Old 05-18-2023, 07:48 AM   #1
chrismoore701
chrismoore701's Avatar
Fouling plugs
I am fouling plugs on cylinder 1 & 2. I am running NGK R5671A-7 plugs. Should I change these?
350 Gen 1 bored 40 0ver, 400 crank, 750 double pumper.
New build mostly idle time, around the block a couple times, but not driving daily yet
Chris
_______________________________
1979 Chevy Stepside SPORT
2018 Chevy Silverado, 39 years apart
My build 2008-2016. http://m.imgur.com/a/bURrE
chrismoore701 is offline   Reply With Quote
Old 05-18-2023, 10:43 AM   #2
kwmech
Re: Fouling plugs
The 750 double pumper may be putting too much fuel into the engine
Old 05-18-2023, 12:21 PM   #3
Dead Parrot
Re: Fouling plugs
Its not even started to break in. Verify timing and run it. Check the plugs again after a couple hundred miles.
Double check for a vacuum leak on the back cylinders. A brake booster can leak while still providing boost.
Dead Parrot is offline   Reply With Quote
Old 05-19-2023, 09:47 AM   #4
VWNate1
VWNate1's Avatar
Post Fouling Spark Plugs
It depends on how they're fouling ~ oil or fuel ? .
What's the gap ? .
Points or breakerless ignition .
-Nate
Geezer
'49 3100 235 W/ Muncie SM420 SOLD
'69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH
VWNate1 is offline   Reply With Quote
Old 05-22-2023, 12:32 AM   #5
Pontiac1976
Pontiac1976's Avatar
Re: Fouling plugs
VWNate1
What's the gap ? .
Should be HEI 43-45 gap. As said by VWNate1.
And I would use a vacuum Gauge to adjust the carb check the timing. Did you have the head seat seals changed make sure the plugs are not oiling fouled. Go back to basic re-ID: the plugs again to find out the problem.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
Old 05-22-2023, 07:30 AM   #6
chrismoore701
Re: Fouling plugs
It is carbon fouled
HEI Distributer
I think the gaps are about 0.55
Chris
Old 05-22-2023, 08:08 PM   #7
VWNate1
VWNate1's Avatar
Post Fuel Fouling Plugs
Okay ;
Now you're getting some where .
Time to check the timing and then look at the fuel system as carbon usually means running too rich and there are myriad simple reasons for this .
-Nate
Geezer
Old 05-23-2023, 07:21 AM   #8
chrismoore701
Re: Fouling plugs
I have heard my carb is too big
Double pumpers are used for manual race cars, not drivers
Chris
Old 05-23-2023, 08:01 AM   #9
geezer#99
geezer#99's Avatar
Re: Fouling plugs
New build, mostly idle time you said.
We’re assuming you did the required cam break in. Normally 2000 rpm for 20 minutes.
A double pumpers not too big. If the floats are set too high or the power valve is not the right one you can get a rich carb.
Lack of enough timing can cause fouling too.
geezer#99 is online now   Reply With Quote
Old 05-24-2023, 07:24 AM   #10
chrismoore701
Re: Fouling plugs
I did the proper break in I have an 8.5 power valve & 73 main jet and a 77 secondary jet
Chris
Old 05-24-2023, 08:11 AM   #11
geezer#99
geezer#99's Avatar
Re: Fouling plugs
What’s your idle rpm?
What’s your initial timing?
What’s the vacuum reading at idle?
What do the plugs look like on 7 and 8?
Old 05-24-2023, 01:24 PM   #12
VWNate1
VWNate1's Avatar
Post Fuel Fouling Spark Plugs
Plenty of double pumper carbys are factory stock .
Yours -may- be too big, keep following the basic questions here, in my long career most times it will turn out to be a simple thing once you find it .
-Nate
Geezer
Old 05-24-2023, 07:42 PM   #13
Dead Parrot
Re: Fouling plugs
Hard to get a good plug read 'just idling'. Drive it 20 or so miles to a good place to eat, get lunch, come back and when it cools off, see what the plugs say. Plus it will be a good start on the break in process.
Old 05-25-2023, 07:21 AM   #14
chrismoore701
Re: Fouling plugs
That is the new plan
thanks
Chris
