Old 06-29-2022, 08:32 AM   #1
Chevy nutcase
Chevy nutcase's Avatar
C10 coil drop vs spindle drop
I'm itching to start ordering parts so I can lower my new 66. My original plan was 2 1/2 drop spindles, disk conversion, dual master cylinder and possibly a booster and 3" rear coils. Well after a bit of study I quickly realized my original wheels may not jive with a modern disk setup soooo I priced out new wheels and tires and it's a minimum $1200 tacked on to my original plan. While I was at it I priced out swapping the rear axles for 5 lug which opens up an ocean of wheel choices and woo hoo the $1200 jump is now $1800 on top of the lowering parts. This got me thinking. The truck stops fine with drums so why not just drop it front and rear using coils. Now obviously a disadvantage of this is loss on suspension travel and disks are superior in almost every way but is there a reason I'm unaware of that 99.999% of lowered trucks upgrade the front hardware to disk when lowering over using just coils? I can get my truck down where I want it for less than half of a disk and or 5 lug conversion. I'll completely replace every drum, shoe, spring, wheel cylinder, hard line and soft line and still have a lot left over for other improvements. It will be interesting to hear what you guys think
Chevy nutcase is offline   Reply With Quote
Old 06-29-2022, 08:55 AM   #2
Paul Y
Re: C10 coil drop vs spindle drop
Drums work fine but do have their limitations, usually when pushed hard or poorly maintained.
If you are on a budget then stick with them, just carry out the preventative maintenance you described.
As for coils I copied Skinny G and used Moog 6454 1 ton coils trimmed to fit up front- I must admit that I am using a dropped spindle and disks but there is no reason why these won't work with a more severe cut to reduce your altitude.
Out back the coils came with the truck but think they are the jeep ones with 2" lowering blocks.
I have seen drop spindle and disk conversions with 6 stud - what is the reason you dont think these will work with your existing wheels?
Share some pictures so we can oooh and aaaaarrr over your purchase!
P.
Woody's Build -
http://67-72chevytrucks.com/vboard/s...d.php?t=658621
If it goes wrong, I blame the Internet...
Paul Y is offline   Reply With Quote
Old 06-29-2022, 09:57 AM   #3
curvedglass
curvedglass's Avatar
I used CPP front disc kit with stock rear drums. CPP power brake booster with included proportioning valve. CPP 2 1/2 spindle and a 1" spring up front and 1 1/2 inch blocks in the rear. I am running 8" 80's 4x4 wheels (6 lug) 235-70-15 tires fit just fine.
Literally the first day after the upgrades I had to jam on the brakes for deer. Discs are worth every penny. No pulling or fade. If you plan to drive the truck in todays traffic (texters etc) they are a must.
--Life looks better through a curved windshield--
curvedglass is offline   Reply With Quote
Old 06-29-2022, 02:43 PM   #4
bigmoe
bigmoe's Avatar
P.
I've read the Skinny G method of using one ton front coils (trimmed) but geez that must make for a stiff ride? I put stock HD coils on front and the ride was pretty harsh (v8/auto). I ended up getting the lightest stock coil (ACDelco # 45H 2104) to use with drop spindles.
bigmoe is online now   Reply With Quote
Old 06-29-2022, 03:47 PM   #5
Paul Y
Time will tell as Woody is still in bits but hopefully it will not be unacceptable. Sure the man himself will be along shortly to corroborate.
P.
Woody's Build -
Old 06-29-2022, 04:03 PM   #6
verdell
verdell's Avatar
I think how you intend to use the truck should be part of the determining factor in your plan to achieve your desired stance/ride height. For occasional cruising around and sticking to a budget, the drums on stock spindles will suffice. However, you can't beat the overall performance, reliability and correct geometry of drop spindles and discs though. Good front suspension parts, shocks and sway bar up front combined with upgraded brakes does wonders for these old trucks. The brakes and front suspension was the very first thing I addressed when building my C10s..
verdell is offline   Reply With Quote
Old 06-29-2022, 05:01 PM   #7
Chevy nutcase
Thanks everyone for the insight. I know the limitations of drum brakes and the advantages of disk brakes and that was my original plan all along and I was prepared to pay for the upgrade but the front wheels accepting the new setup is so unknown. My fear is getting the kit with drop spindles and 6 lug rotors, if they fit, fantastic, if not I'm stuck waiting for tires and rims from a limited selection. I could then get 5 lug rotors and new axles but that in total would be a husky chunk of change when all is said and done. Again not a cheapskate here but theres other things I'd like to be able to afford for this like a new back bumper, power steering and eventually a T5 transmission. I've looked for people parting out a 71 or 72 that has a 5 lug rear diff that could be a direct bolt on swap after rebuilding the brakes of course but I have yet to find one. Here's a few pics if the thing that's been occupying my thoughts lately
Old 06-29-2022, 05:25 PM   #8
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Beautiful truck!
