Old 03-21-2023, 03:23 PM   #1
mike16
Ignition key door key
My 72 c10 came without keys.
Are the ignition key and the door key the same?
mike16 is offline   Reply With Quote
Old 03-21-2023, 04:10 PM   #2
Extended Power
Extended Power's Avatar
Re: Ignition key door key
Negative.
Two separate keys.
The ignition is a rectangular shaped key, and the door locks are more.....”round”
And they are “keyed” differently.
"If it ain't broken, fix it 'till it is!"
Extended Power is offline   Reply With Quote
Old 03-21-2023, 04:17 PM   #3
jabborabbo
jabborabbo's Avatar
What year did the keys become different? (My ‘67 GMC uses one key.)
"It is hard to search for a black cat in a dark room, particularly if it is not there. Especially if this cat is smart, brave, and polite." Sergei Shoigu, Russian Minister of Defense
jabborabbo is offline   Reply With Quote
Old 03-21-2023, 04:37 PM   #4
FirstOwner69
FirstOwner69's Avatar
Same thing with my '69. It has never had 2 keys. Just the rectangular head version. I always thought they should have had separate keys for ignition and doors.
Jim
FirstOwner69 is offline   Reply With Quote
Old 03-21-2023, 04:39 PM   #5
too much stuff
Roadtrip!
too much stuff's Avatar
I know originally the early ones did use the same keys. Not sure if or when they changed to 2 different keys in the 67-72s. Check with lockdoc on the board here, he will probably know.
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 03-21-2023, 04:40 PM   #6
LockDoc
The Older Generation
LockDoc's Avatar
Originally Posted by Extended Power View Post
Negative.
Two separate keys.
You would be wrong.
All '67 - '72 Chevy and GMC trucks came from the factory with the same key for doors and ignition. If you have a truck with different keys for the doors and ignition then someone has changed one or more of the locks, usually the ignition. '73 was the changeover year for 2 keys....
LockDoc
Leon
Old 03-21-2023, 04:45 PM   #7
LockDoc
LockDoc's Avatar
They should be the same if none of the locks have been replaced.
The first thing I would do is to pull the passengers door lock out and see if there is a code number stamped into it. If there is take it to a locksmith and have him cut you a key. If the locks are all original the key will fit the ignition. If you don't have a locksmith close PM me the code number and I will cut you a key and send it to you for 8 bucks. If there is no code number on it, the door lock can still be disassembled and de-coded to cut a key. The destructive methods (drilling, sawzall, etc)would be a last resort for me.
Picture shows the location of the code number.
LockDoc
Leon
Old 03-21-2023, 05:21 PM   #8
jabborabbo
jabborabbo's Avatar
LockDoc is a treasure of knowledge on this website!!!!!
Old 03-21-2023, 07:10 PM   #9
Extended Power
Originally Posted by LockDoc View Post
You would be wrong.
LockDoc
Right on.
Good to know.
Obviously mine have had the door locks, or ignition changed, over the years.
Old 03-21-2023, 08:28 PM   #10
LockDoc
LockDoc's Avatar
Thanks for the vote of confidence.. ... I think it is only because I am on here a lot and do a lot of reading. Yes, I have built a few trucks, but this site is where I got most of my information too. There have been a LOT of knowledgeable people before me. I just like to try and spread it around.
LockDoc
Leon
Old 03-21-2023, 08:37 PM   #11
LockDoc
LockDoc's Avatar
Right on.
Good to know.
If you are comfortable carrying two keys there is nothing wrong with that. If you ever decide to convert to one key this is a good solution:
https://www.speedwaymotors.com/Class...GM,116526.html
Not the cheapest aftermarket set, but it is the best aftermarket set. Made in Mexico, it is the closest to NOS or OEM you can get.
LockDoc
Leon
Old 03-21-2023, 09:15 PM   #12
mike16
My next question is weather the lock blank/ plug is standard or normal on the passenger side door?
Old 03-21-2023, 10:08 PM   #13
Stocker
20' Daredevil (Ret)
Stocker's Avatar
I'm gonna say no. I have never seen that before, only the same type lock as on the driver's door.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is online now   Reply With Quote
Old 03-21-2023, 10:17 PM   #14
'68OrangeSunshine
'68OrangeSunshine's Avatar
Hey Mike -- I've never seen that on a '67-'72. Is it on a Panel Truck perhaps?
I saw a thread about how a '63 C/10 had a 3-way passenger side door handle -- Lock/Neutral/Unlock -- but in '67 GM changed trucks to be unlockable if you pushed the button down, held the release in and closed to door to lock, like the passenger cars. The button would just pop up again.
If a turnip farmer came to town, and left the keys in the ignition, and locked the door, how would he get back in?
I call it the Turnip Truck Anti Lockout Feature.
What year and type of truck is your photo from?
Old 03-21-2023, 11:47 PM   #15
LockDoc
LockDoc's Avatar
I would say that is just a snap in plug that happend to fit.
Here is a picture of an original GM blank door lock cylinder. I removed this one from a C50 truck over at my local salvage yard. It is made just like a keyed door lock cylinder except it has a blank cover. I have only seen one other one and it was on the for sale board on here.
LockDoc
Leon
Old 03-22-2023, 10:15 AM   #16
jabborabbo
jabborabbo's Avatar
Negative.
