Old 05-20-2022, 01:42 PM   #151
Braunschweiger
Re: A '62 has to get back on the road
I agree, I'm really happy that the windshield is back in place, the wiring is progressing well.
Greetings Harald
My 62 build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=829782
Braunschweiger is offline   Reply With Quote
Old 05-20-2022, 04:10 PM   #152
SCOTI
SCOTI's Avatar
New glass & fresh wiring definitely stoke the passion.
Glad the glass cooperated w/you this round!
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 05-22-2022, 11:31 AM   #153
Braunschweiger
Today I have been looking after the Mustang, With new oil and filter and the valves adjusted, 1x in the year is Service, that is done, I had a bit correct only two cylinders, job done and nice test drive made
Greetings Harald
My 62 build thread
Old 05-23-2022, 09:08 AM   #154
Braunschweiger
Wiring under the Dash is finished, I have to come up with something for the safety switch, it was almost in the Firewall and I had to remove it so that the steering column would fit, so there was no one on it. Still made holders for the flasher relay and the wiring harness, looks good. The rear window is back in place too.
Greetings Harald
My 62 build thread
Old 05-23-2022, 11:27 AM   #155
realvc
realvc's Avatar
Everything on your truck is so very neat and tidy.
Looking better than new.
Vince
Galatians 6:14
62 SWB stepside, 94 Wrangler, 99 Z71, 99 vette
My Project http://67-72chevytrucks.com/vboard/s...d.php?t=719086
"If it's too loud, you're too old"
realvc is offline   Reply With Quote
Old 05-23-2022, 12:06 PM   #156
bigmoe
bigmoe's Avatar
Coming together nicely. Any provisions for a neutral safety switch on that column?
bigmoe is offline   Reply With Quote
Old 05-23-2022, 01:29 PM   #157
Braunschweiger
I'll probably this reverse switch, down on the steering column, fastened to the shifting, the engine must be started only in P.
Greetings Harald
My 62 build thread
Old 06-10-2022, 10:51 AM   #158
Braunschweiger
Slowly I can do something again, nobody needs Covid19. Inside I'm almost done, the Bench seat still has to go in. I had to install a safety switch so that the engine only starts in "P", the original one collided with the firewall, so nobody was there.
I used a small industrial roller switch and put it on the shift lever
Are there actually longer speedometer cables? I find it a little tight with the TH350
Stabilizer is also attached.
Shift linkage installed.
Rough preset toe, camber and caster.
Now the inner fenders could be mounted.
Fenders attached, whether the alignment is okay.
Greetings Harald
My 62 build thread
Old 06-10-2022, 11:30 AM   #159
Grizz1963
Grizz1963's Avatar
More getting done every day.
Glad you are feeling better.
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside
MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger
IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE.
Grizz1963 is offline   Reply With Quote
Old 06-10-2022, 11:44 AM   #160
Joe Pass
Joe Pass's Avatar
Nice neutral safety switch idea.....My after market column has no provisions also
Joe
Joe Pass is offline   Reply With Quote
Old 06-11-2022, 01:52 AM   #161
Paul Y
This is turning into a very nice truck.
P.
Woody's Build -
http://67-72chevytrucks.com/vboard/s...d.php?t=658621
If it goes wrong, I blame the Internet...
Paul Y is offline   Reply With Quote
Old 06-20-2022, 01:30 PM   #162
Braunschweiger
We continued on the truck, first some rework, the holder of the stabilizer changed from the low to the high holder, gives more space on the tie rod.
Inner fenders, fenders and front mask aligned and screwed everything together.
Bumper bolted to the Bumperette.
Now come the relays for the headlights, the wiring has to be adjusted.
Greetings Harald
My 62 build thread
Old 06-21-2022, 07:01 AM   #163
Paul Y
The more I look at the colour combo the more I like it!
Good work Sir!
P.
Woody's Build -
Old 06-23-2022, 09:15 AM   #164
Braunschweiger
Yes.... thank you. It went a bit further, the Heater is connected, the hose connection is a bit strange due to the Heater Valve. The Wiring Harness is also making progress, the relay for the Headlight is connected, the Wiring Harness in the grill is prepared and the front is painted black and today my Douglas fir wood bed was picked up by the carpenter, I'm really happy about it.
Greetings Harald
My 62 build thread
Old 06-23-2022, 09:19 AM   #165
Joe Pass
Joe Pass's Avatar
Nice work..
Joe
Old 06-23-2022, 12:48 PM   #166
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
I so admire the patience and skills needed for restoring the body metal.
Great work!
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is online now   Reply With Quote
Old 06-24-2022, 08:45 AM   #167
88Stanger
88Stanger's Avatar
great job! really like this build
John 3:16 - Saved me... God Bless
88Stanger is offline   Reply With Quote
Old 06-24-2022, 03:25 PM   #168
Braunschweiger
Thank you, I'll keep you posted.
This weekend is a hot rod meet up with 1/8 mile race in Finofurt near Berlin, great to be around normal people and see so many C10s...... crazy.
Greetings Harald
My 62 build thread
Old 06-27-2022, 12:18 PM   #169
Braunschweiger
Now the C10 has a face again
Greetings Harald
My 62 build thread
Old 06-27-2022, 02:04 PM   #170
realvc
realvc's Avatar
Looking very nice. Can't wait to you driving your truck.
Vince
Galatians 6:14
Old 06-27-2022, 02:14 PM   #171
Grizz1963
Grizz1963's Avatar
Looking so smart already.
Progress
Old 07-05-2022, 07:50 AM   #172
Braunschweiger
In the meantime, the Cowl Covers and Windshield Wiper system have been installed, the electrical system is complete and working, everything is connected for testing.
Finally welded the battery holder, the front edge was brittle.
The seat could now be reinserted.
A new Water Cooler has also arrived, I still have to fit it in, it will work.
Greetings Harald
My 62 build thread
Old 07-05-2022, 07:52 AM   #173
Braunschweiger
A few more pictures
Greetings Harald
My 62 build thread
Old 07-06-2022, 08:14 AM   #174
Grizz1963
Grizz1963's Avatar
Battery tray repair is a great result.
Your red interior really is classy and looks rich.
I like that, a lot.
Old 07-06-2022, 08:48 AM   #175
Braunschweiger
Thanks for the kind words.
Today it ran again for the first time, a bit pre-primed, waved the key and hey it started, don't let it run for long, no cooler is installed yet. But he drives forward and backward, idiotlights go out, when the engine is running.
I'm very happy with myself.
Greetings Harald
My 62 build thread
