Old 10-24-2022, 04:56 PM   #1
MELUVNOVA
68 k10 mounting questions
Looking to bolt an LS/4l60e into our 68 K10. Can I just use adapter plates that go from the stock v8 engine crossmember/mounts to the block? My crossmember is the early type that uses mounts with one bolt to the crossmember.
Ive looked thru a ton of threads here, still unclear to me on what adapters work and if Im gonna have to buy a complete new crossmember setup.
MELUVNOVA is offline   Reply With Quote
Old 10-24-2022, 05:26 PM   #2
mongocanfly
mongocanfly's Avatar
Re: 68 k10 mounting questions
with adapter plates , clamshell mounts will bolt to the LS, it will drop right in place where the smallblock was.. you can also use plates that have mutiple mounting holes , or sliders..
i used the stock location plates..commonly referred to as ebay plates..on my C30
but im not sure how it will work with your crossmember and the one bolt mount
not sure on your trans crossmember..i changed to a 5spd and had to slide that crossmember back and drill new holes
your also gonna have to do some trans adapting to get the transfer case back to the pass side
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 10-24-2022, 05:55 PM   #3
MELUVNOVA
My plan for the transfer case is to use a 241c passenger side drop, move the crossmember where I need it, then have a couple drivelines built.
I would really like to use adapter plates with the factory crossmember, but really not sure about clearance
Old 10-25-2022, 02:42 AM   #4
Richard
In post #179 of my build thread there is a pretty good shot of 6.2 pan clearance to the aftermarket crossmember. The stock crossmember would have required some work to fit. BTW all the 67-72 K trucks use the one vertical bolt type mounts. Mine now has the newer style.
Richard
Richard is online now   Reply With Quote
Old 01-17-2024, 09:57 PM   #5
MELUVNOVA
Got the 5.3/4l60e/208 combo in the frame. Bought an engine crossmember from EC Fab, worked great.
Wondering what everyone is using for trans crossmembers and front driveshafts? Ive been to driveshaft guys before, would love to bring him a core to work with $$
Seeing a ton of aftermarket crossmembers, but only listed for c10?
Old 01-17-2024, 11:25 PM   #6
suburban99
suburban99's Avatar
I have a 72 K10 LS swapped. Used Dirty Dingo crossmember. As a side note the firewall for the 4x4 is different from the non 4x4. My 6.0 was very close to the firewall. When i swapped the TH350 for a 4L60E I moved the engine forward about 1" and used electric fans.
1962 C10 Longbox LS 5.3 4L60E----Sold$$
2014 Ram 4x4 3500 Laramie Diesel..Momma's truck
2015 Ram 4x4 1500
1997 Boxster.
1972 K10 Custom Deluxe LS 6.0
1950 GMC 3100 S10 & LS swapped
suburban99 is offline   Reply With Quote
Old 01-19-2024, 08:42 AM   #7
MELUVNOVA
What transmission crossmember did you go with? Ours is a k10, Ive only seen bolt in crossmembers for a C10....
Old 01-27-2024, 03:59 PM   #8
derotoreut
Roto Reuter thats the name...
derotoreut's Avatar
I used Pacific Fab/Tilden engine cross member. I did not have to move my stock trans X-member for my 4L60E. Check out my build thread.
http://67-72chevytrucks.com/vboard/s...d.php?t=782232
~ Dan
My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232
My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394
1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt
1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project
"Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977
derotoreut is offline   Reply With Quote
Old 01-29-2024, 01:04 AM   #9
Richard
I also used the Pacific Fab/Tilden crossmember. Maybe a different company now? http://www.pacificfabrication.com/
Have an LSA and adapter from Advance Adapters for the 6L90 to 205. The 6l90 is a bit longer than most trans but new adapter is shorter than stock one. Wanted to keep motor farther back and needed new drivelines anyways. So I needed to move the stock transmission crossmember back almost 2".
AFAIK there is no difference in the 4x4 firewalls. Maybe the 67 trucks are different? Would like to know what the difference is by suburban99.
Richard
Old 01-29-2024, 02:13 AM   #10
Richard
Do not know of any transmission crossmembers for 4x4's. I built a riser/adapter for the stock transmission crossmember to fit the new trans/transfercase adapter. Custom adaptation. No disrespect, but expecting that there is bolt in solution for your situation or combination is maybe somewhat unreasonable. There are details in my build thread on what I made. Had to modify again when tcase was put in. "Custom"
Richard
