Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 12-14-2023, 11:38 AM   #1
NDM
Bucketlist Blazer -Restomod build 6.6liter L8T
Well, I started my project. I bought my 72 K5 about a year and a half ago with plans to do a 2wd swap. I wanted to have an autocross capable rig. Well as you know, a 2wd Blazer is cost prohibitive so I got the white 4wd at a great price in great condition.
I am a huge car stereo guy from way back so I immediately did my audio build and enjoyed working on it until I got a time suck new job. I was able to enjoy the Blazer every now and then but I worked too much. Fast forward....I got laid off a few weeks ago due to a 500 person downsizing (Terrible company earnings report).
So I did what any right minded dude would do. I sold off a bunch of cult classic audio gear to fund my "winter layoff project". Two days ago I bought a 6.6 liter L8T motor and 2wd 6l90E liftout for a steal! I got it for $3k less than market value. The combo has only 25,000 miles on it.
Pausing the post because I am at the gym in the hottub......To Be Continued
NDM is offline   Reply With Quote
Old 12-14-2023, 01:29 PM   #2
NDM
Re: Bucketlist Blazer -Restomod build 6.6liter L8T
Old 12-14-2023, 01:31 PM   #3
NDM
Old 12-14-2023, 01:40 PM   #4
1970cstblazer
1970cstblazer's Avatar
That shall be a beast..
1970 K/5 Blazer CST 4WD, Medium Bronze, 93k ACT. miles, 350, 4 speed, rear positraction, 16.5" x 8.25" HD wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration finally getting close to completion..
1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor...
2017 Sierra 1500 SLT 4WD, Black, 45k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2...
2019 Canyon SLT 4WD, White, 62k miles, 3.6, 8L45, 3.23 LS, 18" wheels
Old 12-14-2023, 01:44 PM   #5
NDM
So the plan is to take the front crossmember from a 84 C20, Convert it to 6 lug to be able t use my Factory rally wheels and do a stock height or lifted 2wd setup. Mostly to get rid of all the leaky 4wd stuff but basically it will stay that way until the day when I decide to drop it down low.
I may still decide to keep 4wd but for now I am just simply annoyed at all the leaks that are involved in the NP205. My beautiful paver driveway that I laid by myself now has oil drips and that really annoys me . I spent an entire summer working on the 20 pallets of pavers.
2wd is just simpler too. The ride should be much better and the parts are sooooo much cheaper too. I simply cannot afford to do a 4wd build on a vehicle that will never be used for much offroad at all. The most offroad that I will ever do is visit my parents property in the AZ desert.
So for now.....Pre-runner 2wd style it is.
I know that the 6l90e will make it soooooo much better with the 401hp and 464 torque. I have a Gen4 6.0 L96 and a 6l90E in my 76 Buick Regal and that thing absolutely rips! It is a very angry car yet can settle down when I want it to be calm. It has QA1 double adjustable coilovers and is so much fun to drive. It is a 17 foot sleeper for sure.
The Blazer will get the same treatment. I am going for something like my old Jeep Grand Cherokee SRT. Low, wicked handling and lots of power.
Well this is the beginning. I will update as I move along.
Old 12-14-2023, 01:48 PM   #6
NDM
I hope so!
I already ordered the badges.
Old 12-14-2023, 02:10 PM   #7
1970cstblazer
The 6.6 L8T displaces 403 CI. Sure has a lot more going for it than the 1977-79 403 Oldsmobile V8.
Old 12-14-2023, 02:16 PM   #8
NDM
Especially after I do an LT5 cam and ported injection conversion. Should be about 550 horsepower.
Old 12-28-2023, 04:20 PM   #9
NDM
I have been dying of indecision with this thing. First off, I keep going back to keeping it as a 4wd but I want to keep the 6 speed tranny. The issue is that I have a perfectly good 2wd 6l90e with 25k miles. I do not want to cut the shaft. Also, I would have to buy the expensive Advance adapter for the 4wd and buy dual driveshafts. That all adds up. I would be then left with a barely used 4wd system that cost alot and still does not solve my ride quality concerns.
Now the frustrating part. I have read a bazillion threads on how to convert to 2wd. That part is fairly simple. The difficult part is that my 2wd crossmember is from a 84 c20. for the life of me I cannot figure out exactly what is needed to run factory height springs but retain my 6 lug wheels. It is very important for me to retain my 6 lug rally wheels. I do not want to run 8 lug or 5 lug wheels. When I am ready to upsize the wheels, I want to keep 6 lug. I just do not understand why it is so difficult to have the exact 8 lug rotors made but with 6 lugs.
