04-06-2020, 01:18 PM | #451 |
Re: 1960-1972 Lowering Block U bolts
Did you notice the dates on the responses directly above your question?
http://67-72chevytrucks.com/vboard/s...&postcount=448 http://67-72chevytrucks.com/vboard/s...&postcount=449
07-08-2020, 12:29 AM | #452 |
Ordered -1" blocks and U-bolt kit for my '68 today
07-12-2020, 12:07 AM | #453 |
Received my 1" lowering kit in the mail today.
Really nice stuff, Thank You. -Russ |
08-03-2020, 11:45 AM | #454 |
Hi Boris, Ordered -1" blocks and U-bolt kit for my '68 today!
Thanks Greasey for the reminder Blake |
09-02-2020, 06:40 PM | #455 |
I just finished installing the 1" lowering block kit and I'm very happy with the outcome. I wanted an equal reveal from the fender to the tire front and back.
It ends up being a 2.5 drop spindle in front with a 4" spring drop + the 1" lowering block in the back. First pic is before and the 2nd pic is after. Last edited by MySons68C20; 09-02-2020 at 06:42 PM. Reason: Missing words duh! |
09-03-2020, 12:12 AM | #456 | |
Insert clever text here: |
05-06-2021, 08:03 PM | #457 |
Got some 2" blocks a couple of weeks ago, they really leveled out my truck out perfectly. I just got done rebuilding my entire suspension and the back was sitting pretty high, these blocks did the trick. I wouldn't hesitate to order these again, the solid aluminum blocks are a lot more confidence inspiring than the other hollow aftermarket ones out there. Here's a few before and after photos.
1968 C20 -> C10 Last edited by BCash; 05-06-2021 at 08:08 PM. Reason: photos |
11-02-2023, 08:24 PM | #458 |
If you're still offering these kits, how much for your 1" kit shipped to Baltimore 21206?
thanks! |
