![]() Join Date: Feb 2002
'03 Tahoe Catalytic Converter
I was looking at a 2003 4X4 Tahoe, ex cop car today. It came from out-of-state, [NM], where Cats are not required, I'm told. I hear they are required in AZ, where it would have to be registered.
When I looked underneath, I saw one big muffler, both exhaust pipes fed into, and a single 4'' exhaust pipe out the rear that looked factory. Motor is a Vortec 5.3. Could there be a catalytic converter inside, or would it need to be installed for AZ ADOT/MVD regulations?
Re: '03 Tahoe Catalytic Converter
The cats come immediately off the exhaust manifold on both sides. Often times referred to as the y-pipe. The y-pipe then connects to the muffler. You likely have a cat-less y-pipe on there now.
Install is easy for a DIY-er.
Customization is what you want it to look like -- not what other people think it should look like |
#3 | |
Too many red flags from that seller/truck: -- Door handle D/S was busted and a coathanger wire with a cane loop came out of a 3/8'' hole in door. -- Seat belt clip was stuck inside the plastic retractor. Had to pull it out with multi-pliers. -- Steering wheel tilt adjust handle came off in my hand. -- Dude weighed +300 lbs. Driver's seat needs new springs. ![]() -- Oil Pressure gauge pegged. Dude said it was just loose at terminal on block. ''Easy fix'' he said. -- Radio AM/FM inop. Fuse was pulled he said, ''but it works.'' -- Ad stated 150 K mileage. On email Dude stated 160K. Odometer read 170K actual. -- Ex-police undercover rig. Cops had wired flashing lights into Cyl #3 coil pack. Sometimes, it misses. -- Electric 2WD/4WD selector just pops into 4WD when it wants to. Needs new switch, he said. -- Bronze paint color very sunburned. -- Key slot on barndoors rear, was plated over. -- No license plate. A friend says that's a possible scam... They take out a payday loan on the truck, take the plates off, so Repo Man can't find it, then sell it lowball to a sucker. -- Guy smelled of beer at 4 PM. -- Very sketchy location rendezvous. Guy had me meet him at a bodega/carneceria on the South West side -- large Hispanic/Native American demographic area -- and he's White. ![]() -- Didn't want to call me on my cell phone. Only contact thru CraigsList Emails. -- Late to rendezvous. -- I don't know if it had Cats on a Y-pipe. Seemed like it was dual exhausts into 1 large muffler. I decided to walk away. I could've talked him down from $4000, but I don't have time for a project truck in the 20 year old range. I was looking for a reliable rig. 50 year old trucks, I understand, because I've been driving them 50+ years. Thanks for getting back to me. The quest continues... ![]()
Every 25 years I like to rebuild that 292, whether it needs it or not. Last edited by '68OrangeSunshine; 12-08-2023 at 05:11 PM. |
![]() Join Date: Dec 1999
I would be screwed here In California. Looks like I cannot buy a replacement.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