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 06-29-2022, 06:07 PM   #9
EricS76
EricS76's Avatar
Just cut your stock front coils and it’ll cost you $0.00.
‘66 Chevy C-10, long bed fleetside, 350, 3 on the tree, 4-7 drop.
'77 chevy C-10 Custom Deluxe, 350, SM465 4 speed, flatbed.
'80 jeep CJ-5.
‘14 Chevy 1500 Z71…
EricS76 is offline   Reply With Quote
Old 06-29-2022, 06:29 PM   #10
AcampoDave
AcampoDave's Avatar
Nice truck you got there.....I too didn't want to invest big time money on a mostly stock truck which is used around town and on open roads. I redid my drum brakes and split the system to dual reservoir M/C. Then I installed a 2/4 coil drop spring kit that came with shorter shocks, shock relocation brackets, and an adjustable panhard bar. The ride is fine, it only hits the snubbers on big bumps and if I nail the brakes the rear wheels lock up. It's a longbed too. Here's how it sits on 225/35/15 tires and stock wheels....(It's got a barely perceptible rake when you can get it on level ground.)
AcampoDave is offline   Reply With Quote
Old 06-29-2022, 08:20 PM   #11
Chevy nutcase
�� that's a fantastic idea and I feel stupid not thinking of it. My only question would be is how much removed equals how much drop? For example 1 complete twist equals 1" ⬇️? Another question is the spring rate different from lowered coils? Thank you for suggesting that
Old 06-29-2022, 08:26 PM   #12
Chevy nutcase
That's a beautiful truck and sitting exactly how I picture mine. You also did to yours what will likely be done to mine since another board member Erics76 suggested cutting my front coils. Besides that I need 3" rear coils a dual reservoir master cylinder, adjustable track bar and rebuild all 4 corners of the brake system "if necessary " and bada boom vroom vroom
Old 06-29-2022, 09:15 PM   #13
SkinnyG
SkinnyG's Avatar
Roughly one coil is 2".
Cut the bottom of the coil spring NOT the top - the top needs to secure itself properly, and if you cut that off it's harder to do so.
As you go lower, you really need to go stiffer or it will bottom out too easy. Try your stock springs and see if you like it. My squarebody had stock springs cut 3/4 of a coil (with 3" spindles), and then 1-ton springs with about a coil and a quarter removed (stiffer springs need more coils cut).
Good luck. And report back!!
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, turbo, LS
1977 Silverado: Shortboxed & dropped, potato-potato
V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag
Lotus Super 7 Replica: Scratch-built street-legal rollerskate
SkinnyG is offline   Reply With Quote
Old 06-29-2022, 10:48 PM   #14
AcampoDave
AcampoDave's Avatar
On my shortbed I dropped the rear with a 2" spring and a 1" axle block. Obviously, this did affect the shock angle and travel although not severely. (The spring changed the shock but the block didn't.) Anyhow....someone posted a mod to the upper shock mount where you drill a new hole higher and in a more direct line to the bottom. I did it and it worked great. I searched for that thread but can't find it. This pic will help explain, basically you are redrilling the hole in the red area and cutting it off at the yellow line. This of course only approximates the info given in the actual thread but hopefully someone else knows where it is and will drop in and link it up
Edit: I would've used a drill press if I had one but managed it with a handheld placing the bracket in a vise.
Old 06-29-2022, 10:54 PM   #15
EricS76
EricS76's Avatar
I cut one complete coil out and it was just a little less than 2” of drop when I put it all back together. As for different spring rate, I don’t know. Mine rides about the same with the coil cut out.
'80 jeep CJ-5.
