Power Steering Box Adapter Fitting
Looking at running the stock high pressure power steering hose that came with my donor LS power steering pump with the srock 1969 power steering box. What adapter have you guys used to accomplish this? Am I correct in that I need a flare to o-ring style adapter? I can find tons of o-ring to flare, but flare to o-ring seem to be harder to find. Any help would be appreciated.
Re: Power Steering Box Adapter Fitting
I called summit, and they sent me the right stuff for my Nova project
#3 | |
![]() Join Date: Nov 2015
Not exactly the same, but works if you have the parts… When I did my swap on my 72 C10 I just swapped the fitting from the power steering pump on the 72 (assuming you have the fitting from your 69 pump) to the LS pump. This allowed me to use the original flare type fitting on the original pressure hose from the steering box to the Ls pump. I did buy a new pressure line and bend the ends more to my liking with a brake line bender Perhaps this is another option for you
72 C10, Was a 350,M20, Brodix heads,Comp cam, Edelbrock intake&carb, Hedman hedders LWB. Project is now a 5.3(L33) w/PRC stage 2.5 CNC ported 243heads, BTR RedHot cam,Holley Terminator X, T56 magnum. SWB, Boyd tank. 4.5/4 Drop http://67-72chevytrucks.com/vboard/s...My72c10project |
#4 | |
just swap the pump fitting it will work.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205 86 k30, 89 diesel burb, 76 gmc pathfinder 71 longbed 5.3 4l80 http://67-72chevytrucks.com/vboard/s...d.php?t=522535 |
