Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork
Old 06-03-2024, 05:13 PM   #1
Chaparralman1974
Chaparralman1974's Avatar
Painting the cab
I am getting pretty close to painting the cab. I have to finish final sanding and then I plan to seal everything with a thinned epoxy (eastwood) followed by single stage paint. As I am doing the entire cab inside and out the same color, should I paint it in stages (inside first, let it dry, then outside)? Or should I do the entire thing all at once?
Thanks, Clay
Clayton Sikes
Peoria, Arizona
1967 Chevy K20
Build Thread: https://67-72chevytrucks.com/vboard/...d.php?t=841272
Chaparralman1974 is offline   Reply With Quote
Old 06-03-2024, 05:42 PM   #2
Grounded63
Re: Painting the cab
I would definitely break it up in stages. Paint the inside. Then back mask and seal the window openings and door jams, at the pinch welds.
Grounded63 is offline   Reply With Quote
Old 06-03-2024, 05:45 PM   #3
Chaparralman1974
That makes sense. Would it be better to only seal the inside, paint that, back tape the cab and then repeat for the outside? IOW, only seal what I am painting at that time?
Clayton Sikes
Peoria, Arizona
1967 Chevy K20
Old 06-03-2024, 05:55 PM   #4
Grounded63
Yes, generally you let the sealer flash then then go right to paint. The tech sheet should give you the specs for that. Depending on the product, you will have a window by when you need to start spraying the top coat by. Or, you will need to re-sand the sealer, and start over.
Old 06-03-2024, 08:38 PM   #5
LS short box
As said above interior first and then back mask. Then the outside. That way you won't be dragging an air hose across new paint to get at the interior.
Old 06-04-2024, 11:53 AM   #6
Chaparralman1974
Ok, thanks everyone! Hopefully I can get this thing in some color soon.
Clay
Clayton Sikes
Peoria, Arizona
1967 Chevy K20
Old 06-04-2024, 12:53 PM   #7
Grounded63
What color are you painting it ?
Are you also using Eastwood single stage paint. If not, I would recommend using that paint manufacturers sealer.
Old 06-04-2024, 04:54 PM   #8
Chaparralman1974
I am going for a baby blue. I have not yet picked the exact color, but something along those lines. I was planning on using Eastwood paint so that all of my products are from the same manufacturer. I have been using eastwood epoxy primer as well as the 2k urethane primer from them. My plan was to use the same eastwood epoxy primer, but thinned an extra 20% for the sealer.
Clay
Clayton Sikes
Peoria, Arizona
1967 Chevy K20
Old 06-05-2024, 12:49 PM   #9
Grounded63
Sounds great !
