06-03-2024, 11:40 PM | #1 |
Hydro-boost with Disk/Disk Prop Valve
My disk/disk hydro-boost conversion proportioning valve turns the "brake" light on when applying the brake. This is a new first installation/test in the garage. I had selected a disk/disk proportioning valve when putting it together but it is obviously not the correct combo. So anyone with hydro-boost have a part number for a proportioning valve that works? I used the search function above with lots of info but non with a hydro-boost added in. The system has been bled numerous times and the light can easily be reset. I'm not looking for trouble shooting info unless you have hydro-boost.
72 K20 Custom Camper, D60, 14BFF, full roller 406 TPI w custom built ECU and yes..it has tow hooks...and a 5 speed |
06-04-2024, 02:51 PM | #2 |
Re: Hydro-boost with Disk/Disk Prop Valve
I don't speak hydroboost, but the type of assist should have nothing to do with the combo valve, which only interacts with the MC. Boost only changes the amount of pedal pressure it takes
1970 C10 Custom longbed 350/350 Code:
__ ______|__]\____ ....|___(o)_____(o)_] Last edited by Rust_never_sleeps; 06-04-2024 at 05:55 PM. Reason: clarity |
06-04-2024, 05:34 PM | #3 |
I'm in the same camp as Rust_never_sleeps. The valve is shifting off center due to a pressure difference on the piston, inside the valve. Whichever side the piston is moving to is the low pressure side. Whether the low pressure is from a leak, or trapped air in a caliper, or possibly low pressure from the master cylinder is what you need to figure out. A brake pressure guage should help locate the problem.
Some rear disc brake calipers can be notoriously hard to completely purge of air. Sometimes the caliper has to be removed from the mounting and a plate inserted to mimic the rotor and then while the caliper is held so the bleeder is in the absolute upper position the caliper is then bled. Good luck.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
06-04-2024, 09:05 PM | #4 |
So I thought I would start with a known good part number for the prop valve from someone whose hydro system already works, and go from there. Like I said in the first post, I searched on here a lot and the nightmare stories of bleeding gallons of fluid set me on the part number first.
06-04-2024, 10:06 PM | #5 |
At the body shop.
Caddy park brake calipers? A friend has been fighting a similar issue.
Was told the re pop caddy calipers are not the best. He's switching to a later model mustang caliper kit.
" That didnt make it any newer " " Dont antique the equipment " |
06-05-2024, 12:15 PM | #6 |
OK so I need two new rear calipers because a friend was told they were the problem? Is the "friend" on this board? If so maybe you could convince that person to log in and give everyone the real scoop (with pictures please, because everybody likes the pics...) I'm asking for a friend....I'm going to go broke if you guys keep spending my money like that, oh wait I need a brake pressure gauge too! I wonder how much a known good part number will cost me....
06-05-2024, 01:41 PM | #7 |
At the body shop.
It's on a oldsmobile.
Was relaying his experience with repop cad style rear calipers. Pv4 is the standard name for disc disc, as far as a oem pn sorry.
06-05-2024, 02:12 PM | #8 |
At the body shop.
3667810 gm
Try this..
06-05-2024, 02:12 PM | #9 |
An Oldsmobile with hydro-boost? I guess I'm not too sure how re-mfg calipers are the cause of a brake light AND he decided to get rid of them for another style? Were they leaking? I get that some calipers are hard to bleed but to give up on a set, they must have been really messed up. What was wrong with them specifically?
06-05-2024, 02:26 PM | #10 |
So that is the one your friend has on his disk/disk hydro-boost system that works?
06-05-2024, 03:58 PM | #11 |
I just used a universal, manual adjust, valve in the rear brake line. Don't remember exact brand without looking at it, but similar to this https://www.summitracing.com/parts/leb-apv02 . But I did pair it also with a new master cylinder off '01 Chevy with disc front & back.
Been working for 10yrs now with zero problems.