Two separate keys.
And BTW…my original keys are octagonal - my copies are rectangular.
Old 03-22-2023, 10:49 AM   #17
LockDoc
LockDoc's Avatar
Yes, that would be all '67 and early '68 only. The octagon head key blanks are harder to find than the rectangular head blanks.
LockDoc
Leon
Old 03-22-2023, 11:11 AM   #18
67 twins
Location: Herculaneum MO (20 minutes south of St. Louis
LockDoc
Well I guess none of the keys for the three 67s the wife and I own are original then.
67 C10 283 T5 swapped longbed fleetside = wife's daily driver
67 C20 292 (originally a 250)4speed longbed fleetside w/original wooden bed=my project truck
67 C10 283+.060 (so a 292 as well)T5 swapped longbed fleetside=my DD
72 C1500 Sierra Grande 350 TH350 longbed fleetside=wife's fair weather truck
Can you tell we are fans of longbed fleetsides & 67s
Chris
67 twins is offline   Reply With Quote
Old 03-22-2023, 12:34 PM   #19
LockDoc
LockDoc's Avatar
Here is a picture of the 3 different octagon keys. If anyone is looking for blanks for their truck you need to make sure you get the correct one.
The one on the left will only fit the 1935 - '66 trucks. (no stamp) The center one is for the 1967 trucks ("A" stamp), and the right one is for the '68 trucks "C" stamp). Some of the early '68 trucks may have used the "A" key blank. I have not tried to verify that though. This information mostly applies to original GM key blanks.
LockDoc
Leon
Old 03-22-2023, 09:07 PM   #20
mike16
So, is there a code on the driver's side door lock. Since that's the only door lock I have?
Old 03-22-2023, 09:40 PM   #21
LockDoc
LockDoc's Avatar
Some door locks have a code number and some don't. You will just have to take it out and see..... I always mention the passengers side because That is the one I always remove first to check. Be sure and spray some penetrating oil on the spring clip inside the door so it will slide off easier. And wear some gloves, it can be a knuckle buster when you remove it.
LockDoc
Leon
Old 04-04-2023, 08:06 PM   #22
Casper42
Casper42's Avatar
not here to argue with the apparent guru of keys and locks, but if the expert says they all came with ONE key and not two, then why do all the aftermarket suppliers say otherwise - one square key for the ignition "code C" and the other for the doors - a round key with "code D"?
My darn near original, unmolested '72 C10 has two keys - no reason to suggest any of the locks/ignition would have been swapped out. I don't have the OEM keys, so I went with Classic Industries and got the OEM looking keys, however the door key does not match the pattern to even fit. the key for the door lacks the longest groove at the top most portion of the key (bottom picture - right side), thus I am not certain which key would actually work. Based on visual comparison of "GM keys" online it seems that "code B" is the correct one for my doors.
(LEFT - old working key: RIGHT - new not working key)
'72 C10 Cheyenne SWB North Carolina truck for 50 years, 72k original miles, Medium/Hawaiian Blue, 3 owners - one for 40 years, garaged kept, original: sheetmetal, undercarriage, moldings, glass
New - engine rebuild at 65k in 2015, one repaint in 2010, new front bumper, houndstooth seat, carpet, 8 inch rally wheels on 275-60R-15, LED lighting. - Semper Paratus!
Casper42 is offline   Reply With Quote
Old 04-04-2023, 11:05 PM   #23
Orefactory4x4 swb
Active Member
Lock doc is one of many things I like about this site, gives us beginners hope we can pull off a nice build
Orefactory4x4 swb is offline   Reply With Quote
Old 04-05-2023, 12:25 AM   #24
LockDoc
LockDoc's Avatar
"All" is a pretty strong word, and "all" of them don't say that. The below suppliers list 67-72 truck sets with one key for all locks and I didn't check half of the ones that came up in my search. Some of the aftermarket suppliers don't know, or could care less what is original or correct for a certain year of truck. The 1973 & up truck lock sets are the ones that use two different keys. None of this applies to autos of the same era as some of them used the two key system.
https://www.ebay.com/itm/22399368974...38e41162c50232
https://www.ebay.com/itm/32544782428...94a795345dc308
https://www.lmctruck.com/1967-72-che...ock-sets-color
https://aapd.net/lock-kit-67-72-284-chevy-pickup-67-72
https://www.manestruckparts.com/stor...&Category_ID=7
Here is a key chart that lists all of the key blanks used for the '67-'72 GM trucks.
https://67-72chevytrucks.com/vboard/...d.php?t=246485
You will notice there are no "B", "D", or "K" key blanks listed for '67-'72 GM trucks. That is because they are the secondary keys used for door locks on '73 up trucks.
Your '72 would have came from the factory with all of the locks keyed to the "C" keyway and used the same key for all locks..... If your '72 GM truck uses two different keys then one or more of your locks have been changed at some point in it's life.
LockDoc
Leon
Old 04-05-2023, 12:51 AM   #25
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Negative.
Two separate keys.
Say what? The ignition and locks take the same key from factory.
If Doc says it's so it's so. No pressure Doc Speak of keys, I already misplaced one of two from a set I bought from Doc. I took one to the locksmith just today, and they made two more on GM blanks of which they had in stock, a very pleasant surprise.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
