Old 03-09-2024, 01:03 AM   #1
Luke87gt
1969 250 i6 soft fuel line size
Hi all, I’m going to replace the soft rubber fuel line that runs between the tank hard-lines and the fuel pump on my 1969 250 i6. There is a stretch of soft line that’s maybe 18inches long - really old and brittle on my truck.
Before I order, I just wanted to confirm what was the oem softline size? Can anyone confirm?
Luke
Luke87gt is online now   Reply With Quote
Old 03-09-2024, 01:53 AM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: 1969 250 i6 soft fuel line size
Luke
I6 is 5/16" ID. Small block and big block are 3/8" ID. Any auto parts store should have it.
Leon
Old 03-09-2024, 02:18 AM   #3
Luke87gt
Thank you for the confirmation! I thought it was 5/16”
So you’re saying that even i6 and v8 hardliners have different diameter?
Gas tanks are identical however?
I’m asking because at some point I may want to do a v8 swap.
Old 03-09-2024, 02:44 AM   #4
oneshotkyle
Active Member
Inline 6 gas 5/16 diameter hard lines as well as a specific 5/16 flared fitting at the sending unit
All v8’s have 3/8 sending unit to carb
oneshotkyle is offline   Reply With Quote
Old 03-09-2024, 05:27 PM   #5
pjmoreland
pjmoreland's Avatar
I believe V8s with a two-barrel carb also had 5/16 line. That's how my '68 was.
pjmoreland is online now   Reply With Quote
Old 03-09-2024, 09:49 PM   #6
Luke87gt
That’s helpful
How much power will a 3/8” line support before it becomes a bottleneck?
Old 03-09-2024, 10:26 PM   #7
Steeveedee
Who Changed This?
Steeveedee's Avatar
Smart money would be to buy the sender with the 3/8" line if you are replacing it, and use an adapter to reduce the line the rest of the way. No point in buying things twice, and an adapter is cheap. FWIW, I put a 4 barrel carb on my '64 Malibu with a 283 and a powerglide trans. Same 5/16" fuel line got me to 120 MPH. How fast and quick do you want to go?
~Steven
Simi Valley, CA
Old 03-09-2024, 11:56 PM   #8
MikeB
MikeB's Avatar
That's true. My 69 still has the OE 5/16" line that came with its 307. It was enough to support a 383 revving briefly to >5,500 RPM, and maintaining 2,300-2,500 RPM on freeways.
However, GM must have had a good reason to use 3/8" line on 4bbl engines, because they typically reduce costs wherever they can.
Mike
1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes.
1982 C10 SWB -- sold
1981 C10 Silverado LWB -- sold, but wish I still had it!
1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
