Old 09-09-2023, 01:33 PM   #326
Joe Pass
Joe Pass's Avatar
Re: A '62 has to get back on the road
That's really cool.....
Joe Pass is offline   Reply With Quote
Old 09-09-2023, 04:17 PM   #327
Grizz1963
Grizz1963's Avatar
Originally Posted by Braunschweiger View Post
For the Campertop we got a Campingbox that I widened for more convenience,
but it can still be pushed together.
The box is only attached with tension straps.
My Wife still sewed Curtains
The box and Campertop can be removed and dismantled in just under an hour.
The camping weekends can now come.
That is neat.
Multipurpose is the best way.
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside
MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger
IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE.
Grizz1963 is offline   Reply With Quote
Old 10-27-2023, 09:57 AM   #328
Braunschweiger
Played a little today and turned the bumper around.
I removed the Driveshaft to swap the new center bearing for another one.
I have a humming noise up to 70/80 km/h, approx. 43-50mph, above that it's quiet.
I hung the middle bearing lower with washers to test it and it got better. Now one from Iveco (This is from a light Italian panel van) is installed, which is much firmer in the rubber suspension. I already have a spacer there to test the position of the Driveshaft.
Greetings Harald
My 62 build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=829782
Braunschweiger is online now   Reply With Quote
Old 10-27-2023, 10:31 AM   #329
66C10LB
Good thinking to try changing the centre bearing. Do you think that the manufactured reproduction of the original centre bearing is inferior quality compared to the original?
66C10LB is offline   Reply With Quote
Old 10-27-2023, 10:39 AM   #330
Braunschweiger
The currently installed bearing was new, but the driveshaft was hanging down in the rubber, everything was totally soft.
The other new bearing I got is much stronger and will guide the driveshaft better, I hope.
The quality of today's rubber products does not come close to the original parts
Greetings Harald
My 62 build thread
Old 10-27-2023, 01:15 PM   #331
pdxhall
pdxhall's Avatar
I like it less slammed. While I like the camper boxes, I can't see covering up nice bed work.
Sanity'66
http://67-72chevytrucks.com/vboard/s...d.php?t=515110
Long bed, Fleetside, Small back window
I've Done So Much, With So Little, For So Long, That Now I Can Do Anything With Nothing.
pdxhall is offline   Reply With Quote
Old 10-27-2023, 03:42 PM   #332
Braunschweiger
I agree with you about the camper top, but it can be set up for weekend vacations or meetings within an hour, which I think is nice.
Greetings Harald
My 62 build thread
Old 11-06-2023, 10:07 AM   #333
Braunschweiger
Today we got a small motorcycle from 1961 for a friend, 50cc and 5.4 HP,
his dad rode it in the 60s, He was already a cool kid back then,
great memories.
The Driveshaft goes to the Driveshaft Shop this week and is overhauled.
Let it run jacked up and I could see the second part of the wave going back and forth. Bumper is upside down.
Greetings Harald
My 62 build thread
Old 11-06-2023, 10:42 AM   #334
Joe Pass
Joe Pass's Avatar
Nice update
Old 11-06-2023, 04:52 PM   #335
Grizz1963
Grizz1963's Avatar
I also bought a 67 onward bumper for my truck, years ago.
I much preferred the look.
Cool bike, but 50cc is not enough for me.
Old 11-07-2023, 03:56 AM   #336
Braunschweiger
We are now a group who have a lot of fun with the little things.
When I was 16 years old, my buddy and I rode bikes like this via Marseille, the whole Cote Azur to Monte Carlo and over the Maritime Alps and Switzerland and back again,
when you're young you do things that others say you can't do.
Greetings Harald
My 62 build thread
Old 12-03-2023, 01:14 AM   #337
Grizz1963
Grizz1963's Avatar
I wanted to ask before Harald
You do not have a red historical plate on the truck.
What do you need for that?
Or are you not bothered?
Old 12-03-2023, 04:46 AM   #338
Braunschweiger
Yes, the “H” at the end of the license plate stands for historic vehicle, even for trucks. Many people drive the old pickups with truck registration without an "H", so the tax is based on weight and the tax is around €165 per year and you have a little more freedom in terms of construction. Since everything was approved for me, I also received the "H" and could also use it to drive into the environmental zones of the cities. The “H” then costs €192 per year.
Greetings Harald
My 62 build thread
Old 12-04-2023, 01:41 PM   #339
Braunschweiger
Actually I just wanted to replace my broken Pinion yoke, the join was running to the sides and wasn't guided cleanly and because I also have humming noises, I immediately got an overtaking kit for the differential.