'72 C to K20 "Cannibalizer" http://67-72chevytrucks.com/vboard/s...32#post8653432 '85 K30 "Big Nassy" [B]'85 C10 [B] "Corpse" '01 2500 Suburban ...party wagon & tow truck '06 Silverado SS...DD '06 C1500 WT...DD '07 Classic C1500 WT...DD Built & sold cause can't keep 'em all: '72 Blazer "The Bucket" http://67-72chevytrucks.com/vboard/s...d.php?t=433190 '55 Chevy straight axle gasser https://www.trifive.com/forums/showthread.php?t=173938 '69 Pro Street Chevelle http://www.chevelles.com/forums/showthread.php?t=332541 '86 M1031 CUCV http://67-72chevytrucks.com/vboard/s...d.php?t=553619 |
06-05-2024, 04:48 PM | #12 | |
06-05-2024, 05:37 PM | #13 |
At the body shop.
After his brakes wouldn't bleed, he took to a shop.
They told him the re pop calipers are a pita to bleed/adjust. And still won't be good. So swap to a more modern system is his solution. You ever think a metric non park brake caliper to see if it's a proportioning valve or caliper issue ?
06-05-2024, 05:47 PM | #14 | |
So now I need MORE calipers? Maybe it because they would be metric....ya, that's it.
06-05-2024, 08:29 PM | #15 |
On my 66 Mustang project with a hydro boost unit I used a Wilwood adjustable prop valve in the rear brake line. I used C5 Corvette disc brakes all around so not apples to oranges but the Wilwood prop valve once adjusted worked perfect.
Not a great pic but hard to see underneath the master. One thing I had to add after installing the hydro boost was add a fluid resisvoir with a filter to eliminate micro bubbles. This per the folks at Hydra-Tech. |
06-05-2024, 09:11 PM | #16 |
Super excellent info, much appreciated. So where exactly did the extra reservoir go? Which system was it plumbed in to, the master cylinder sys, or the hydro sys? Gold star for the nice Stang!
06-05-2024, 11:56 PM | #17 | |
Location: Herculaneum MO (20 minutes south of St. Louis
67 C10 283 T5 swapped longbed fleetside = wife's daily driver 67 C20 292 (originally a 250)4speed longbed fleetside w/original wooden bed=my project truck 67 C10 283+.060 (so a 292 as well)T5 swapped longbed fleetside=my DD 72 C1500 Sierra Grande 350 TH350 longbed fleetside=wife's fair weather truck Can you tell we are fans of longbed fleetsides & 67s Chris |
06-06-2024, 11:18 AM | #18 | |
"Super excellent info, much appreciated." I will call out BS when I see it, just for future reference.
06-06-2024, 11:49 AM | #19 |
I would leave it alone until you drive the truck. See how it brakes and stops and if like the bias and all else is good in the stopping/braking arena; then chase the light problem. You could get the light working with a new valve and not like how it stops. It will be a good point of reference ,anyhow, if you need to move onto a different valve. I'm running a disc/drum so I won't post the part. Hydro-boost is a great upgrade.
Good luck... Have fun! j
White K20 |
06-06-2024, 11:52 AM | #20 |
I have a hydro boost on my truck running for about 3 years now. I don't even have a proportioning valve. I have never had an issue with the brakes locking up or being off balance. I have an adjustable prop valve I originally planned on installing on the rear like fun in dirt has, but I never got around to it. All it would do is stop the rear from locking if that were an issue.
I do not have the parking brake in the caliper. My PB resides inside the rotor, so I am using Explorer calipers. I have never had a problem bleeding rear calipers with the PB in them. The trick is having to pump up the parking brake lever to get the pad adjusted correctly or you will never got a good pedal. The rear caliper has a ratchet mechanism which pushes out the piston reducing travel. Once you have that set, then the piston has only a very small amount of travel. Whether that small amount will mess with your prop valve, I am not sure. |
06-06-2024, 12:26 PM | #21 | |
06-06-2024, 12:36 PM | #22 | |
06-06-2024, 01:19 PM | #23 | |
j
White K20 |
06-06-2024, 01:43 PM | #24 | |
06-06-2024, 02:35 PM | #25 | |
