Old 04-28-2024, 06:53 PM   #1
Nick_R_23
Nick_R_23's Avatar
1980 Silverado C10 “Big 10”
I just picked up this 1980 Chevy Silverado C10 from Fairbanks, Alaska for $800! It was a beautiful trip and well worth the 600 miles around to bring it back home. It is a factory Big 10 package, the engine is missing, but still has the TH350, 12 bolt rear axle, and was optioned with power windows, power door locks, sliding rear window, A/C, power steering, power brakes, and what appears to be the deluxe interior. It has factory rally wheels with only 3 trim rings missing, and two tone paint with exterior body trim. It also has an aftermarket rear bumper still in pretty good shape. Despite the options, this thing sat outside with the windows open for quite a number of years. However, it seems to have faired pretty well and there’s not too much rust, mostly just some large dents I’m hoping to get smoothed out. It’s missing the title, so until I get that bonded I won’t be doing too much to it other than cleanup and collecting parts, but I do have quite a lot sitting around that will end up being used here.
Ultimate plans are a stock-ish Vortec 350 that’s sitting in my shop, and one of the two TH350’s I have, most likely the one that’s already in the truck. I will also probably do a 4.5”/6” drop, and undecided on using the rally wheels or going with an aftermarket set. I have a 73/74 grille kicking around the shop I might throw in as well. Other than that, just clean it up and drive it.
The drive up! Left the house at 4:00 am
This is the picture from the ad.
Lookin’ a little sad there buddy. Let’s get you home.
All loaded up!
Beautiful views the whole way!
Got home and started cleaning it up!
Set the hood back on. Cleaned up pretty well!
Going to hit the interior next. Half tempted to find a bucket/console set from a suburban.
BIG 10!
Old 04-28-2024, 10:21 PM   #2
Nick_R_23
Nick_R_23's Avatar
Re: 1980 Silverado C10 “Big 10”
Here’s some of the new parts I have sitting around that will end up on this engine.
Milodon Anti-climb shelf for the oil pan and ARP Vortec intake bolts
Holley aluminum Vortec timing cover with no sensor hole
Cloyes True Roller single row timing set
Melling M55HV high volume pump and drive shaft
Elgin 1.6 ratio rockers
LS3 beehive springs with Comp retainers
ARP main bolts for 4 bolt main blocks
OEM LS7 lifters
Weiand Vortec carb conversion intake
Old 04-29-2024, 10:21 AM   #3
Nick_R_23
Nick_R_23's Avatar
This was originally purchased for another project, but I found a better block I wanted to start off with instead, so this engine will now be used for the C10.
Donor rig was a 2000 Express Van
Engine out!
Engine separated from the transmission and heads removed
On the stand. Oil was a little milky, so head or intake gaskets were done.
Started teardown
Completely stripped down. Everything looked serviceable other than some light scoring on the pistons. Off to the machine shop!
Old 05-05-2024, 11:32 PM   #4
Nick_R_23
Nick_R_23's Avatar
Tinkered on it a little this weekend. Hooked a battery up to see if I could get the power windows to work. The switches seem functional, but I believe the motors are seized. There’s a little bit of life in her, though!
I also scored a bench seat for $100. It’s from a crew cab and non-folding, and the mounts will have to be swapped, but it’ll look better inside now.
Vacuumed the interior and removed the carpet and padding. Found some rocker rust, but the floor seems to be pretty nice overall!
Also wiped the interior down!
I picked up a full set of interior switches. Part of the title process says that the vehicle needs to be street legal, so all of the safety equipment needs to function, such as the horn, headlights, turn signals, brake lights, etc, so I’m hoping this solves a lot of issues right out of the gate.
Old 05-09-2024, 12:16 AM   #5
Nick_R_23
Nick_R_23's Avatar
Small change of powertrain plans, picked this up today! 1999 Express 2500 with a 5.7 Vortec and 4L80E for $250! Should be a good donor rig!
Old 05-20-2024, 02:03 AM   #6
Nick_R_23
Nick_R_23's Avatar
I really need to get that winch mounted on the trainer. Hand cranking it up on there was a pain in the ass!
Wasted no time parting it out!
Sawzall to the rescue!
Engine and trans out!
Old 05-21-2024, 11:25 PM   #7
PowerdbyChevy79
PowerdbyChevy79's Avatar
Post some pics please...
1966 C10 "Mary"
1972 C10 Cheyenne "Betty" https://67-72chevytrucks.com/vboard/...d.php?t=847364
1976 C35 Sierra Grande "Mr. Harvey"
1979 C10 Silverado "The BIG TEN" https://67-72chevytrucks.com/vboard/...d.php?t=841339
1982 C10 Silverado "Lucy"
C10 Club Texas -HMIC
PowerdbyChevy79 is offline   Reply With Quote
Old 05-27-2024, 12:50 PM   #8
Nick_R_23
Nick_R_23's Avatar
Engine and trans in the shop!
Old 06-12-2024, 01:51 AM   #9
straight6chevyguy
straight6chevyguy's Avatar
Cool project, Im kinda curious how positive you are about it being a 1980? Since it doesn't seem to have the correct hood or grille setup for an 80. I know those things could have been swapped but I'm just curious what you're thoughts were.
1965 chevy c20 292 4speed http://67-72chevytrucks.com/vboard/s...d.php?t=777601
1976 chevy c10 250 4speed http://www.67-72chevytrucks.com/vboa...d.php?t=787037
1978 chevy c20 350 4speed
1998 chevy c1500 4.3L 5speed
2002 Chevy s10 4.3L auto 4x4
Plus a Mercury & some Fords... To many projects!
straight6chevyguy is offline   Reply With Quote
Old 06-12-2024, 10:07 AM   #10
Nick_R_23
Nick_R_23's Avatar
It’s an 80 per the VIN and door tag. The hood, although close, isn’t the exact same color, and the front end has definitely been worked on since the valance is white. It’s getting a ‘73 grille though as soon as I get the mounting brackets from a buddy.
Old 06-12-2024, 01:18 PM   #11
straight6chevyguy
Okay that would make sense.
After I posted my reply I realized the truck does have the correct mirrors and has the fuel doors in the bed which would be correct. (I think fuel doors came out in 79? Someone can correct me if I'm wrong)
