build your own adjustable track bar 71 Long Fleet C/10 72 Jimmy 4x4 (Junkyard Jimmy) HG's Plow Truck '78 K35 Dually Bigass Farm Truck HG's thread of miscellaneous stuff |
11-06-2021, 10:30 PM | #3 |
Thanks for sharing
I really like your signature
11-06-2021, 10:39 PM | #4 |
GEARHEAD
Once the inner roof panel was set up we put the sound deadener in. We used fatmat. Then the outer skin could go on. The fit wasn't bad but needed a little more tweaking. This would have been easier if we had done it in the order described in the previous post. Oh well, live and learn, make the best of it.
I had to do it in 2 steps. First glued the rear seam. Then after that set up I glued and clamped the front and sides.
11-06-2021, 10:50 PM | #5 |
GEARHEAD
Last step was doing the drip rails. Probably the easiest part of the job. BTW, removing the old drip rails was probably the worst part of the job. They had spot welds about every inch! Lots of drilling.
The new ones fit up nice. Clean everything up, mix up the adhesive and clamp in place! Using adhesive has a lot of benefits. It completely seals the joints and keeps moisture out so it won't rust after. It's very strong and if you use the right one you have plenty of time to move and adjust the pieces. It's how the manufacturers are building them now and how most body shops do things. If a seam splits you can still drill a small hole and plug weld. And in some areas I use adhesive and plug welds together.
If no one knows what you're doing, they can't tell you you're doing it wrong HG's Dream Car Build - Shelby Cobra Kit Build your own adjustable track bar 71 Long Fleet C/10 72 Jimmy 4x4 (Junkyard Jimmy) HG's Plow Truck '78 K35 Dually Bigass Farm Truck HG's thread of miscellaneous stuff Last edited by hgs_notes; 11-06-2021 at 11:09 PM. |
11-06-2021, 11:07 PM | #6 |
GEARHEAD
This thread was just to share our experience doing an uncommon job that really wasn't that difficult to do. The new panels weren't cheap, I think $500 for the roof skins and another $50 or so for the drip rails. The adhesive is about $45-50 a pack and I used more than one pack for the roof replacement. You need a special tool to use the adhesive that cost about another $50-60. I bought mine several years ago when I did the restoration on my 71. Mine is for the SEM version of adhesive but also works with the 3M stuff. But the 3M tool won't work on the SEM adhesive. They have different diameter tubes.
As I said, we didn't have prior experience doing this and maybe we made mistakes. If any pros want to comment, criticize or just share pro tips that would help everyone. If you need to do this and you have any experience with rust repair, you can handle it. Oh, you will need a TON of vise grips. The kind for this type of work. You can see what I used in the pics. And we used every single one we could get our hands on. I filled a 5 gallon pail with vise grips.
11-06-2021, 11:33 PM | #7 |
All about them K’s
Very nice work!
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne: 5” lift, 35’s, front dana 60 blah blah blah… http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB: 4” lift 33”s… in a million pieces http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 35x12.5x20’s |
11-07-2021, 05:14 AM | #8 |
Good tips- thanks for sharing! Looks really good
71 C10 72 K20 72 K10 Super Kirk |
11-07-2021, 09:11 AM | #9 |
Where did you find good drip rails? All of the comments say they such and most venders don't carry them.
11-07-2021, 09:41 AM | #10 |
Proprietor of Dale's Corner
Thanks for sharing the info HG.
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man R.I.P. FleetsidePaul |
11-07-2021, 09:54 AM | #11 |
GEARHEAD
Bowtie truck stop is local to me. Call Kevin gramentz at 507-723-2843. His prices are comparable to anyone's and he always tries to get the best version of the parts. Doesn't want to sell light weight, low quality, poor fitting parts. And he is pretty well stocked.
11-07-2021, 10:52 AM | #12 | |
GEARHEAD
11-07-2021, 10:53 AM | #13 |
Roadtrip!
Nice work.
