03-25-2024, 12:39 PM | #1 |
front tires for 52
Im getting my 52 3600 back on the road after 6 years sitting in the barn. It needs front tires. I have some dodge truck 16X6 wheels that clear the tire rods. looking for a 7.00X16 steer type tire look for the front. was thinking of 215/85/16 size tire. Any one have any recommendations? I want to keep the stock look. found some Mastercraft courser hxt that have the right look for $150 each.
72 GMC SWB 6.2 diesel 4spd 3.07 |
03-25-2024, 01:29 PM | #2 |
Re: front tires for 52
I don't know the brand but a 215/85/16 should be right at 30.4 inches tall.
As long as the Dodge wheel center holes fit the Chevy hub. I always get mixed up on the center hole thing on Chevy, Dodge and Ford 8 lug wheels. I've carried a Ford 16.5 wheel and tire off my mom's 77 F250 (that I drive all the time) on my 71 GMC 2500 and that works. Tire size dot com has a tire size calculator https://tiresize.com/calculator/ and click on the tire comparison calculator https://tiresize.com/comparison/ and you can compare two tire sizes side by side. Pretty useful stuff when you are wanting to see the diameter and width of a tire you are thinking of running or want to compare two tires side by side. I did my 255/60/15 compared to a 255/35/20 yesterday when someone was asking what would fit under the rear of an AD and those tires are the same height and width with 5 inch different rims. I'd say as long as you are happy with that tire we are happy.
Founding member of the too many projects, too little time and money club. My ongoing truck projects: 48 Chev 3100 that will run a 292 Six. 71 GMC 2500 that is getting a Cad 500 transplant. 77 C 30 dualie, 454, 4 speed with a 10 foot flatbed and hoist. It does the heavy work and hauls the projects around. Last edited by mr48chev; 03-25-2024 at 01:37 PM. |
03-25-2024, 01:31 PM | #3 |
diamond back tires gets a lot of praises from the full restoration guys that love the stock look but want a somewhat modern tire and make it a driver. see them mentioned all over the forums here and others.
lots of tire discussion and even tech tips in the tech tip section will help you out as well. |
04-03-2024, 10:02 AM | #4 |
Go with the Mastercraft HXT. That's what I run on my '95 Dodge 3500 and two gooseneck trailers, 235/85/16. Between trucks and trailers have over 250,000 miles on the Mastercrafts with no complaints. I usually change out the truck tires at around 50,000 miles since it often tows heavy and wears out the rears. The trailer tires we change at the 5 year mark.
I'm running HXT 215/85/16s on the '51 3600 since 2015 for about 25,000 miles with no issues. Good Luck, RonR
1951 3600, stock 216, T5, 4.10 Eaton Rear 1953 Farmall Super A 1970 340 Duster 1990 Miata with 5.0 Mustang GT drivetrain= FUN!!! |
