Old 03-06-2024, 12:05 PM   #1
OKGMC4
OKGMC4's Avatar
IMPOSTER! ( or hey guys I got a little jimmy!)
I already had a build thread on this one but I am changing direction so wildly that I need to start over. I realized almost none of my previous work will be reused and it will be easier to start fresh. I got a 69 c10 for free about 8 years ago. It was a long bed, inline 6, wore out truck but it had a title.
56 GMC BUILD THREAD:
http://67-72chevytrucks.com/vboard/s...d.php?t=368649
69 long bed Chevy turned 67 gmc jimmy roadster:
https://67-72chevytrucks.com/vboard/...d.php?t=851167
OKGMC4 is offline   Reply With Quote
Old 03-06-2024, 12:08 PM   #2
OKGMC4
OKGMC4's Avatar
Re: IMPOSTER! ( or hey guys I got a little jimmy!)
I cut 15 inches out of the frame in front of the wheels. 6 behind. Rather than doing a short bed, I wanted to build a unibody.
Old 03-06-2024, 12:12 PM   #3
OKGMC4
OKGMC4's Avatar
But the roof panel had ridiculous rust inside. I kept fixing spots but more just popped through. I had already chopped the roof 1” and shaved the drip rail. I think that made it worse. Buying new inner and outer panels would be expensive and I’d have to modify new panels to fit the modified roof so I just made a new plan. Remove the roof.
Old 03-06-2024, 12:17 PM   #4
OKGMC4
OKGMC4's Avatar
So I’m going the blazer roadster route. But it’s been changed to a gmc clip so it would be a jimmy. And I removed the bed, shortened the frame another 8” (for a total of 29” shorter) and shortened the bed as well to get blazer wheelbase. That’s why I’ll have a little jimmy. I’ve seen blazer roadsters before but not a gmc version. The reason why I call it the Imposter now is because it’s not a 69 Chevy long bed anymore. It’s disguised as a 67 gmc jimmy.
Old 03-06-2024, 12:20 PM   #5
OKGMC4
OKGMC4's Avatar
Tailgate is modified and dash is a 60-62 c10 dash. I’ll post more details when I get a chance.
Old 03-06-2024, 12:54 PM   #6
CKfan
Interesting ideas. Looks like some nice metal work.
CKfan is offline   Reply With Quote
Old 03-06-2024, 01:46 PM   #7
OKGMC4
OKGMC4's Avatar
Using the 12 bolt with 3.73 but put a new Eaton limited slip in it, moser 5 lug axles, and a Wilwood disc kit. Front has Wilwood D52 calipers on drop spindles for 73-87 trucks. I wanted rubber bushings, heavier duty ball joints, and thicker tie rod connections.
Old 03-06-2024, 01:52 PM   #8
OKGMC4
OKGMC4's Avatar
I originally raised the whole bed floor 6” so I’m leaving that. I welded in a notch that sits under the floor about 3/4”. Going to bag it, was a static drop truck. Anyone need drop springs? lol Tank is a poly Tanks Inc unit for late 40s ford. It won’t rust, price wasn’t bad, and it fits.
Old 03-06-2024, 01:55 PM   #9
OKGMC4
OKGMC4's Avatar
Doors got bear claw latches
Old 03-06-2024, 01:58 PM   #10
OKGMC4
OKGMC4's Avatar
High hump to clear 4l60e and cleaning up the firewall a little.
Old 03-06-2024, 02:12 PM   #11
OKGMC4
OKGMC4's Avatar
Wheels are Vision 143. 20x8 and 20x9.5. I’m going with 245 40 on the front and 285 35 in the rear.
Old 03-06-2024, 07:42 PM   #12
raggedjim
raggedjim's Avatar
Nice work, I'm going to have to check your original thread.
I like the jimmy idea! Rg
Roger
'68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675
'69 ('70?) 2wd Blazer
'70 GMC Jimmy 2wd
'73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203
Ideas - https://67-72chevytrucks.com/vboard/...d.php?t=851743
raggedjim is offline   Reply With Quote
Old 03-06-2024, 09:22 PM   #13
OKGMC4
OKGMC4's Avatar
The axle won’t push up all the way. Tires were hitting inner fenders. Cut em in half and moving inside lip in 1.5” gives clearance, but tires still hitting outer edge now. More cutting in my near future.
