Old 11-17-2023, 09:21 PM   #276
65Custom
Re: 65Custom Build Thread
Set seat in the truck to check steering wheel location and seat mounting
My Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=366677
I must be
65Custom is online now   Reply With Quote
Old 11-18-2023, 12:06 PM   #277
f66
Junior Member
f66's Avatar
I really like your dash modifications. I would like to incorporate that in my Truck.
U.S. Army Retired and Combat Veteran
Current serving DoD Civilian
1966 C20 Custom Camper Saddle 327 Automatic
1962 C1 Corvette Black/Fawn 327-300 4 spd
1966 C2 Corvette Silver/Black 327-350 4 spd
f66 is offline   Reply With Quote
Old 11-27-2023, 09:55 PM   #278
65Custom
I decided to go with coolc10's reproduction AC dash Vents rather than trying to emulate it, plus it will be more original looking.
My Build Thread
I must be
Old 12-04-2023, 04:24 PM   #279
65Custom
fitting the AC vent, the template wasn't an exact match so it needed a little adjustment to center it and used the vent itself to mark the mounting holes for the screws.
Also fitted the AC evaporator to make sure the cubby will fit, looks I need to make some adjustments to the cubby depth and one of the defrost ports. I will need to cut off one port and blocked it off to make clearance and use a Y connector for the defrost hose to defrost vents
My Build Thread
I must be
Old 01-13-2024, 06:55 PM   #280
65Custom
A little update not getting much done things have been busy, but have gotten the backup lights mounted, ground down the welds between the firewall and cowl and have put in all the seat belt mounting, getting down the last few things before the bed and front end go out for sand blasting.
My Build Thread
I must be
Old 01-31-2024, 09:19 PM   #281
65Custom
Took off all the brackets in prep for installing the new suspension and changed course on the dash extension, changed back to the first idea the filled center wasn't turning out as expected.
My Build Thread
I must be
Old 03-26-2024, 10:37 PM   #282
65Custom
A little more progress dash extension is mostly complete, a few little touch up things needed the cubbies are not mounted at the top yet, all the welding is finished on the dash extension, assembling the rear suspension spaced the trailing arms back 1" and few other things tidied up. Getting closer to the finish line.
My Build Thread
I must be
Old 03-26-2024, 10:50 PM   #283
65Custom
AC vents finished, and working on power door locks have a proto type ready, next is to figure out how to get the power door actuator to operate the door lock/un-lock
My Build Thread
I must be
Old 04-07-2024, 03:22 PM   #284
65Custom
All the body panels are out for sand blasting and an epoxy coating, the rear end is installed and the front crossmember is removed for a new front cross member and suspension.
My Build Thread
I must be
Old 04-14-2024, 12:18 AM   #285
65Custom
fitting the front crossmember in it's new home, will be relocating it forward around 1 inch to help center the tire in the wheel well. This should also give the truck a better ride with the rear also shifted back 1 inch and the front crossmember forward 1 inch with a new 117 inch wheel base an overall 2 inch gain, should help get some more weight off the front and give the truck a better weight bias.
My Build Thread
I must be
Old 04-14-2024, 01:05 PM   #286
Grounded63
Is the engine staying in the stock location. And, only the crossmember/suspension is moving forward ?
Because, if the engine/trans drags forward with the cross member. And the rear moves further away. It will actually be worse.
Grounded63 is online now   Reply With Quote
Old 04-14-2024, 11:25 PM   #287
65Custom
The plan is for it to stay in the stock location or as close as possible, moving it forward with the crossmember would cause too many other issues with clearance for accessories & fan & radiator etc. Keeping it in the stock location should also help with the weight bias keeping the engine weight as close to the center of the truck as possible.
My Build Thread
I must be
Old 04-20-2024, 10:45 PM   #288
65Custom
Front suspension is installed still have to install the front & rear sway bars. the rear sway bar needs custom mount brackets due to the heavy duty axle housing, The housing extends out further, it has shorter axle tubes than the std housing and the sway bar mounts sit right where the tubes are welded and so a stepped mounting bracket is needed, so another custom piece needed to make it all work together
My Build Thread
I must be
Old 04-20-2024, 10:49 PM   #289
65Custom
rear sway bar mount bracket
My Build Thread
I must be
Old 05-04-2024, 10:52 PM   #290
65Custom
We set in an engine to test fit everything and it looks like we will have to push it back, as it is right not it is about a 1/2 in front of the stock location. The front cross member is 1 inch forward but when installing the engine mounts first install as the instructions pushed the engine even more forward so we were able to flip sides and bring it back a 1/2 inch.
It really looks strange with all that space between the firewall and the back of the engine.
Probably will have to run a low profile valve covers (hope I can do that as I want to run a good set of roller rockers ) and also modify the firewall to be able to set it back more than it is right now, I'm not sure right now how far back we can go because the 4l80e has to also fit in there and pushing that back will surely have some interference somewhere, I believe it will be on the seam between the firewall and foot well. I may have to cut that off and weld it up to gain that 1/2 inch to clear the trans but we need to get a empty case to test fit it. So just to get the engine as far back as we can to get it as far behind the crossmember as possible there will be more modifications.
My Build Thread
I must be
Old 05-16-2024, 09:41 PM   #291
65Custom
All the body parts are back from sand blasting with a fresh coat of epoxy.
My Build Thread
I must be
Old 05-16-2024, 11:13 PM   #292
cwcarpenter98
cwcarpenter98's Avatar
Nice! Did you have that done locally? Eventually, when I get to that point, I'll probably end up doing the same thing
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed
1995 Dodge Dakota Sport
Old 05-20-2024, 10:24 PM   #293
65Custom
The shop is in Cleveland, ga. where Im getting the body work done, A long time friend works there is doing the work I can't do since my health issues side lined me from doing much for a few years now. Anyway they have a guy that does this for them who is cheaper and does better job and also does the expoxy coating for a much more reasonable price than the other guy who is closer to the shop.
I can probably get the guys name and info if you want it. I will say when I saw it this past Saturday he did do a great job, everything was very clean the hood was not warped which was my biggest concern. Cleaned out all of the old filler and old undercoating, and overall we had very little unknown rust show up so I'm very happy with the results.
Next is fix the unknown now known rust and beat out the dents enough to so that it can be body worked and then it will be off to the painter for body work and paint.
Looking forward to getting it back has been gone since 2020
My Build Thread
I must be
Old 05-21-2024, 11:16 PM   #294
cwcarpenter98
Thanks for the info! I'm so far out on getting to that point, so I'll reach out to you when I start that whole process. I'm looking forward to seeing yours get back on the road!
Christian Carpenter
Old 05-22-2024, 10:15 PM   #295
65Custom
Yeah me too! it has been a long time in the works.
My Build Thread
I must be
