04-03-2023, 07:23 PM | #1 | |
Re: Firewall or Under Floor Mounted Master Cylinder?
Laid it out on chip board and traced it. Then put the old pedal arm down and sloooooowly ground and filed down until they mated. Pinned, then tapped the pin holes. Counter sunk screws. Less than 1/16" inch movement thru stroke. Took an entire weekend. I hate it when I come up with these screwy ideas, only to spend hundreds of hours building. Still beats the best day at work though.
Chip '51 Chevy 3600 5 window C4 Vette front/rear suspension & drive train full Rusto-Mod '92 GMC Sonoma GT VIN #0015 '91 GMC Sonoma GT extended cab 1 of 1 |
04-04-2023, 01:42 PM | #2 |
I have had it both way. Currently I have a Wilwood unit mounted on the frame under the body. Once you get your system bleed and assuming you have no leaks there is really no maintenance or reason you need to be fooling with it much. I made a metal cover wrapped in the same leather as my interior. It fastens to the floor utilizing nutzirts in the floor. My floormat covers over this access door. I just wanted at well thought out/functional solution.
Marc
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
04-14-2023, 10:00 AM | #3 | |
RUBBER DOWN AND HIT THE ROAD!!! 1940 Ford Dlx Coupe 1969 Mach1 |
