Insane oil leak
Asking for a friend who just got his engine fired up after being built 3 years ago. Older motor Fired up with synthetic oil. Did a break in. lost over 2 courts of oil in just a couple hundred miles.
He has compression sees oil on the threads of the plugs. I am thinking valve seals, how do you check this
Chris _______________________________ 1979 Chevy Stepside SPORT 2018 Chevy Silverado, 39 years apart ![]() My build 2008-2016. http://m.imgur.com/a/bURrE |
Re: Insane oil leak
What kind of engine?
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
#3 | |
Re: Insane oil leak
Re: Insane oil leak
2 quarts in a couple hundred miles . I would think it would be smoking pretty bad . Can’t see seals doing that much , my 68 327 uses oil and fouls the #1 plug regularly so I know the seals are bad but it doesn’t use that much and it hardly smokes at startup . Any plugs fouled?
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. |
Re: Insane oil leak
Did he break it in with synthetic oil? If so nothing broke in I would drain it put break in oil in it and redo the procedure.
Re: Insane oil leak
Pull a couple of the oily plugs. If the tips are also oil coated, could be the valve seals. But as mentioned, a normal sign of burning oil is blue exhaust smoke.
Another reason the outside of the spark plugs could be oily is leaking valve cover gaskets. But that much leakage should show up on the floor. OEM valve covers or aftermarket? Some aftermarket skip the baffles for the PCV connections. No baffles could cause excessive oil consumption. |
Robert Olson Transport
![]() Join Date: Oct 2002
Re: Insane oil leak
on tv years ago guy had similar issue with a fresh rebuild on a corvette.. turns out the intake manifold was bad and it was sucking oil down the ports it was an episode of fantomworks
Bob 1951 International running on a squarebody chassis "If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board" http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!) PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport Live each day to the fullest.. you never know when fate is going to pull the rug out from under you... I hate cancer!! |
Re: Insane oil leak
thanks guys, going to try to do the break in again
Just here to tinker
![]() Join Date: Jun 2008
Re: Insane oil leak
x2
78 C10 SWB Diesel #1 (wrecked)http://67-72chevytrucks.com/vboard/s...1978+silverado 78 C10 SWB Diesel #2 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=650751 60 GMC Suburban (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=445526 60 GMC 1000 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=298235 67 GMC 1500 (sold) http://67-72chevytrucks.com/vboard/s...d.php?t=803695 86 Suburban(summer unit) http://67-72chevytrucks.com/vboard/s...d.php?t=810697 88 Suburban 4x4(winter unit)https://67-72chevytrucks.com/vboard/...25#post8900725 |
