compression for a LS 1
What kind of compression should a 1999 LS 1 have? I have a couple of cylinders that have 100 and 105lbs, thinking about pulling motor and replacing it.
Re: compression for a LS 1
If you don't get an answer here I check with the folks over on LS1tech.com.
Moderator
![]() Join Date: Jun 2017
"Blower cam" ?
Any long duration cams will drop initial compression pressure. "Normal" numbers would be around 160 to 175 with no more than a 30% variation between highest and lowest numbers. Figures of 100 to 105 etc should really be subject to a leak down test before making any rebuild decisions. ![]() ![]() ![]()
Family and country before all others... 2006 Chevy Silverado (Daily Driver) 2012 Chevy Equinox ![]() ![]() ![]() |
![]() Join Date: Mar 2015
On my LT1, I had over 150psi on all cylinders with a BTR Stage II camshaft.
If your compression is low it's a 90% chance refreshing the heads will fix it. A decent Lt1 will bring about $2500 in my area. Worth repairing if it's the heads. |
