03-07-2024, 08:58 AM | #26 |
Re: Borgeson Steering Box
Hey guys. I installed a new Borgeson steering box and rag joint. I centered the box as directed and installed. I turned the wheels left and right and noticed that the left turn is significantly sharper than the right. The wheels were in the same location as when I pulled the pitman arm. I removed the pitman arm and attempted to rotate it to compensate and find a closer center but it can only be rotated in 90 degree increments. And 90 degrees is way too far causing clearance issues with everything else down the line. I know the steering box is centered as it has that tight sweet spot in the middle. I don't think rotating the steering box back to the right before reinstalling the rag joint would be a good idea. Does anyone have any suggestions? Thanks for any help.
03-07-2024, 11:21 AM | #27 | |
03-25-2024, 02:01 PM | #28 |
I'm not sure about Alderan, but I purchased one and yes, there is an 1/8th gap between the frame and the gearbox. I called Borgeson this morning and they said yes, they had a few issues with that, . They suggested that I shim it out to make it fit.... I'm not totatly opposed to shimming it based on thoughts from the group. However, it's ridiculous to have to shim a brand new $500 part to make it fit, maybe I'm wrong. He said return it if I wanted a refund. Not sure what to do here, thinking about going to a redhead. Thoughts?
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 03-25-2024 at 03:07 PM. |
03-25-2024, 02:23 PM | #29 |
That 1/8" gap is why I went to town with a grinder on mine. I probably voided the warranty by doing that, but I wasn't willing to use spacers. I would have gone with a Redhead if I had known about this issue ahead of time.
03-25-2024, 03:12 PM | #30 |
I agree on knowing ahead of time, I wouldn't have either. Now I'm debating on going through the hassle of sending it back and then ordering a Redhead. Why did you choose grinding over using spacers? I posted pictures of mine.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
03-25-2024, 03:16 PM | #31 |
Mostly, it just would have bugged me having spacers there from an aesthetic standpoint. It's probably a small enough shift that it wouldn't have a significant impact on the steering geometry.
03-26-2024, 12:57 PM | #32 |
I personally would send that back and get a Redhead, which I have and love btw. But if the Redhead came like that I would have sent that back too. That is unacceptable.
03-26-2024, 02:00 PM | #33 |
Three years ago, I installed power steering on my '71, where previously there was none.. I installed a Cardone reman gear box per their instructions.. I've had absolutely zero problems with it... Cost me less than $400 for everything including gear box, pitman arm, idler arm, pump and hoses....
03-27-2024, 03:18 PM | #34 | |||
I had an AGR box on the truck to begin with and the only reason I had to replace the box is that while doing my engine swap, I needed to turn the wheels. As I was turning them, I heard a pop. I thought it was something in my tilt column, but it ended up being something inside the AGR box . Does anyone know if they sell a rebuild kit for the AGR boxes? Are they even still in business? I couldn't find their website
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 03-28-2024 at 01:02 PM. |
03-28-2024, 10:41 AM | #35 |
I have a 1971 blazer 4x4 and a 1975 K10. Eventually I will replace both. I learned that Cardone and others are using the same number for a 71 blazer and a 75 K10. They said luck of the draw for what you get. Is there an additional number at the end for example 3L or 4L on the case that would tell you the difference. Thanks
03-28-2024, 12:02 PM | #36 | |
Been awhile since I've shopped for a steering box. I have an older AGR box and pump on one of my Jeep CJ's, and the pump went out a while back and I haven't gotten around to fixing it yet, so it's been sitting. |
03-28-2024, 01:02 PM | #37 | |
04-01-2024, 12:52 PM | #38 |
04-06-2024, 09:16 AM | #39 |
AGR is straight trash, Borgeson is the way to go.. I have had zero issues with mine in my 66.
1966 C10 "Mary" 1972 C10 Cheyenne "Betty" https://67-72chevytrucks.com/vboard/...d.php?t=847364 1976 C35 Sierra Grande "Mr. Harvey" 1979 C10 Silverado "The BIG TEN" https://67-72chevytrucks.com/vboard/...d.php?t=841339 1982 C10 Silverado "Lucy" C10 Club Texas -HMIC |
