Old 03-02-2023, 05:12 PM   #1
sfont66
sfont66's Avatar
Drive line angle questions
Truck is a 72 C10 SWB with coil spring/ trailing arm rear suspension. My current angles have the transmission at 3.6 degrees down, and rear end at 2.3 degrees with pinion pointing up( sloping down from front to back) drive shaft is 1.3 degrees down. So in order to get the angles closer to correct, I have been trying to find a 1 degree or even a 1.5 degree shim for the axle. I see Cpp had them in the past but now I can only find 2,4, and 6 degree. Same at Speedway, and Brother’s/Holley. I find 1 degree shims at Summit, but not sure of fitment and they don’t have dimensions for length, and are special order.
I do have 2 degree shims on hand .
I have talked with Silver Sport Transmission, and I seem to recall they recommend that I try to keep the transmission at 3 degrees if possible, and I can’t raise it any further without cutting the floor of the truck.
So my question is: does anyone know where to purchase 1 degree shims, or should I install the 2 degree shims, making the rear 4.3 degrees, and then lower the transmission to the 4.3 degrees to make for more optimal driveline angles??
Can anyone see a problem with the engine /transmission being at 4.3 degrees down?
Any advice is appreciated
72 C10, Was a 350,M20, Brodix heads,Comp cam, Edelbrock intake&carb, Hedman hedders LWB.
Project is now a 5.3(L33) w/PRC stage 2.5 CNC ported 243heads, BTR RedHot cam,Holley Terminator X, T56 magnum. SWB, Boyd tank. 4.5/4 Drop http://67-72chevytrucks.com/vboard/s...My72c10project
sfont66 is offline   Reply With Quote
Old 03-03-2023, 12:39 AM   #2
Richard
Re: Drive line angle questions
Your current working angles are fine, actually real good. The 3 degree recommendation refers to the working angle of joint not a transmission, driveline or pinion. Your working angles are pretty close to being within 1 degree. Typically the pinion should be down 1-2 degrees to allow for wrap under acceleration.
Unless you have a vibration there is no reason to do anything.
Richard
Old 03-03-2023, 02:16 PM   #3
MySons68C20
MySons68C20's Avatar
So the goal is to keep them within 1 degree of each other correct?
MySons68C20 is online now   Reply With Quote
Old 03-04-2023, 08:50 AM   #4
sfont66
sfont66's Avatar
Thanks for your reply
I only have what could be described as a very slight vibration while cruising at 75-80 in 6th gear. It’s possible it’s not even drivetrain related. I haven’t driven the truck for 5 months now(winter weather) and it will be another month or two before I can do so again, to investigate further.
Old 03-09-2023, 10:02 PM   #5
samert111
samert111's Avatar
I always understood that the trans output shaft centerline and pinion centerlines should be parallel to one another but not necessarily inline with one another to improve ujoint wear. The centerline to centerline difference to create a max 3° driveshaft angle.
samert111 is offline   Reply With Quote
Old 03-11-2023, 11:15 PM   #6
2500HD
2500HD's Avatar
With your angels listed above i would raise the trans 1 degree and leave the rear alone. When raising the trans it will also cahnge the angle of the driveshaft to close to 2 degrees resulting in 2.6/2/2.3.
1970 Custom Original 400/400
Now ZZ454/4L80E/Edelbrock Pro-Flo 4/3:73 Eaton Posi
PS PB and cold factory air
Early Classic 4.5/6
Front 20X8.5 Riddler 4.75 inch bs Pirelli 255/40/20
Rear 20X10 Riddler 5.5 inch bs Toyo 295/40/40
Rear end is original wide 6 lug converted to 5 lug
2500HD is offline   Reply With Quote
Old 03-12-2023, 11:11 PM   #7
sfont66
sfont66's Avatar
Thanks for your reply,
The transmission in my truck is a T56 magnum, and is fairly large, I have the high hump transmission tunnel, but even with the high hump, a portion of the rear of the transmission is very close to contacting the floor of the truck. I can’t raise the transmission any further without modifying the floor. I found a company that makes a extended high hump cover, and believe it would allow the transmission to be raised far enough to get to 2.6 degrees. Level 7 is proud of this piece, as they are fairly expensive, $355 plus tax and shipping.
This could be a solution though, with those numbers the drive shaft may be happier.
I’m not sure how to figure what the driveshaft angle would be if I added a 1 degree shim to the rear of current setup to plug the numbers into the driveline calculator, to get the operating angles, so my original plan may not be the best plan.
Again, I want to thank those that have responded with suggestions /advice, I appreciate it.
Old 03-13-2023, 11:40 PM   #8
2500HD
2500HD's Avatar
You could always get a little heat and an air hammer and message it a bit. i will not take as much as you think. 1/2 to 3/4 i bet.
Early Classic 4.5/6
Old 03-14-2023, 03:11 AM   #9
Richard
3 degrees references the operating angle of the ujoint, not a component. The components create the operating angle. Operating angle is what is important. Understand, it is not like the ujoint explodes if that number is exceeded. It is said the life of joint is decreased if above 3 degrees. I have had two previous 4x4's and my current one. Past two and current had and will exceed that 3 degree theshold. Never had a problem with ujoint life or excessive vibrations. My current build will have about a 15 degree driveshaft angle at ride height and 25+ degrees at full droop. It will give me about 5 degrees operating angle on the joints in the double cardan cv at ride height. Will live a long service life. The operating angles constantly change while driving with any suspension. Need to get them close at ride height. IMO many people over think this.
