#11 | |
![]() Join Date: Dec 2009
Re: Previous owner '68
Myself ![]() I am working on one of my better half projects. I have used Wd-Forty or brake cleaner to soften the undercoating. ![]() About the drilling of those bolts. Here is my detailed process. ![]() ![]() ![]() #1= HSS (High Speed Steel) center drill the Bolt. Link: https://www.grizzly.com/products/gri...its;%20Grizzly Just an Example link. #2= Drill the head of the bolt 25% less than the diameter of the bolt. This gives you 12.5% if you drilled Off Center. Then only drill to a Depth of the head of the bolt. #3= Then take an Impact drill/ air ratchet / air gun and try to tighten them till they break off. #4= If they still spin/ Then I put Vice grips on the nut/ Then step up the drill size tell the head of the bolt goes away.