I am going to try to track down the ece style 3/4 ton to 1/2 ton spindle if it is still made and run 6 lug 1/2 ton rotors. I have the equipment so I might as well use it. I just wish that there was a simple conversion rotor from 8 to 6 lug. Things like this frustrate a simpleton like me. A simple 8 lug rotor blank could be machined to 6 lugs instead of having to change rotors, calipers pads, etc.
Old 12-28-2023, 04:45 PM   #10
NDM
I think for the moment I may just run the holley terminator x max with the 6.6 and the factory th350. That way I will have the new motor and still will be 4x4. When i am ready, I can decide on which way to go either 2wd/6 speed or 4x4/6 speed.
Old 12-29-2023, 12:10 PM   #11
raggedjim
raggedjim's Avatar
I'm pretty sure you can use the rotors and spindles from your 72 on the 84 a-arms as long as you change the 84 balljoints to 72 balljoints. You may also have to change the tierod ends but not sure about that.
Good luck, Rg
[QUOTE=NDM;9270913Now the frustrating part. I have read a bazillion threads on how to convert to 2wd. That part is fairly simple. The difficult part is that my 2wd crossmember is from a 84 c20. for the life of me I cannot figure out exactly what is needed to run factory height springs but retain my 6 lug wheels. It is very important for me to retain my 6 lug rally wheels. I do not want to run 8 lug or 5 lug wheels. When I am ready to upsize the wheels, I want to keep 6 lug. I just do not understand why it is so difficult to have the exact 8 lug rotors made but with 6 lugs.
I am going to try to track down the ece style 3/4 ton to 1/2 ton spindle if it is still made and run 6 lug 1/2 ton rotors. I have the equipment so I might as well use it. I just wish that there was a simple conversion rotor from 8 to 6 lug. Things like this frustrate a simpleton like me. A simple 8 lug rotor blank could be machined to 6 lugs instead of having to change rotors, calipers pads, etc.[/QUOTE]
Roger
'68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675
'69 ('70?) 2wd Blazer
'70 GMC Jimmy 2wd
'73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203
raggedjim is offline   Reply With Quote
Old 12-29-2023, 01:07 PM   #12
NDM
Good luck, Rg
My 72 is 4wd so I cannot use them.
I wish I had access to someone with a 2wd to test this theory.
If it was not for the fact that I am currently laid off, I would have gone and purchased a bunch of parts to get this figured out.
Old 12-29-2023, 02:03 PM   #13
lolife99
67-72 parts collector,…
lolife99's Avatar
You would have been better off with a c10 crossmember assembly because you would have all the correct steering linkage.
All you needed then was aftermarket 6-lug rotors.
Now you need to change the lower control arms (to the c10 version) and figure out how to get a c10 outer tie rod to fit a c10 spindle. Besides changing to c10 balljoints.
The crossmember itself will still work.
I own a set of the ECE ( 3/4-ton to 1/2-ton) conversion spindles you are talking about but don’t currently want to sell them. I’ll keep you in mind if I do.
Keith
Convert to disc brakes.
lolife99 is online now   Reply With Quote
Old 12-29-2023, 02:57 PM   #14
NDM
Can you get me any identifying marks or part numbers on those spindles? So technically are you saying that it would in fact work if I had those spindles that you have? It seems like with what I already have that these spindles are the exact thing that I need. I could then just change brake components for new stuff and be done.
The issue with changing to all c10 components arms etc is that I might as well sell some of my crap and save up for an entire QA1 setup or something.
I would not mind changing the lower and upper control arms really. I just really want to just get it all figured out so that I can move forward. I just do not have the open budget or time to be able to make mistakes on parts. The shipping delays would seemingly put me into next summer.
Sucks because I have time now but not the big budget. As soon as I find my next position, I will have the budget and no time! FML!!
Old 12-29-2023, 03:07 PM   #15
lolife99
lolife99's Avatar
Here’s the part number for those spindles.
They are really nothing special.
They are standard c10 2.5” drop spindles with the balljoint and tie rod holes that fit the c20 trucks.
Here’s an idea,… buy new stock or drop 73-87 HD spindles (the ones for 1.25” rotors) and have the holes reamed for your c20 size balljoints and tie rods.