Old 03-07-2024, 12:15 PM   #14
wpsharpshooter
Wow, This is going to be a sweet build... Please keep the post updated!
wpsharpshooter is offline   Reply With Quote
Old 03-07-2024, 07:49 PM   #15
nicklear36
nicklear36's Avatar
More info on the latches?!?
nicklear36 is offline   Reply With Quote
Old 03-08-2024, 06:01 AM   #16
OKGMC4
OKGMC4's Avatar
I did those about 7 years ago. At the time I wanted to change door handles and felt I needed bear claws to operate them. I had to cut big holes in the door and door jamb and weld a bunch of 18 gauge sheet metal in to get them flat enough to install the latches. I was just guessing but they turned out ok other than maybe how close the strike ended up to the weatherstrip channel. I have changed the plan a couple times since then but it’s way easier to leave them in than to go back stock. The only other photos I took are what I started with. I should probably try to get a chunk of rubber on that rail to make sure the latches operate with the weatherstripping.
Old 03-08-2024, 10:43 AM   #17
OKGMC4
OKGMC4's Avatar
Just realized I haven’t posted my drivetrain plans. I was going to rebuild a 5.3, but built a 6.0 I got with a broken crank. Then I put that engine into my 56 gmc. Then I was going to turbo the 5.3, but all the turbo stuff is now on the 6.0 in the 56 running 10lbs of boost. (Yes, it is fun!) I’m just going to run the 5.3 as is. It’s a 2001 engine with 85K miles and has only been opened to swap the cam to an LS1 Camaro cam I got for $25. Runs smooth and used to get 18mpg in my 56. Going to make it a cruiser, don’t need a lumpy cam or 600 horsepower. A looong time ago I bought some BH custom designs engine covers. Will need to change color scheme but will likely use these as they go with my dash and tailgate treatment.
Old 03-11-2024, 11:23 AM   #18
fatbass
fatbass's Avatar
What you're doing to this truck is probably illegal in 15 states LOL.
Subbed!
'71 C/20 350/T350.
fatbass is offline   Reply With Quote
Old 03-11-2024, 11:26 AM   #19
OKGMC4
OKGMC4's Avatar
Subbed!
You might not be wrong!
Old 03-13-2024, 05:49 AM   #20
72 tigger
72 tigger's Avatar
Nice fab work!
Thanks for the updates
71 C10
72 K20
72 K10 Super
Kirk
72 tigger is offline   Reply With Quote
Old 03-16-2024, 04:10 PM   #21
OKGMC4
OKGMC4's Avatar
I originally wanted a flush windshield so I modified the cab to fit the glass with no rubber seal. I’ll still urethane the glass in but I’m working on capping the pillars and deleting the weatherstrip tab down to the door. I filled the cowl in a long time ago but now I’ll need to delete the wipers as well.
Old 03-19-2024, 04:37 PM   #22
OKGMC4
OKGMC4's Avatar
Attached what was left of the cab back to the bed floor. Need to pick up a sheet of 18 gauge to make the side panels.
Old 03-19-2024, 06:04 PM   #23
CanadianNascar
CanadianNascar's Avatar
Wow, awesome workmanship, loads of man hours.
Insane build, dash, unibody, engine, windshield frame, bed rails, tailgate, insane!!
Your last pic, rear bed floor looks high, is that due to tubbed/wheels/low rider?
CanadianNascar is offline   Reply With Quote
Old 03-19-2024, 07:18 PM   #24
OKGMC4
OKGMC4's Avatar
Thank you! My bed floor is raised 6 inches. I knew I wanted to lower it but I’m actually going to bag it lower than I originally thought. That worked out since I ended up putting in a notch and it’s covered. I’m mounting the air tank to the back of the notch under that bed floor to take advantage of the space.
Old 03-27-2024, 04:31 PM   #25
OKGMC4
OKGMC4's Avatar
I didn’t have seating so found some today at the salvage. Place had a handful of square bodies and one 68 c10 but no seats. Found one in a 1980 Ford for $50 that I can make work. I originally wanted buckets but now that I’m going topless I think it would be nice to sit 3 if I want. The pattern I have planned it had to be a flat bench, no split benches or armrests.
