![]() Join Date: Nov 2001
Big washers used on front bumper
We got any venders here or outside to purchase these big flat washers, and or can I find them at a good nut and bolt supply place. What would be the size needed.
Thanks NGN NICK. |
![]() Join Date: Dec 2009
Re: Big washers used on front bumper
McMaster Carr is a good Go-To place.
They have different plating choices also. They have all the Specs of thickness and diameter so there is no surprise. Link: https://www.mcmaster.com/products/wa...7%2F16+washers
Ace Hardware or Fleet Farm in my area. The hole in the flat washer only has to be big enough to clear the square portion of the bumper bolt.
If you have a good Ace hardware they carry square hole washers. They are for lag bolts but work well .
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. |
Was in lowes recently hunting for some hardware ( nuts bolts and washers ). In their section where they have the grade 8 hardware in drawers, there's a drawer or three dedicated to automotive and one of the categories was fender washers or similar. They had what you're looking for methinks. -klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
See washer #10. It's a special oval shape and one side is thicker to compensate for the bracket angle. If you don't have them I'd be careful when tightening these two bolts as you could suck in the bumper. Maybe some kind of half shim? On the diagram they are listed as special. I can't believe I kept mine when I disassembled the truck years ago. I'm sure somebody on the forum knows of these special washers.
Yes the #10 washer, I've remember coming across it in my spare bolt containers wondering what that's for everytime .
Thanks all for you help. NGN Nick |
![]() Join Date: Jan 2012
Does anyone have a picture of this illusive #10 washer?
Here's the elusive # 10 washer.
The washer should be flipped over to match bumper. Sorry about that. Last edited by howzzzit; 07-03-2023 at 03:04 PM. |
![]() Join Date: Feb 2009
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring the truck from ground up. With assys, the guide accts for 1000s details, OEM identifications & part numbers, written in short order. 700+ images of assm., illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
![]() Join Date: Mar 2015
Interesting.
ClassicParts is selling these in two styles; "Original style Polished Stainless Steel flat washers with offset square hole." $3.96. "(1934-72) Offset Washer - Zinc-Offset Washer for 1934-72 Chevy Truck $1.50 Somehow I'd wonder if the originals are stainless. Possibly they were sometime in the 38 years of production? Also appears the "re-pops" are flat, not concave to fit the bumper. The thickness, of the, ClassicPart, washer is also not specified. The thickest washer in the McMaster Carr listing was .040". They also have a square hole not round. Although both make sense from a pragmatical standpoint. To keep from damaging your bumper the re-pop washer should somehow be massaged to match the bumper profile. Either by bending the washer or grinding a taper into the washer. Even with the excellent pictures posted by "howzzzit" it is difficult, for me, to identify the profile. Stamping this washer to be thicker on one side would be interesting from a OEM cost prospective. The re-pop could be tapered with a grinder. I a pretty sure my truck is missing this washer. Just another detail that need to check on. Good discussion. Thanks everyone. Last edited by Accelo; 07-06-2023 at 06:52 AM. |
#12 | |
I wonder if they used the bed washers as bumper washers also???
Bed washers have a square hole
For a steel bed floor to frame? I give, why? I know they're carriage bolts, but the head bottoms don't contact the washers, speaking for a 1971.
I believe the original washers are extra thick however, like all or most bed assembly washers. __________________ I'm sure glad this came up. Years ago a seasoned Chevy guy said they were just regular washers. Perhaps he misunderstood. Anyway, I kept them anyhow, and had them finished black zinc. Mine vary, but they seem to serve the same purpose, sorta ![]()
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring the truck from ground up. With assys, the guide accts for 1000s details, OEM identifications & part numbers, written in short order. 700+ images of assm., illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 07-06-2023 at 10:39 PM. |
#15 |
what about using a teflon washer? it seems these could be shaved down fairly easy to replicate the angle desired
'72 C10 Cheyenne SWB North Carolina truck for 50 years, 72k original miles, Medium/Hawaiian Blue, 3 owners - one for 40 years, garaged kept, original: sheetmetal, undercarriage, moldings, glass * * * New - engine rebuild at 65k in 2015, one repaint in 2010, new front bumper, houndstooth seat, carpet, 8 inch rally wheels on 275-60R-15, LED lighting. - Semper Paratus! |
#16 |
howzzzit or anyone else have the ID and OD and a nominal thickness for the washer?
I like the idea of Teflon. I have some round stock here and could easily replicate them in Teflon. Or 3D print them in plastic. I really like the plastic/Teflon idea. Cheers |
#17 |
Well, trying to measure it with my Harbor Freight p.o.s. caliper I get 1 1/2 d x 3/4 id and thickness about 1/8. Sorry I can't get more precise.
#18 | |
#19 |
My digital says 9/64", so 1/8". They get bent up pretty good, so if original, best to put them back the same. On topic, my bumpers are supposed to be ready, their mailbox full. If so I get to drive 500 miles RT to pick them up from Fresno on Wednesday. Go figure they still do triple chrome in Ca., hmm. Word is the gov. more/less restricts it but enjoy the tax income anyhow.
#20 |
Who in Fresno is doing your bumpers? I'm about 90 miles north. Nobody up this way. Had them done in Stockton and it didn't last. They even tried to give me some cheap bumpers in return. Luckily I put my I.D. on the back of each bumper. Make sure you get yours back. Anyway funny thing they are out of business. Why did you choose this place? There are suppose to be good platers in Nevada. What's their name? Good reputation? By the way, the platers are given time to convert to the p.o.s. chrome. Let us know the name and quality of the job. Don't know how one can tell by looking. Had mine chromed and they were storage in my garage for a few years. Looked really good and were never on the vehicle. Developed micro pits in the chrome and there are a couple of areas you can see a hint of copper. This happened in the garage. Probably didn't triple plate. Cost?
#21 | |
I marked the bumpers for sure. Even weighed them as they were. The place in Fresno is called Moreno's Chrome. I've only read positive about them. Just got off the phone, looks like another week out. Cost estimate is 1700-ish. I'll try to remember to report, here. For what worth, assuming my scale is worth a (^^, here are what my original bumpers weigh. The rear was replated once before.
