![]() Join Date: Aug 2014
How do I flatten the top of the frame rail?
I am looking for advice on how to flatten that raised section of the top of the front passenger side frame rail. Correct me if I'm wrong, but I believe it is there to accommodate the lower radiator hose. Regardless I am converting my '69 to an electric and have plans to set a battery pack atop the frame in that section so I would like to make it flat like the other side.
I hope these picture convey what I am trying to accomplish. Thank you in advance, g |
#2 | |
Re: How do I flatten the top of the frame rail?
I'm thinking that this is a "take your pick" kind of thing.
A little heat and a hammer/dolly Trim most or all of it away. Saw, whizz wheel, torch, plasma cutter, etc No heat and more hammer. To get it truly flat, you might need to cut a slit or two into it, to give the metal somewhere to go, then weld them back closed. Grinder
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. ![]() |
#3 | ||
Do you think using heat and large C Clamps of sorts would pull it down into submission, and not pull the bottom (non heated) part of the C channel up? Along those lines I thought of putting some sort of metal bar on top of it then clamping that down, but then I wonder how I would heat up the frame (maybe upside down with the torch) but then the metal bar would act as a heat sink? here I go again over thinking stuff, ha ha also considering picking up this 48" pipe wrench off of Craigslist to use as leverage thanks again Last edited by Gregski; 03-13-2022 at 09:53 AM. |
That relief there was for the fuel pump on V8 engines ,
The Older Generation
Start at one end, make a relief cut about 1" in, angled toward the center of the radius, heat & hammer down first piece, another relief cut, heat & hammer down second section (trim sides as necessary), and continue down the line. After you are happy with the outcome weld up & grind down. LockDoc
I'd just heat the whole area red with a torch and hammer and dolley it flat. It won't really take that long to do.
#8 | |
I tried that. You end up with wrinkles in it that you have to grind off and weld up anyway so it's just as easy to make the cuts and do it a section at a time, and it looks better overall when you are finished. LockDoc
You could also cut that top section out, then weld in a new piece. Just be sure to get thick enough donor material. You could even cut that section out, flatten it, then cut off excess and weld it back in.
Posted via Mobile Device |
I've used a big crescent/pipe wrench to get it done. Start @ one end moving the lip down a little. Move over about the width of the tool jaws & repeat. Continue following the raised area. Repeat until it's flat & use a 60grit flap disc to true the edges w/the surrounding rail sections. A little hammer/dolley work helps as well.
At the body shop.
Gregski did the square body find a new home.
Reading your thread was a good read.
" That didnt make it any newer " " Dont antique the equipment " |
#12 | |
#13 | |
[shameless self promotion] please check out my current build, the truck is called Dusty and I'm making it electric, I have some YouTube videos to go with it on my Good Enuff Garage channel My Dusty 71 GMCe Electruck [/promotion] Last edited by Gregski; 03-13-2022 at 01:50 PM. |
#14 | ||
"I ain't nobody, dork."
Yup... will need to reroute fuel line to get past it if mashed flat.
Gary
#15 |
It appears he's building an electric truck.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
#16 |
BlahBlahBlah
#17 | ||
Nevermind then...
![]() Gary
#18 |
I love this forum, armed with your advice I put on my Big Boy Pants and made sum noise
#19 |
first up, Big Bertha and sum brut force
#20 |
then the mini death wheel
#21 |
please don't knock these little Home Depot torches until you've tried a proper torch like this Benzomatic TS8000, cause it doesn't matter if its the blue bottle or the yellow one, it has nothing to do with the type of gas or fuel but everything to do with the proper mixture
#22 |
she's gettin' there
#23 |
not bad for an email administrator
#24 |
Senior Moment
![]() Join Date: Mar 2002
Very interested in following your conversion to electric. Hope you post more
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN 2013 GMC PU, Oldest Son 71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son 2017 Toyota SUV Daughters car 2018 Traverse , Wife’s Ride Pittsburg Ca 94565 |
#25 | |
um... My Dusty 71 GMCe Electruck |
