08-18-2004, 01:08 AM | #1 |
Gentleman Jim Driver
Worst gear ratio EVER!!!!
As you may or may not know, I recently swapped a Goodwrench 350 and TH700R4 into my 1980 GMC Indy Hauler. I've only driven the truck about 300 miles since the first of June or so when I got it done and I've been annoyed since my speedo has been off.
I put a new drive and driven gear in the tranny to match up with my 255/70R15 tires (within .05" of the stock 235/75R15's, or probably closer than one brand to another of that same size...) and what I assumed were 3.07 gears. Ah yes, I used the assume word, and it bit me. I've checked my speedo gear math but always used 3.07 for the rear end ratio since I knew it was higher than 3.42s but didn't think GM was using 2.73s much in 1980 (even though my 84 4WD and 86 2WD trucks BOTH had 2.73s...) Anyhow, I know the only way to know my gear ratio for sure is to pull the cover and read the numbers off the ring gear, so tonight I did that. I was shocked and very dissapointed to see a part number followed by: 16 41 3 80 which tells us my ratio is 2.56 to 1!!! Holy crap! I was shocked when I pulled down 16mpg on my way back from California with a worn out 350 when i picked this thing up, but I gave most of the credit to the TH350C that used to be in the truck. I guess it was the gears. I'm sure they are original gears since the date code matches and there are no signs that the carrier has ever been out of the axle. GM sure made some bad choices in the late 70's and early 80's. With those gears, at 70 mph in OD on the TH700, I'd be running 1450 RPM, thats pretty close to the converter stall speed and if it isn't locked up, it could even be slipping. No thanks, the 700R4 needs all the help it can get to keep from grenading and those terrible gears aren't the ticket. Anyhow, I guess I'm looking for some 3.23 or 3.55 gears now!
Joe '75 GMC Gentleman Jim '84 Chev C10 Short Wide - Super duper plain (manual steering, manual brakes, no dome light, no cig lighter) '85 Chev C10 Short Wide - Super plain Vortec 4.8 4L60E trans also: '81 K30, '83 C30 Crew Dually, '84 M1028 CUCV, '85 M1009 CUCV, another '85 C10 SWB, '89 R3500 Flatbed |
08-18-2004, 01:10 AM | #2 |
Garage Queen Material
i run 3000rpms at 70mph
08-18-2004, 01:21 AM | #3 | |
08-18-2004, 01:26 AM | #4 | |
08-18-2004, 07:59 AM | #5 | |
86 SWB 9.0 LITER T-400-OD 4.11 eaton-4/5 drop Best 1/4 12.51 @112mph no traction |
08-18-2004, 08:00 AM | #6 | |
Happy to be here
I talked to a mechanic that does a lot of transmission work and has done a ton of 350 to 700r4 conversions. He said the 3.08 was the best combo to run on our trucks. He built a 4wd for his daughter with this combo that gets good mileage and has decent power with 31" tires....
08-18-2004, 11:57 AM | #7 |
I have a 350 with a 700r4 too. I was told by the previous owner, who also changed out the rear end, that I have 2.96 gears. Does that sound plausible? I don't remember ever hearing of that ratio.
08-18-2004, 12:03 PM | #8 |
My 1979 Chevy 1/2 ton 4x4 came with 2.56s and some nut put 36" tires on it... Once rolling, things were okay... Getting up there was the hard part!
08-18-2004, 12:09 PM | #9 |
On this truck, I'm going to stick with 255 70R15s they are 29.06" tall which is very very close to what the 235 75 15's were stock. 3.08's would probably be ok too. One thing you have to keep in mind is the steep drop from 1st to 2nd on a 700R4. 3.55's or 3.73s will help keep the revs up closer to the power band on that shift.
That said, I'm not going to be racing this truck so some kind of compromise in gear ratio will be made for economy, especially since the days of $2+ gas seem to be here to stay. |
08-18-2004, 12:20 PM | #10 |
ROCKET POWER!
I'd send you a set of 2.78 gears for a 12 bolt for free but, shipping them to the USA would cost more than they're worth
What did i do last nite? I had a wonderful time, That's what they tell me What did i do last nite? 1979 C-10 shortfleet: Olds 350, Th400, 12 bolt Current project: 1969 Olds 455 W-30, needing a rebuild |
08-18-2004, 12:46 PM | #11 | |
Ughhh, yeah, I think I'll find something a little closer to home. Thanks for the offer though.... |
08-18-2004, 01:28 PM | #12 |
3.08s or 3.42s would be the ticket I think.
I have a 700r4, 350 and 33" tall tires (more like 32" probably) and I think if I had 31" tires it would be perfect. So I would say 3.08s or 3.42s otherwise you will have too high an rpm running 3rd gear while towing. Right now with the 33's and 3.42 gears I turn about 1800-1900 and a couple more hundred would help out some.
