01-21-2024, 05:43 PM | #1 |
Active Member
Patina love
My Facebook marketplace buy. Original owner shortbed patina truck. Flushed fuel tank, replace all rubber fuel hose, replaced plugs, set points .019 and I fired right up purrs like a tomcat in a bucket of cream. Going through taillight wiring now as driver turn no workin in the back. I want this. Anyone recommend or have anyone who have used this? That would be a starting height and if not low enough for me I would purchase disc drop spindles for front after |
01-21-2024, 06:02 PM | #2 |
Re: Patina love
I've used WC 3/5 kits on 2 trucks.
Two hints to make this easier on you. Remove the bed and buy NEW ubolts before you start. Remove the front cap to do the front work. The front shock relocators are impossibe to put on without the inner fender being out of the way. You will also need to trim the inners to fit around them. Check out my build thread. Not sure how well I covered it. I might also add that I would probably consider 2" spindle drop and. 2" springs cause a 3" spring drop puts you on or very close to the bump stop rubber. A 4 would be worse.
:My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=807535 1972 K10 swb/1968 Camaro 350/4spd 1955 210 2 dr sedan/1998 RCSB Z71 Last edited by tutone; 01-21-2024 at 06:07 PM. Reason: Added |
01-21-2024, 06:13 PM | #3 | |
Active Member
Re: Patina love
01-21-2024, 06:43 PM | #4 |
Re: Patina love
You can try it, but I'm leary of aything more than a 2" spring drop on the front end. (Maybe I just had bad luck). I didnt need the c notch kit on mine. A friend of mine went all out on his with the 4/6 , c notch and 2 1/2" spindle drop with a 2" spring.
Here is a photo from the side. His tires are the same as mine and we measured wheelwell to ground on both. His is exactly 1" lower on eah end. I can't tell that much difference.
:My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=807535 1972 K10 swb/1968 Camaro 350/4spd 1955 210 2 dr sedan/1998 RCSB Z71 |
01-21-2024, 07:03 PM | #5 | |
Active Member
Re: Patina love
I just took around the block and brakes are ok but will go through and adjust them all. |
01-21-2024, 07:13 PM | #6 | |
Active Member
Re: Patina love
01-21-2024, 07:21 PM | #7 |
Active Member
Re: Patina love
Next on the list. Took her for a spin and the old clutch slips with about half throttle or more. Anyone think it might get better with normal use?
01-21-2024, 07:53 PM | #8 |
Active Member
Re: Patina love
Overload spring removed. Is there any value to selling them? Someone must have installed them after purchase of truck. Cause you can’t run oem bumper mounts with them in place on shortbed. Sure wish I had the patina factory white bumper
01-22-2024, 12:33 AM | #9 |
Active Member
Re: Patina love
Got into the heater tonight. It’s completely $:!:’ up and broken so I got on LMC and ordered up control panel with new dash vents and hoses to defrost. Vacuum out the heater box. Removed fan and cleaned that side out to. Plus I ordered the door window felt kit.
01-22-2024, 12:34 AM | #10 |
Active Member
Re: Patina love
And then this happened. And my finger slipped and hit buy
01-22-2024, 01:04 AM | #11 |
Re: Patina love
I have the same kit from Speedway on my 68. I had to grind a small amount on the passengers trailing arm to get the panhard bar mount to shift over enough to line up the u-bolt holes.
Good luck, Rg
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer '70 GMC Jimmy 2wd |
01-22-2024, 01:11 AM | #12 |
Active Member
Re: Patina love
Thanks for the heads up. Gotta start somewhere and adjust as necessary I guess
01-22-2024, 03:57 AM | #13 |
Re: Patina love
You wont need to remove the front sheet metal with that kit. It shows no front upper shock relocation brkts.
01-22-2024, 10:11 PM | #14 |
Active Member
Re: Patina love
As I dug into the truck yesterday I found that the blower motor was about all that was worth a damn in the heating department. Controls, cables, ducts, def vents were all junk. So Got them ordered through LMC as well as door felt kit and clutch fan for engine. Parts can’t show up fast enough
01-23-2024, 09:27 AM | #15 |
Re: Patina love
Check your linkage adjustment first. But it's probably time to order a clutch too. No, it won't get better.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
01-23-2024, 11:08 PM | #16 |
Active Member
Re: Patina love
Linkage looks good and does have free play. Throw out bearing does make some noise to. O’Reilly auto parts has a clutch, pressure plate, throw out with pilot bearing for 99.99. I have never seen an inline 6 250 flywheel but I take it that it will be surfaceable
01-24-2024, 07:17 PM | #17 |
Active Member
Re: Patina love
Driving truck yesterday and really started driving like crap. Sputters and misses, even died rolling into stop sign. So this a.m. I found the culprit
All taken care of now. Should have removed carb and cleaned in the first place. Oh well. She runs like a champ now. Well, except clutch slipping. I got new one be here tomorrow and I’m taking trans out tonight. |
01-24-2024, 08:14 PM | #18 |
Active Member
Re: Patina love
Trans out.
01-25-2024, 12:30 AM | #19 |
Active Member
Re: Patina love
Pretty deep on the flywheel. Hard to believe someone could screw this up that bad with a 150hp engine😂😂 it is an 11” setup and from what I can see 10”s are the typical for a inline 6 with 11” being listed for 307’s. I don’t plan on running it for anything more than a driver so I opted for the 10”. Will get flywheel turned in the morning and reinstall. Plus’s I got tail seal and 2 u-joints to install |
01-25-2024, 04:16 PM | #20 |
Active Member
Re: Patina love
Word of advice on clutches. Mine had a 11” clutch and from what I could tell most inline 250’s listed a 10”. I went along and brought a 10” kit home and the pleasure plate is to small of a diameter to work on flywheel so here I sit waiting for tomorrow delivery on that 11”.
01-27-2024, 09:58 PM | #21 |
Active Member
Re: Patina love
Speedway 3/5 kit installed. Waiting on some 3 on the tree rubber bushings to tighten shifting up some. Read good article on that here on the forum.
01-28-2024, 12:57 PM | #22 |
Active Member
Re: Patina love
Will be trimming rubber snubber till I get cnotch |
01-28-2024, 10:06 PM | #23 |
Active Member
Re: Patina love
Been driving around all day settling in the suspension. No bottom outs and drives better than I got it. Ordered up an HEI and wires tonight for 87 bucks shipped clutch fan going on after LMC order arrives tomorrow along with all the heater controls and such for heater on inside of cab
01-29-2024, 01:56 AM | #24 |
Active Member
Re: Patina love
Question for all the guru’s on here. My truck had a aftermarket dual knob radio in the dash. There is no way to mount dash speaker, no holes cut in doors and no wiring anywhere to be found. And it is about as base model as you could get. Where can I find a OEM radio delete plate? Are they anywhere to be found?
01-29-2024, 08:58 AM | #25 |
Re: Patina love
Keep an eye out on the sale section here, delete plates pop up from time to time.
Looking good!