Richard
Old 03-14-2023, 06:29 PM   #10
MySons68C20
Great post!!^^^^^^
Old 03-15-2023, 08:53 PM   #11
2500HD
2500HD's Avatar
i agree with you and i think we are saying the same thing. if the componets are correct so will the ujoint operating angle. the one thing we may not agree on is what excessive vibration is. In my opinion any driveline vibration is excessive. Unless a vehicle has a big lift there is no reason the component angles and therefore the oprtating angles cant be really close. I just went though this on my truck and as it turned out the brake drums were causing the vibration.
Early Classic 4.5/6
Old 03-16-2023, 12:23 AM   #12
Richard
Regarding component angles, saying that my engine/trans, drive shaft or pinion should be at a certain angle is really useless info IMO. Those optimum angles are going to be different for my dropped truck, lifted truck or stock truck. I will adjust those angles to obtain the best ujoint operating angles for the vehicle.
I do not recall stating it was okay for the operating angles to be far apart. Infact, I said they should be within 1 degree. I did point out that exceeding the 3 degree recommendation is not a big deal. I have a 94 extended cab that I installed a 6/8 drop on and drove it that way for many years. Is lifted now. Has a two piece drive line so I have dealt with that as well for experience.
I also said the operating angles constantly change. Depending on suspension type such as the trailing arm and angled leaf springs on the old trucks the pinion angles down the more suspension compresses. A 4 link may be more linear depending on link bar length. Then there is wrap from torque. Which still exists even on a trailing arm truck or even a 4 link.
All is good with me, just wanted to explain where I am coming from. My last comment about overthinking it was not meant as an insult. I just believe that searching for the perfect combination of angles can be a fruitless endeavor. It is literally impossible to keep the ujoints in phase under all driving conditions.
Richard
Old 03-18-2023, 12:03 AM   #13
2500HD
2500HD's Avatar
Whatever. live with your "good enough" result. You contradict yourself mutiple times and i will not argue with generalities. i am out.
The fact the engine/trans angle should be 3 degrees or less due to oiling and fueling issues is hardly usless. You should have a 3 degree or less engine/trans angle regatdless of lifted or lowered.
You never mentioned the angles on your lifted or lowered 94. do you even know what they were. Did it vibrate? Vibrate acceptable to you? acceptable to me? I doubt it.
Recomendations, why would anyone listen to the manufactures recomendations? Richard from SoCal seems to be much smarter. Run u joints from 1 degree to 90 degrees and they should be good..... i think. ask Richard to be sure.
I agree angles constanly change but they are at max droop or max compression for milliseconds if ever. The suspension stays within 2 degrees 98% of the time for a street driven truck.
Early Classic 4.5/6
Old 03-18-2023, 12:20 AM   #14
2500HD
2500HD's Avatar
Back to this. message the trans tunnel 1/2 to 3/4 to raise the tailshaft and be happy. start wide and raise over a wide area. you will not even notice inside the cab.
Early Classic 4.5/6
Old 03-18-2023, 02:38 AM   #15
Richard
Apologize I am not explaining myself in a way you can understand. You are assuming I live with the vibration. Sorry, I have not experienced any. Custom stuff is, well custom. You could put the motor and trans at 10 degrees and as long as the pickup is submerged the motor and trans will be fine. It is a pressurized system. An acute angle would have no bearing on a FI motor fueling, just a carb. Do not want to pollute this thread any more than I have with a lot of figures of my setups. I have nothing to prove. Just trying to help others with my experiences. I am out with you as well, you are getting nasty with needless insults. Sorry to the OP for this getting out of hand.
Seriously, do you think I would have driven a vehicle with a vibration for any amount of time? That is ridiculous.
Richard
Old 03-18-2023, 01:38 PM   #16
sfont66
sfont66's Avatar
I was able to massage the transmission tunnel enough to allow the transmission to be shimmed up to 2.6 degrees, this made the driveshaft angle 1.7 degrees, and the rear remains unchanged, so it should still be the 2.3 degrees.
To me these angles are an improvement and should take away the slight vibration I was feeling at freeway speeds.
It will most likely be at least another month before I can do a test drive to prove these changes. (We received another 16” of snow in the past week)
I see the first pic loaded sideways, it was tough to get a good shot.
Originally I thought it would be easier to shim the rear up to correct my pinion angle, but after thinking it through, doing so would have made my operating angles worse. The drive shaft angle would have been less , and when doing the math, my operating angles would have been worse than when I began.
There is a lot of information out there when researching this subject, and sometimes a person can go down the rabbit hole with information that doesn’t directly apply to their specific application.
Many years ago my wife purchased a sign for the garage, can you find it? I guess for me this is true.
I asked for, and received valuable information from those who have experience setting up their own trucks.
Thanks again to all
Old 03-19-2023, 01:57 AM   #17
2500HD
2500HD's Avatar
Thats great sfont66. If you have any vibrations now i am sure it is somthing other than driveline angles.
Early Classic 4.5/6