1985 Scottsdale Shortbed 4x4 Stout 350 with some "upgrades"-700r4-33x12.5" Mud Tires, Warn 8274-50 winch. 2005 Chevrolet Colorado Regular Cab 2wd 4-banger, 5 speed, Street Pack with 3.73 axle. |
08-18-2004, 01:34 PM | #13 | |
yeller
With a properly equipped truck (matchng gears, tires, and converter), 3.08 gears would be great for highway cruising and mileage...but not soo good for acceleration...if that was what you were after. I am running 4.10's...I will have a helluva time leaving the line w/o spinning, my first gear ratio will be more like 4.56 with the new 700. But my truck is being built for go-fast duties and occasional drag strip fun.
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
08-18-2004, 04:31 PM | #14 | |
driving is in my blood
BTW- why are you not running the lockup?
-78 c10 short/step: 388cid, M20, 5/5 drop, lots more. Playtoy and first vehicle. -98 c1500 x-cab: 5.7L, 17" rims, 5/6 drop, flowmaster, helper bags,NBS rear disk brakes. -02 Suburban 4x4: leveled front -CBR600F4i, CBR600RR, CBR1000RR, and standup skis DISCLAIMER: I cant spell for the life of me. |
08-18-2004, 05:17 PM | #15 | |
The rest of the time you are trading acceleration and probably non-highway mileage. You get the best of both worlds by using steeper gears and an OD trans. The biggest flaw with 700R4s (aside from early reliability issues) is the big gap between 1st and 2nd that was mentioned earlier. If you don't want to lug the engine in 4th locked up, you need steeper gears, just like I will be getting. Oh yeah, I am running the lockup. Even then, it will unlock under high load when manifold vacuum goes away. That will happen when pulling a grade or passing someone without forcing a downshift. Again, by running steeper gears, I will raise my cruise RPMs closer to the efficient power band and will stay away from the stall speed of my converter. |
08-19-2004, 08:59 AM | #16 |
Mudslides 'r my specialty
Destructo,
Are you saying that 31s with a 700R4 and 3.08s in the rear is a good combo? I am afraid it wouldn't lock up on the highway...
Always on the lookout for old cars and parts...(20s, 30s, 40s, 50s, 60s, etc.) http://www.cardomain.com/memberpage/500339 |
08-19-2004, 12:41 PM | #17 |
I am running 28 inch tire with 305 and 3.08 gears. Not bad mileage. I am going to a 700R4 also to get better mileage. I was going to go 350 c.i. but may not.
ElGracho....I would love $2.00 gallon gas. Today it is 85.5 cents per litre here in Ontario. That converts to $3.21 a gallon. Keep blastin anyway!!!!!!!!! Doug |
08-19-2004, 04:22 PM | #18 |
Stepsides RULE
hmmm this thread is very informative. ill throw in my .02 on the comment about GM making bad gear choices.
I'm running my 80 c10 with 305 v8, TH350 tranny, and stock wheels and stock size tires. no idea what my gear ratio is. but its JUST FINE i like having my truck that idles low and climbs up into third real easy as long as i ain't dogging on it. whoever said "its easier on the motor to turn 2000 rpms rather than 3000 rpms", i love you!!! my buddy has a toyota tercel thats 14 years younger than ol red with less miles, but i bet he blows the thing up the way he dogs on his AUTOMATIC by jumping into low 1 and low 2 to rev it up.
1981 Chevy C10 Custom Deluxe Stepside 350 V8, headers, side exhausts, 3-speed auto SOLD 1980 Chevy C10 Custum Deluxe Stepside 305 V8, Edelbrock Performer Intake, Edelbrock 1406 600CFM 4-barrel, TH350C. Bent rod. SOLD 1984 GMC Sierra Classic Longbed 6.2L Diesel SOLD 2009 Kawasaki KLX-250S too many mods for this signature 1999 Honda Accord EX 4-cylinder, 17" Motegi Wheels 215/45/17 Sumitomo tires, Tein S-Tech lowering springs, KYB GR2 shocks, Acura TL 20mm rear swaybar, debadged, blackhoused headlights, Short-Ram Intake Cardomain of the Accord |
08-19-2004, 04:31 PM | #19 | |
With 33's and 3.42s i'm about the same as 3.08s and 31's. The engine does chug and downshift to third on hills though, so some 3.73s and 33's would work best I think and still turn around 2000 rpm on the highway. But 4.10s may be better. I couldn't run overdrive with my bad carb but not with a good carb I can run OD on flat land, and my 700r4 locks up right when it shifts into 4th regardless of the rpm. I have a bowtie overdrives lockup kit, its not factory.
