Old 04-25-2024, 12:52 AM   #1
Luke87gt
1969 Three on the Tree - trans fluid and capacity?
Hi guys, I have a three on the tree in my ‘69
Can anyone tell me what trans fluid it takes and rough capacity? Thanks
Also, assuming it’s original, what transmission is this?
1969 C10 Shortbed
Luke87gt is offline   Reply With Quote
Old 04-25-2024, 02:21 AM   #2
mr48chev
mr48chev's Avatar
Re: 1969 Three on the Tree - trans fluid and capacity?
80/90 Gear oil. I'm thinking 3-1/2 pints but will have to find my manual. If it is in the truck one of those red plastic transfer pumps with the red hoses from Harbor Freight is a life saver. They are inexpensive enough to have one for each type of fluid you would pump with one and not cross contaminate.
My ongoing truck projects:
Old 04-25-2024, 12:33 PM   #3
Jason Banks
Jason Banks's Avatar
This is what I use in mine:
https://www.tractorsupply.com/tsc/pr...-2-gal-t806600
The GL-1 rating is safe bronze and copper(one or both are present in the 3 speeds)
There's much discussion about this on this board and many others. But my deduction was the a GL-1 Rated 90w Gear oil is the safe choice.
Jason Banks is online now   Reply With Quote
Old 04-25-2024, 12:34 PM   #4
Jason Banks
Apparently NAPA has 1 gallon for the price of 2 at tractor supply if that is more convenient for you.
https://www.napaonline.com/en/p/NHF65201
Old 04-25-2024, 03:38 PM   #5
dmb
Active Member
dmb's Avatar
that stuff is made for an 8N tractor
I would go with a good 80W90 oil
just my opinion
David
Old dogs and children and watermelon wine
dmb is offline   Reply With Quote
Old 04-26-2024, 03:49 PM   #6
mr48chev
mr48chev's Avatar
just my opinion
David
Yuppers, there have been a ton of advancements in gear oil and oils in general since that Ford tractor formula was created. A good quality 80-90 would be far better. Leave that stuff to the antique tractor brigade.
Old 04-26-2024, 05:33 PM   #7
Luke87gt
Thank you for the replies everyone.
Will use the gear oil recommended above.
Lastly, what transmission brand/name is this?
1969 C10 Shortbed
Old 04-26-2024, 06:19 PM   #8
MikeB
MikeB's Avatar
Just like a differential. Fill it until lube runs out of the fill hole.
Most gear oil bottles have a nozzle, so unless something is in the way, you can just stick in the hole and squeeze.
Mike
1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes.
1982 C10 SWB -- sold
1981 C10 Silverado LWB -- sold, but wish I still had it!
1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 04-26-2024, 06:32 PM   #9
geezer#99
geezer#99's Avatar
Look on the side cover for the cover bolts location. That’ll tell what trans you got.
https://lugnutz65chevystepside.weebl...ission-id.html
geezer#99 is online now   Reply With Quote
Old 04-26-2024, 08:29 PM   #10
Luke87gt
Thank you!
Based on the 7 bolt cover, and placement of bolt holes, it appears to be a Saginaw 3sp manual
Is that good or bad? Lol
1969 C10 Shortbed
Old 04-26-2024, 09:38 PM   #11
geezer#99
geezer#99's Avatar
Good trans.
Lighter duty.
The Muncie was supposedly heavy duty.
Old 04-26-2024, 10:19 PM   #12
1970cstblazer
1970cstblazer's Avatar
Lightbulb Re: 1969 Three on the Tree - trans fluid and capacity?
Just make sure the fluid is GL4. It's compatible with soft metals.
1970 K/5 Blazer CST 4WD, Medium Bronze, 93k ACT. miles, 350, 4 speed, rear positraction, 16.5" x 8.25" HD wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration finally getting close to completion..
1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor...
2017 Sierra 1500 SLT 4WD, Black, 45k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2...
2019 Canyon SLT 4WD, White, 62k miles, 3.6, 8L45, 3.23 LS, 18" wheels
Old 04-26-2024, 10:57 PM   #13
MikeB
MikeB's Avatar
Not sure about 69 models, but for an 82 that I had, there were 3 versions, each with a different first gear ratio. The lowest ratio was for the 250 six because it needed lots of torque multiplication. The next was for the 305 and 292, and the tallest was for the 350 which would handle more torque. You wouldn't want to use the 250-six trans behind a 350. BTW, 2nd gear was also different for each trans to span the different gaps between 1st and 3rd.
Useless information?
Mike
Old 04-27-2024, 12:06 AM   #14
Luke87gt
Oh, can anyone confirm the three gear ratios ?
Also, what is my factory rearend gear ratio in my 12 bolt?
1969 C10 Shortbed
Old 04-27-2024, 05:27 AM   #15
'68OrangeSunshine
'68OrangeSunshine's Avatar
I can only answer B.
B]...If originally equipped with an automatic transmission, a 3:08 differential gear set was installed. If Manual, 3.73 was standard.
If not noted on the SPID Then it was one of these.
Old 04-27-2024, 10:37 AM   #16
Luke87gt
Thank you, the truck is original manual. If it has 3.73 that would be awesome as it’s one less thing I need to UG later. SPiD doesn’t show anything on gear.
I’ll try to confirm it by doing the wheel rotate / driveshaft count
1969 C10 Shortbed
Old 04-27-2024, 11:12 AM   #17
1970cstblazer
Factory issued info:
Old 04-27-2024, 11:22 AM   #18
1970cstblazer
Arrow Re: 1969 Three on the Tree - trans fluid and capacity?
GL-5 80W or 90W was recommended then..
Old 04-27-2024, 03:30 PM   #19
'68OrangeSunshine
I've heard some debate -- among SM465 Users -- that the limited slip additive in GL-5 is bad for the phosphor/bronze of the synchronizers and GL-4 or lower is preferred.