I have a roof already cut off and ready to go if you need to do another one...
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
11-07-2021, 11:03 AM | #14 |
Outstanding work! And I thought I had a rusty cab...
You are indeed a gifted craftsman. I'll certainly be following this build. Thanks for sharing! |
11-07-2021, 12:16 PM | #15 |
INCREDIBLE.
Subscribed and bookmarked if I ever get the courage to take this on for my GMC. Thank you!
1971 GMC C15 Sierra Grande SWB 1972 Chevy C10 Custom Deluxe LWB 2018 GMC Yukon Denali |
11-08-2021, 10:17 AM | #16 |
landarts
Nice work on the roof. Been there and done that it is a boat load of work and takes some time and patience to do it right.
Really like the approach and craftsmanship. Again nice work!
Super Cheyenne aka the "Devil Cowboy" 71 K20 Idaho Edition 69 K10 from the Field 68 Second Chance Fix and Sale 72 GMC 3/4 ton 4x4 K2500 The "Fixrupr" build thread 72 Cheyenne 1/2 ton " FIXRUPR " - daily driver 67 C20 all original paint 71 K20 Custom 4x4 (Idaho Edition) 72 K20 GMC Super Custom 4x4 72 K20 Custom Deluxe 4x4 69 K10 Custom package 4x4 (69 K10 from the field) 72 K10 Custom 71 K10 Custom 72 K20 Custom Deluxe 4x4 72 K20 Crew Cab Project 71 GMC Jimmy CST 72 Blazer 70 Blazer |
11-08-2021, 07:05 PM | #17 |
Thanks for the drip rail info.
11-10-2021, 10:44 AM | #18 |
GEARHEAD
Sure, NOW brothers puts out a video on doing a roof. Oh well, their tutorial isn't quite the same situation we had and they welded rather than using adhesive. I think they HAD to weld the rear seam because they didn't do the full inner roof panel so there isn't access to the inside with that in place, so the rear cab seam gets welded closed. We discussed it and decided to stick with the original look rather than weld it and smooth it out.
There was also a patch panel someone made a while back, not sure if it's still available, but it basically removed the rear seam and replaced it with a radiused piece for a smoother look. https://www.youtube.com/watch?v=S_0ImjRL6jI
11-10-2021, 12:27 PM | #19 |
6>8 Plugless........
Very nice work! I have a cab I have to do a complete roof on as well. The inners down the b pillar are rotted too unfortunately so I will be cutting the pillars and doing it that way.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
11-10-2021, 08:47 PM | #20 |
Dang. I wish I had friends like you!! Well done
Insert clever text here: |
11-10-2021, 11:16 PM | #21 |
I get most of my parts from bowtie truck stop. Kevin and Lisa are great people and have always done right by me. Whenever I go up there on a parts run, I plan on an extra 45 minutes of talking to them.
What are you planning on using for drip rail sealer? I used some stuff from 3M and have found it peeling out. I think it's because I was lazy and didn't remove the factory ecoat from the new roof panel and the sealer didn't stick to it. I need to clean out all of the sealer and grind away the ecoat.
My 67: http://67-72chevytrucks.com/vboard/s...d.php?t=784468 |
11-11-2021, 04:39 AM | #22 |
I,d just have looked for a nicer cab personally
I BELIEVE IN JOHN 3:16 |
11-11-2021, 01:23 PM | #23 |
That's easier said than done in our area. Usually the entire floor is roached or the roof and floor are roached. When you do find a good usable cab, you'll be spending $500 for a bare rusty cab. It's nuts.
11-11-2021, 01:28 PM | #24 |
Mine is a 67 small window...even harder to find in good condition...
1967 C10 Step side 1968 C10 Step side 1970 Chevrolet K/5 Blazer 1972 Chevrolet K/5 Blazer ............. |
11-11-2021, 02:33 PM | #25 |
A member here in southern Iowa had one at a reasonable price. Needed rockers/inner rockers, light floor repairs and cab corners. Russ/counter had it.