08-19-2004, 05:06 PM | #20 |
ROCKET POWER!
Well, my 79 C-10, Olds 350, TH400 with a diesel converter, 2.78 gears+two barrel carb got around 7 mpg doing 65mph. Did i mention it was SLOOOW. Yeah. REAL slow.
So today i ordered 4.10 gears+a complete overhaul kit for the 12 bolt from Superior Axle, and topped it off with a Powertrax No-Slip. Should make up for the crappy first and second gears of the TH400. I'll be running 325/50/15's in the rear, as soon as i can drop my 468 BB in.
08-19-2004, 05:14 PM | #21 |
www.73-87chevytrucks.com
Not to throw a fork in the road on this, but were are the pics of the Indy!!!!
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
08-19-2004, 09:50 PM | #22 | ||
All I was trying to say was that with a non-overdrive tranny, those 2.xx rear gears aren't bad at all. The 3.07's are too much gear for a non-overdrive IMO even not at 80mph. With my motor I can easly take off from a start as fast as my traction will let me, so anything bigger just dosen't make sence. Of course my 78 is getting at least 4.10's
08-20-2004, 12:04 AM | #23 | ||
I'm really glad to hear other people's experience with this! Oh yeah, I'll get some pics up on my page Chris, give me a day or so. Unfortunately it doesn't look much different than when I bought it except under the hood.
08-20-2004, 12:56 AM | #24 |
If you take a combination of 3.73 gears in a 12 bolt posi rear end, with a set of tires that are 26.5" tall, and a 700 R4 tranny (without lockup) which is getting an RPM of 2500 at 70 Miles per hour. The power curve for a 350 Chevy engine is good from approximately 2100 to 2800. The optimum place is 2300 to 2500 for good acceleration and response. The cruise controls and the transmission are working well at these speeds and RPMs, so that they don't have to shift down on hills or climbs. This in itself will increase dependability and gas mileage. We had a truck with 3:08 gears and a 700R4 that was only getting a solid 12 MPG, after changing the rear end gears to the 3.73 ratio the mileage increased to 14.5 MPG. You guys are talking about running 3000 RPM at 70 MPH, then you definitely don't have an overdrive tranny or your gear ratio is way low. At 3000 RPM, our trucks are pushing 92 MPH; so there is a definite difference in tranny output or rear end gears. (just ask the guys with the Mustangs that can't lose us) The 3.08 combo of gears is good if you don't have an overdrive, but if you do, the RPMs will be to low to get a good RPM for daily driving and your engine will work itself to death. We were getting 1900 RPMs at 70 MPH and we could not get the cruise to work smoothly and not shift down on every incline. The 3.42 gears are not bad, but the RPM is at the bottom end of the 350 power band and the cruise control will still be somewhat inefficient, especially with a tall tire. I drove on 3.42 gears for a long time and the change to 3.73s was worth the money and time. You can do what you want, but I can run with the best of them and still get a reasonable gas mileage (for a 4000 lb truck with a 400+ Hp 383 engine) (Kick A-- and take no names) I understand the thought of $2.00 and higher gas, but if you do anything but drive the highway and haul NOTHING, then you will need a truck. Want gas mileage then buy a small Toyota or Nissan, there is a reason that they exist. I was in California for a period and I do realize that life out there is a struggle of how to get to work. I live 15 minutes from my work place and I drive a truck everyday. My 91 chevy does have a 350 motor and 3.42 gears and with the fuel injection it is not bad on gas. My 84 GMC has a 383 stroker motor and 3.73 gears, but it is carbureted and it gets 15 MPG plus. The difference is the computer in the truck. The 84 lost it's computer long ago to the garbage gods, In California you are stuck with what the "CARB" (California Air Resources Board) tells you to do.
08-20-2004, 12:05 PM | #25 |
Ultimate Diesel Dude
"If you want good mileage, buy a Toyota...."
Don't forget about diesels! My truck with 31" tires, 4.10 gears, and 700R4 gets near 20 mpg! Myself, I prefer the 4.10 gears, but then, I'm also running larger tires than a lot of you. I used to have 3.42 gears and 29" tires, and it was a pretty good combo, but the jump to 4.10's made a huge power improvement. Joe, Running with stock tires and the overdrive, I would go with the 3.42's for max. economy w/good power, or 3.73 for max. power w/good economy. You'll just have to decide which is more important. Casey
Project truck: '81 C/20 converted to 6.2L TURBO DIESEL bored .040", gear drive, 6.5L injectors/pump, custom pistons, custom 4" exhaust, 700R4, 4.10's Daily Driver: '95 K1500 Tahoe, 6.5L TURBO DIESEL, NP241, 4L80E, 3.42's |
