Old 01-17-2022, 03:27 PM   #1
Blazer690
Blazer690's Avatar
Frame numbers?
I found these numbers in the middle of my frame on my 2 wd 1972 blazer. Any one know anything about them?
Blazer690 is offline   Reply With Quote
Old 01-17-2022, 07:14 PM   #2
Rickysnickers
Re: Frame numbers?
I know they were upside down, so I fixed it for you. Other than that, no I do not know
Old 01-17-2022, 10:24 PM   #3
Blazer690
Blazer690's Avatar
Re: Frame numbers?
They were upside down on the frame, but thanks
Old 01-20-2022, 04:31 PM   #4
Harold Holbrook
Re: Frame numbers?
May be Part Numbers .
Harold Holbrook is offline   Reply With Quote
Old 01-20-2022, 08:37 PM   #5
Keith Seymore
Keith Seymore's Avatar
Re: Frame numbers?
Part numbers, date codes and other manufacturers info.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 01-25-2022, 10:20 AM   #6
Blazer690
Blazer690's Avatar
Re: Frame numbers?
ttt
Old 01-25-2022, 10:37 AM   #7
Keith Seymore
Re: Frame numbers?
I have answered your question.
At this point in time it would be difficult to ascribe more detail than that. Typically it would be obscure lot numbers, component or uplevel part numbers, manufacturers trademarks or other arcane information that was used for problem diagnosis or quality metrics and is not, nor intended to be, useful beyond the time of manufacture.
Much of the manufacturing process occurs with the frame upside down. This carries over into the vehicle assembly plant as well, where the frame starts off upside down in order to allow gravity to help hold the front and rear suspension in place until they can be attached and torqued. As a result, most wax crayon markings (like build sequence numbers, or option content, or inspection marks) are written early in the process and appear upside down once the vehicle is completed.
You could make up some kind of meaning, if you like; no one would be able to prove you wrong.
Unless you run across some old guy with a stellar memory who worked at AO Smith back in the 1960's/1970's. Which would be my luck.
K
1979-1986
1986 - 2019
Old 01-28-2022, 12:09 PM   #8
BigBird05
Re: Frame numbers?
Way to go Keith. You said it perfectly. Spoken like someone has been there. I only hope that they are listening and understand. Most if not all factory numbers are only meaningful to the assembly line personnel. They were never meant to have any other meaning.
BigBird05 is offline   Reply With Quote
Old 01-28-2022, 02:02 PM   #9
hemi43
hemi43's Avatar
Re: Frame numbers?
I worked in automotive manufacturing for 30 years, and what Keith said is correct. Those numbers represent the "options" on that given frame. Those numbers may specify if it's a 2WD vs 4WD, or if it's got certain holes or brackets for other things. Unlike the early 70's where there might have been a handful of frame variants, today there could be 50 different things that make the frames unique even though they look identical. On the newer truck frames they use a decal with both an internal numbering system and bar code that the line worker can see to determine which component goes to that particular frame. It still amazes me how such a complex assembly plant can spit out a vehicle every 50-60 seconds.
hemi43 is offline   Reply With Quote
Old 01-28-2022, 03:36 PM   #10
Blazer690
Blazer690's Avatar
Re: Frame numbers?
Thanks everyone
Old 01-28-2022, 04:43 PM   #11
BigBird05
Re: Frame numbers?
Those #'s may not mean anything, but I still documented them and wrote them down in my trucks history book.
