#26 |
Carpe manana
![]() ![]() Join Date: Dec 2010
Re: Blazer courtesy lights
I'd like to find repro rubber grommets for where the harness exists the kickpanel.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() |
#27 |
![]() Join Date: Mar 2015
Looks like the color of the reflectors, you purchased, is closer to the factory tint than the ones from American Auto Wire.
You will really like the extra light these provide. Gives the inside a nice look at night. I just used Grommets I purchased in a bulk pack. Look factory and no one will ever know. |
#28 | |
Mr. Cheyenne
![]() Join Date: Jun 2020
seeing you guys are talking about firewall grommets (responding DeadheadNM?) - where did you buy your bulk pack? This has kind of been on my to do list to fine a pack that would be useful, as I have at least one I need to replace (for where the washer hoses came through the firewall).
Richard '72 Chevy C10 Cheyenne *Super WHT/MED BRONZE/WHT SBC 350 | TH350 | LWB | AC | Buddy Seats Upgrades: Tilt | Front Sway Bar | Radio | Sliding Window | Bed Spare w/Lock Bed Rails | Full LEDs | Courtesy Lights | Tachometer | Glovebox Lock & Light | Head Light Relays | *Upgraded Fully Super Trim Last edited by Rich72C10; 01-03-2022 at 04:04 PM. |
#29 |
You will really like the extra light these provide. Gives the inside a nice look at night. Grommets https://www.amazon.com/200PCS-Gromme...l%2C240&sr=1-3 $10. I'm guessing that Harbor Freight may also have something close. |
#30 |
![]() Join Date: Feb 2002
MY '71 GMC JIMMY came with the under dash courtesy lights. I repaired the passenger side lamp holder, but the drivers side got torn or twisted off by a PO [or his dog].
Is it possible to buy just one of the lamp holders, [Lamp-to-Harness connection] or do I have to get the whole kit?
#31 |
Mr. Cheyenne
Thanks @ Accelo!
@'68OrangeSunshine - all the looking around for them I only have seen them as a full set.
Richard '72 Chevy C10 Cheyenne *Super WHT/MED BRONZE/WHT SBC 350 | TH350 | LWB | AC | Buddy Seats Upgrades: Tilt | Front Sway Bar | Radio | Sliding Window | Bed Spare w/Lock Bed Rails | Full LEDs | Courtesy Lights | Tachometer | Glovebox Lock & Light | Head Light Relays | *Upgraded Fully Super Trim |
#32 | |
I may have to rig a bigger light under the drivers dash, so I can fill out my logbook at night. [I keep a log so I know how many miles I've run, and when I last filled up. Gas tank is inaccessable behind an armored 1/4'' steel plate.] I have an old military cockpit light -- focusable, Red/White lensed, and self-dimmable -- changed out the 24 volt bulb for a 12 volt, and soldered a cigar plug on the Mic-type coil cord... But I'd rather that operated out of the opened center console, and independent of the Dome Light/ Courtesy Light circuit. Unless some one has an incomplete harness they'd part out?
#33 | |
Mr. Cheyenne
These were the only holes I had on my 72 C10 on both sides - which are a bit big. Assuming these are the correct holes, I wonder if some kind of a grommet is suppose to go in the hole. Or perhaps the dome mount is suppose to have a collar to fill the hole? I had to double up washers and my hardware is all silver. Perhaps I can find something at Lowe's / Home Depot, otherwise I'll need to paint what I have black.
#34 |
Mr. Cheyenne
Walmart actually had a (ton) of 1003 bulbs and nicely packaged in pairs!
Let there be light!
#35 |
Interesting how much the pricing of what appears to be the same part varies;
Courtesy Light Harness 67-72 from classicparts.com (part number 52-753 / $35.95) |
#36 |
Mr. Cheyenne
I am happy with the classicparts.com one, the wire coloring matches what is in my truck. Though looking at their site, it is shown out of stock now.
I also ended up going with Sylvania 89's which are 13v 7.5 watts (replaced the 1003's). The bulb glass is a bit smaller too.
#37 |
I talked to a guy at Ron Francis yesterday about just buying the last 5 or 6 inches from the connector to the bulb holder. But they would only sell the harness as a whole.
#38 |
![]() Join Date: Jan 2008
I just need a few things, 1 x globe holder, 1 x door jamb switch, but looks like can't get globe holder by it's self
I like that Classic Parts looks original, but is showing out of stock There is one at Lectriclimited that looks to be a good replica https://www.lectriclimited.com/court...harness-115396 https://www.lectriclimited.com/court...switch-harness https://www.lectriclimited.com/court...-switch-103933 Anyone used their stuff? Last edited by 68ls1; 01-18-2022 at 10:45 PM. |
#39 |
I have an extra (new) door jam switch. $12 including the ride. PM if interested.
#40 |
#41 |
Too funny. Guess I will pass.
However, this switch is used on almost every chevy from the 60's. Identical to one's on my Chevelle. Should not be too difficult to find. |
#42 |
#43 |
![]() Join Date: Aug 2019
I aways check several sources before I buy any auto part. A small amount of time on the computer can save a lot of money. I also look at shipping when buying.