‘14 Chevy 1500 Z71…
Old 06-29-2022, 11:05 PM   #16
Chevy nutcase
I thank everyone for their input on this matter. I wish I had parts ordered a week ago but I like to get a certain amount of ducks in a row before I pull a trigger this big. Looks like I'll be cutting the front coils and replacing the other stuff. I'll absolutely let you guys know when parts start flying
Old 06-29-2022, 11:30 PM   #17
AcampoDave
AcampoDave's Avatar
Hey, I found it. I didn't mess with the lower mounts, only the top because 63-'66 are different than 67-67 on the bottom. http://67-72chevytrucks.com/vboard/s...d.php?t=359399
Old 06-30-2022, 12:51 AM   #18
Chevy nutcase
That's awesome. Thank you for finding this. Like you I think I could get away with only modifying the upper mounts since I'm only dropping the rear 3". 4 or 5 would probably need lowers changed as well
Old 06-30-2022, 06:30 AM   #19
Paul Y
You could always look at mounting the rear shocks outside the chassis like FrizzleFry did. I copied his methodology on my truck when I first did the suspension upgrades and it made a noticeable difference.
Not his post but his pictures.
http://67-72chevytrucks.com/vboard/s...d.php?t=612934
P. D
Woody's Build -
Old 06-30-2022, 08:42 AM   #20
SCOTI
SCOTI's Avatar
Since I'm the guy that originally posted the info, yes, you can just do the upper mount mod but travel gains won't be as much. As @Paul_Y suggested, the outboard mounting offers better results.
As for just cutting coils.... Yes, it can work; but it def will leave some ride quality on the table. For a part time rig & a temporary set-up it gets the truck closer to what you want while saving for the better braking set-up.
The issue you mention (6-lug discs working w/your OE 6-lug wheels)? There will be interference as the barrel of a drum brake wheel was different vs when disc brake wheels came into play. There will be caliper clearance issues. Options are to find/purchase just some new front aftermarket steel wheels in the same size. That allows the front tires to swap over so no additional costs & they'll work w/the disc set-up. With hubcaps on, you really won't notice a difference.
My disc swap combo was typically dropped disc brake spindles & one coil off the original springs (if I liked the ride quality of the un-cut springs & there was no excessive lean). If you cut the coils beyond that 1-coil, that's where you'll start to muddy the waters.
The original springs usually don't have enough spring rate when the springs height is reduced drastically (say 2-coils removed). My research stated that removing 1-coil was the equivalent of increasing the spring rate by </= 20%. The more you cut, the more the rate increases but it may/may-not be enough of an increase for the reduction in travel.
If the original spring rate is 700# & 2 coils are removed w/a rate increase of ~20% you would be around 840#. You might need 980# for that height of spring to yield a ride that's not constantly compressing to the point of contact. This is where the combo's provided w/the kits have some value (unless they're not doing the homework & just tossing parts together). The longer the coil, the better the ride quality.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 06-30-2022, 09:50 AM   #21
AcampoDave
AcampoDave's Avatar
SCOTI that was a great write up on the shock brackets. After I did the top, a tape measure revealed the installed shock length to be unchanged, simply because the shock became straighter and the distance between the top and bottom shortened. But then the higher mounting point restored it to its former length. The real benefit to me was restoring the shock to its original angle. What I've wondered for some time however is this; if the shock set up on the 60-62 was superior to 63-66, why did Chevy change it?
Old 06-30-2022, 10:49 AM   #22
Chevy Fleetside
Chevy Fleetside's Avatar
http://67-72chevytrucks.com/vboard/s...d.php?t=727826 This is what I did for the disc brake swap. I basically put my own together with parts from rockauto.com I have since lowered it with 2 1/2 drop spindles and 3" drop springs in the back with 235/75 r15 tires all around. I do have 5 lug up front and 6 in the rear but will change that soon. I have 6 lug disc's waiting for me to install after I make sure my wheels fit. Too bad your that far away from here. I have a 72 rear end I might want to part with and also a complete 73 front suspension. They are for another truck I have which will probably not get built now.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 06-30-2022, 12:26 PM   #23
verdell
verdell's Avatar
As a 60-62 owner, I've always wondered the same thing. Especially with companies like No Limit Engineering selling shock mount kits that replicate the 60-62 rear set up.
Old 06-30-2022, 01:10 PM   #24
SCOTI
SCOTI's Avatar
My guess it's relayed to the actual change w/the frame. Eliminating the x-center & revision @ the rear x-members allowed incorporating the shocks there. That being said, the farther out the springs & shocks are, the more stable the ride will be.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 06-30-2022, 01:12 PM   #25
SCOTI
SCOTI's Avatar
When I first lowered my 68, I did the same thing. Five lug OE disc brake front wheels & 6-lug OE rears. With the poverty caps on, you didn't know they weren't the same.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
