Old 05-07-2024, 01:43 PM   #1
desert-rat
Location: 3,018 feet above the SoCal/Mojave Desert region.
Removing rust from chrome rims and polishing.
So my chrome rims are starting to show signs of rust. Has anybody removed rust and polished their wheels themselves?
desert-rat is offline   Reply With Quote
Old 05-07-2024, 01:47 PM   #2
geezer#99
geezer#99's Avatar
Re: Removing rust from chrome rims and polishing.
I had great successe with this stuff.
https://www.wikihow.com/Clean-and-Po...with-Nevr-Dull
Old 05-07-2024, 05:26 PM   #3
purple gas
I've used Brasso, or Silvo polish on chrome and had good results.
I've also used 0000 steel wool and windex on a GMC headlight bezels & grill and bumper that I eventually replaced.
Gotta be very gentle with the steel wool. It didn't appear to scratch the chrome, but it does nothing for the pits.
I wouldn't use steel wool on aluminum trim.
I've heard that applying wax after cleaning helps as a barrier between the metal and the elements to prevent or at least slow down the rust coming back.
I'm not telling you to go the steel wool route, just reporting my experience.
I got a bench seat baby, you don't have to sit over there.
purple gas is offline   Reply With Quote
Old 05-07-2024, 06:45 PM   #4
howzzzit
howzzzit's Avatar
https://www.amazon.com/Meguiars-G172.../dp/B001O7PNNM
This stuff works. Even safe on clear coat. I used with a wheel and cordless drill on a couple of bumpers and then waxed them. I've had rust on chrome wheels where your showing and it's an ongoing fight.
howzzzit is offline   Reply With Quote
Old 05-08-2024, 04:15 AM   #5
BRL
BRL's Avatar
Originally Posted by howzzzit View Post
...I've had rust on chrome wheels where your showing and it's an ongoing fight.
Ain't that the truth!
I've been using steel wool with car wax paste in a separate can to avoid contaminating the wax that I use on my paint job with steel wool threads.
Seems to do a decent job and it really isn't noticeable rolling down the road (I don't think) but I know it's there and once that moisture gets under the chrome and etches it you gotta keep on top of it or or it will just get worse all that much sooner.
BRL is offline   Reply With Quote
Old 05-08-2024, 03:31 PM   #6
72SB
Blue Magic brought my Craiger's right back on my 72
https://bluemagicusa.com/
72SB is offline   Reply With Quote
Old 05-08-2024, 08:17 PM   #7
dmjlambert
dmjlambert's Avatar
Coca-Cola and crumpled up aluminum foil will clean that right up. Follow up with soap and water, rinse, dry, and wax.
Old 05-08-2024, 08:49 PM   #8
weq92f
weq92f's Avatar
I just used something similar that was marketed for aluminum. It did exactly as described in your URL. It did require some elbow grease for sure but the result was very nice.
Not sure how it would do against rust on chrome but it did just fine removing a lot of crap off aluminum.
-Kevin
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is offline   Reply With Quote
Old 05-08-2024, 08:58 PM   #9
BRL
BRL's Avatar
Yeah I've heard about people using aluminum foil with good success.
I've been posting pictures on this forum from my phone and I just checked the picture on my tablet and noticed the dang picture came out so big that the tire was almost life-sized...oops.
Anyway I took another picture and no, it's really not noticeable from any sort of distance.