Same thing as what I have.
Finding a set of stock height c10 spindles should be easy.
Just make sure they are for the 1.25” rotors, because the aftermarket 6-lug rotors are 1.25” also.
Keith
Old 12-29-2023, 03:09 PM   #16
lolife99
lolife99's Avatar
Any machine shop should be able to ream them for you.
I would have the balljoints and tie rod available to make sure they ream them the correct amount.
Keith
Old 12-29-2023, 03:22 PM   #17
notsolo
notsolo's Avatar
The front axle in your photo appears to be 71-72 the control arms on later trucks had different bushings, and a big flat washer on the end, instead of the hex nut. Maybe someone an verify C 20 were different. I also have some measurements in my build thread that might help.
notsolo is offline   Reply With Quote
Old 12-29-2023, 03:26 PM   #18
lolife99
lolife99's Avatar
I believe only the 1/2-ton 73-87 trucks got rubber bushings.
I think the 3/4-ton and 1-ton trucks still got the steel bushings like the 63-72 trucks.
You can tell it’s a 73-87 front assemble because the rubber brake line bolts to the upper a-arm.
Keith
Old 12-29-2023, 03:43 PM   #19
NDM
Thanks very much....I might even invest in the specific reamer for this purpose.
This is very helpful.
Old 12-29-2023, 03:44 PM   #20
NDM
The guy that I bought this front clip from is very knowledgeable and was pretty sure that it came from an 84 C20.
I will hit up your build thread for sure.
Old 12-29-2023, 03:45 PM   #21
lolife99
lolife99's Avatar
I wish I new the correct size reamer, but I don’t.
It might take 2 reamers.
The c20 outer tie rod is probably a different taper.
You’ll just have to determine that.
Keith
Old 12-29-2023, 06:52 PM   #22
notsolo
notsolo's Avatar
Great looking Blazer BTW...2wd or 4wd, I would recommend driving it with the new motor in it, if you can with least amount of effort. I did the 2wd conversion, with mostly gm parts, cross member, trailing arms etc, sold the 4 x 4 parts. 10 plus years later value wise the 4 x 4 would be worth more IMO...It's your ride and you get to decide on what works best for you. I'm back to working on mine TBI is gone, fixing some 1/2@ss work I had done previously and some other improvements.
Old 12-29-2023, 09:03 PM   #23
raggedjim
raggedjim's Avatar
Sorry, for some reason I was thinking 2wd. Where are you in Illinois? I have lower a-arms from a 86 that you can have if you want to drive to Murray Ky.
Roger
'70 GMC Jimmy 2wd
Old 12-29-2023, 11:39 PM   #24
NDM
I am in the far west burbs of Chicago. Essentially where things turn into corn fields!
The 86 control arms, They are C10 arms or C20?
Funny thing is that I had a young troop that I did a few TDY's with from my unit. He lives in Murray, Ky with his young wife. Good kid.
Old 12-29-2023, 11:59 PM   #25
NDM
Thanks!
I am basically trying to save all the 4x4 parts for just that reason. I know that the market fluctuates a bit. I have been and want to continue to daily drive it. I was looking for a 2wd but the market was bonkers for 2wd $$$$$$. I found this 4x4 and figured I would immediately convert to 2wd and LS swap it. Well I kind of grew to like the height. I absolutely hate the leaks though. My 76 Buick was a leaky bastard originally too but I LS swapped it and did the 6l90e. It does not leak a single drip of anything and I have no regrets. It is fast as hell and with the 6 speed, it is buttery on the highway.
The more I research keeping 4x4, the more I realize that it will cost so much more to keep it 4x4 and do it right. So for now, I will plan to just install the 6.6liter and holley terminator x max with the factory th350 and 4x4 gear. As soon as I figure out the 2wd stuff, I will swap it. If I can figure it out soon, I will go with perhaps lifted 2wd with the 6l90e to keep it at the current height.
I am pretty sure that it will keep me satisfied for at least a few years until I stabilize my work situation and move forward with big changes (Autcross style or Pre-runner style). I can see myself enjoying a smooth buttery ride with gobs of power available.
I have driven mostly 2wd vehicles for most of my life (Minus my military years). I am perfectly happy doing so. One thing is for sure, the resale aspect is not for me. That will only be for those that sell my Blazer after I kick the bucket. This thing is staying with me until I am gone!