The differential has been overhauled before.
The differential also came out of the case very easily, which surprised me.
On the Pinion the bearing behind the yoke was broken, all other bearings were undamaged and running cleanly.
Pinion was assembled with a new crush sleeve and new yoke, the crush sleeve was broken and the preload was set to 19 inch pounds, a stupid job under the truck.
But the carrier has 0.20mm(0.00787inches) axial play, which is far too much, it is supposed to have 0.010 preload, backslash is also too much at 0.45 (0,0177inches).
I first ordered shims for the carrier and a solid spacer for the Pinion and will probably have to readjust it.
Greetings Harald
My 62 build thread
Old 12-19-2023, 11:04 AM   #340
Braunschweiger
Well, replacing the Pinion yoke just now turned into an overhaul,
a Pinion bearing was broken, the contact pattern on the differential wasn't okay
and there was no preload on the carrier, so everything was new.
Instead of a crush sleeve for the Pinion, I installed a solid sleeve and re-calibrated everything.
Greetings Harald
My 62 build thread
Old 12-20-2023, 05:36 AM   #341
Grizz1963
Grizz1963's Avatar
Excellent work.
I would not know what to do or where to start.
This sort of work always just makes me smile and thank God someone knows how because I have no clue.
Old 12-20-2023, 10:52 AM   #342
Braunschweiger
Thank you, i appreciate your answer.
I'm not satisfied yet, I also picked up the overhauled driveshaft today and put everything together.
Did a test drive and I find the differential runs rough.
From 55-60mls it's quiet. I need some advice from you.
What did I do: the Pinion got new bearings and was assembled with a solid spacer and achieved 19in-ibs as pre load and the carrier also got new bearings,
the backlash was set to 0.009 in. I thought the bearing image was okay.
It's an 8.5 10Bolt axle with 2.41:1 locking from 1978.
I would be happy if you could help me with this, thanks.
P. S Here are the pictures from Drive and Coast
Greetings Harald
My 62 build thread
Old 12-24-2023, 06:42 AM   #343
Braunschweiger
I wish everyone a merry Christmas
and that your projects don't take too long.
Greetings Harald
My 62 build thread
Old 12-24-2023, 06:52 AM   #344
Grizz1963
Grizz1963's Avatar
Merry Christmas Harald.
Thank you for your wishes.
I trust you and your family will have a wonderful time.
Old 03-24-2024, 09:28 AM   #345
Braunschweiger
Update on my rear axle, I looked at the bearing pattern again and came to the conclusion that the pinion is still too low,
I corrected it and am now happy.
Some of the noises are gone, the other noises were still there,
I jacked up the truck and ran it without wheels and brake drums,
I am now going to replace the wheel bearings, why didn't I replace them at the same time?
I'm an idiot.
I will use the repair bearings.
Greetings Harald
My 62 build thread
Old 03-24-2024, 01:28 PM   #346
Grizz1963
Grizz1963's Avatar
Technicallities beyond my ability and understanding
Good luck.
Old 03-24-2024, 04:03 PM   #347
SkinnyG
SkinnyG's Avatar
That looks like a very good pattern.
Are they aftermarket gears? Some are just noisy.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, boosted-LS
1977 Silverado: Shortboxed & dropped, potato-potato
V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag
Lotus Super 7 Replica: Scratch-built street-legal rollerskate
SkinnyG is offline   Reply With Quote
Old 03-25-2024, 03:02 AM   #348
Braunschweiger
This is an original GM differential from a 1978 Pontiac Firebird with a 2.41:1 with Limited Slip.
It was a little neglected, but drives well behind a TH350.
Greetings Harald
My 62 build thread
Old 03-25-2024, 09:01 AM   #349
Braunschweiger
Some of you will remember the Model A that I am now building.
It has a ragtop from Legacy which I have now fitted
and the 4Banger is at the engine builder.
Behind it will now be a 4-speed gearbox from a Volvo.
I got the gearbox at the weekend.
The torque pipe will remain.
A Model A from England has already been built like this, here is an example photo.
And the parts for it are available here in Germany.
Greetings Harald
My 62 build thread
Old 04-05-2024, 10:51 AM   #350
Braunschweiger
I have now installed new axle shafts with new bearings.
I initially wanted to use the repair bearings, but that was a bad idea.
I assume that because of my limited slip differential I couldn't put the C-clips in, or only with force, but the C-clips would never have come out again.
So I stopped and changed to new axle shafts.
Now the C10 runs without rumbling or vibrations.
Greetings Harald
My 62 build thread
