Old 06-15-2023, 12:17 AM   #1
D-n-Tyke
Power Steering Box Adapter Fitting
Looking at running the stock high pressure power steering hose that came with my donor LS power steering pump with the srock 1969 power steering box. What adapter have you guys used to accomplish this? Am I correct in that I need a flare to o-ring style adapter? I can find tons of o-ring to flare, but flare to o-ring seem to be harder to find. Any help would be appreciated.
D-n-Tyke is offline   Reply With Quote
Old 06-15-2023, 03:01 AM   #2
Ziegelsteinfaust
Re: Power Steering Box Adapter Fitting
I called summit, and they sent me the right stuff for my Nova project
Ziegelsteinfaust is offline   Reply With Quote
Old 06-15-2023, 11:50 AM   #3
sfont66
sfont66's Avatar
Not exactly the same, but works if you have the parts…
When I did my swap on my 72 C10 I just swapped the fitting from the power steering pump on the 72 (assuming you have the fitting from your 69 pump) to the LS pump.
This allowed me to use the original flare type fitting on the original pressure hose from the steering box to the Ls pump.
I did buy a new pressure line and bend the ends more to my liking with a brake line bender
Perhaps this is another option for you
72 C10, Was a 350,M20, Brodix heads,Comp cam, Edelbrock intake&carb, Hedman hedders LWB.
Project is now a 5.3(L33) w/PRC stage 2.5 CNC ported 243heads, BTR RedHot cam,Holley Terminator X, T56 magnum. SWB, Boyd tank. 4.5/4 Drop http://67-72chevytrucks.com/vboard/s...My72c10project
sfont66 is online now   Reply With Quote
Old 06-15-2023, 09:00 PM   #4
D-n-Tyke
I saw inline tube has those and was windering if that would work If I have to buy an adapter anyways I think I would rather change out the pump fitting since the fitting and adapter are basically the same price.
Old 06-16-2023, 07:51 PM   #5
v30crewcab
v30crewcab's Avatar
just swap the pump fitting it will work.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205
86 k30, 89 diesel burb, 76 gmc pathfinder
71 longbed 5.3 4l80
http://67-72chevytrucks.com/vboard/s...d.php?t=522535
v30crewcab is offline   Reply With Quote
