Old 05-12-2024, 06:19 PM   #1
Dirsuper
Junior Member
Ran truck out of gas - fuel pump dead
Hey guys,
Stock mechanical pump - I deliberately ran my 1972 K20 out of gas due to having let it sit too long and the gas going bad (I assume, would not make it up a hill and ran really rough). I let it idle while I also pumped the fuel out of the tank manually. It ran out, as planned, no odd noises or anything weird. I got 5 gallons of fresh gas, put it in, and tried to start it, no luck. Poured a little fuel into the carb, start, run 5 seconds, die. Did that a few times and realized that I have a fuel delivery problem. Did all the usual checks (fresh line without filter off pump output into bucket and turn over, nothing; run a fresh line off the pump input into a gas can with gas, nothing; had wife turnover truck with my finger over the input side of the pump, no suction felt). I feel pretty confident the pump is dead. My concern is that I read a few threads where people had similar situations and others told them to check the oil. So I pulled the dipstick and the level was normal. However, when I sniff it I think I smell fuel so I plan to change it to be safe, but seeing that recommendation (which I never would have thought of) has me concerned there are other things to worry about.
So my questions:
1. Anything else to be concerned about checking?
2. I am ordering a new pump today, and hope to have time to replace next weekend. Given the overall situation, any other recommendations/words of wisdom?
All assists are greatly appreciated!
Thank you,
Dirsuper
Dirsuper is offline   Reply With Quote
Old 05-12-2024, 08:20 PM   #2
HO455
HO455's Avatar
Re: Ran truck out of gas - fuel pump dead
It's possible that the diaphragm gave out. As the fuel passes through the pump it will cool the diaphragm so it's possible that your old diaphragm was worn and failed when it got hot with little or no fuel passing through.
Just to be thorough are the rubber hoses on your fuel lines in good shape?
RIP Bob Parks.
Old 05-13-2024, 12:05 PM   #3
54blackhornet
54blackhornet's Avatar
I bought three pumps from Napa before I got one that was usable. The first one didn’t work at all. The second one had mismatched threads on output port. AC-Delco is no longer an American built product also !
71 C-20
07 Magnum RT AWD
54blackhornet is offline   Reply With Quote
Old 05-13-2024, 12:37 PM   #4
Shortnwide4x4
Shortnwide4x4's Avatar
sometimes it works force feed fuel into the f/pump thru the lines to prime it.
Shortnwide4x4 is offline   Reply With Quote
Old 05-13-2024, 04:01 PM   #5
mattfranklin
mattfranklin's Avatar
Yes, I use one of those red and black squeeze bulbs to push a little fuel through mine. I think it's supposed to check battery acid or something other than fuel. I've never used mine for anything other than gasoline. The fuel ages the bulb pretty quickly. But it will last for at least a few months of fuel system tinkering. Totally misusing the tool, but it's handy.
(Very) Slow-Going Build Thread: Stock 1970 Short Step with Stock 1970 LT-1
http://67-72chevytrucks.com/vboard/s...d.php?t=567340
mattfranklin is offline   Reply With Quote
Old 05-13-2024, 07:04 PM   #6
'68OrangeSunshine
'68OrangeSunshine's Avatar
Besides sub standard materials being used to assemble Asian-made fuel pumps -- even good US-made NOS pumps may have compatability issues with current gas station fuel being made with additives that are corrosive with the elastic element in the diaphragm.
Replacing the mechanical fuel pump on an Old School engine is a crapshoot now.
Same thing happened to the 350 in my '71 GMC a few years ago. I don't have a working gas gauge. I rely on using a trip log and factoring my gas buys [in gallons] against miles logged.
Not a blunderproof system.
About 5:45 PM, Downtown, coming home from work, the Jimmy started sputtering and stalled, just south of an intersection. I called a friend, and I called Road Side Rescue. The friend got there first. I gave him my Shell card and an empty plastic fuel jug, and sent him off to buy some gas. Meanwhile the Rescue guy showed up. He splashed about 3 gallons into the tank. No Start. Rescue guy left. My buddy came back with about 4 gallons. We added that. still no start. Now I had to call Road Side Rescue back and request a tow. The flatbed got there about 9. I was home by 11.
When I replaced the fuel pump, it lasted about 100 miles. Then it was spraying gas all over the underside of the engine. Towed home again.
Next one lasted 90 days.
Third time was the charm.
I was lucky, my SBC block has that stop bolt, that sets up the Fuel Push Rod between the ''shoe'' on the pump and the cam lobe. Just have to remember to disengage the set up bolt for running.
Old 05-13-2024, 10:58 PM   #7
oneshotkyle
Active Member
A rag wraped around a air nozzle pointed into fuel fill gently to pressurize and force fuel up to pump
oneshotkyle is offline   Reply With Quote
Old 05-14-2024, 11:38 AM   #8
54blackhornet
My SBC block was not drilled for the pushrod retaining bolt so installing a new pump is a royal pain in the neck. I replaced the top left bolt with a stud. This allows you to align the pump while starting the other bolts.
71 C-20
07 Magnum RT AWD
Old 05-14-2024, 12:15 PM   #9
1970cstblazer
1970cstblazer's Avatar
Lightbulb Re: Ran truck out of gas - fuel pump dead
I have greased the push rod on a cold engine with good results.
1970 K/5 Blazer CST 4WD, Bronze, 93k ACT. miles, 350, 4 speed, positraction, 16.5" x 8.25" wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration in progress...
1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor...
2017 Sierra 1500 SLT 4WD, Black, 41k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2...
2019 Canyon SLT 4WD, White, 60k miles, 3.6, 8L45, 3.23 LS, 18" wheels
Old 05-14-2024, 03:19 PM   #10
'68OrangeSunshine
That doesn't work in AZ. You get a blob of red grease in the face.
Old 05-15-2024, 12:03 PM   #11
697498chevy
Been a while , but some grease on the rod always worked for me too . Maybe I was just lucky ?
697498chevy is offline   Reply With Quote
