Stock overload spring bump stop
These are on my 57. Would these be original? Attachment 2153507
Re: Stock overload spring bump stop
I'd say not original. Probably something that was sold by parts houses or Western Auto back in the day.
definitely not original. mine were riveted to the bottom of the frame like this
cool, an ogre smiley ![]() how to put your truck year and build thread into your signature shop air compressor timer |
Ok, Thanks. I thought it looked too hokie to be factory. No doubt it was done in the distant past, probably when the 10 bolt rear and 54 chevy car hubs were added to get the 5 lug bolt pattern.
you may also find something usable in here if you have time.
https://www.trifive.com/d1/55-59Assy.pdf my 3/4 ton came with overloads but the springs were another set of shorter leaf springs above the original springs with a spacer block between them and some contact slipper brackets riveted onto the frame above that. similar to what you would find on a newer truck but minus the teflon contact slippers. |
![]() Join Date: Feb 2004
I kinda like the engineering of that overload.
1942 Chevy 1/2 ton Rod, 1959 GMC 1/2 ton Fleet Stepside, 1967 Chevy SWB K10, 1985 Corvette Coupe 4+3, 2015 Chevy Duramax reg cab 4WD W/T |
