06-01-2024, 12:05 PM | #1 |
sm465
looking for tools,tips and tricks. My second gear syn is shot. other than that it seems to work fine. I didn't see any issues with the gears when I had it open before installing it. What special tools will I need, and which kit would you suggest?
2000 c3500 utility bed 7.4l 5sp manual old body style. Cab and chassis 1964 GMC K10 383cu in/sm465/twin stick np205 1965 Chevy C60 |
06-01-2024, 07:43 PM | #2 |
Re: sm465
When you say second gear, are you counting L,1,2,3 or ,1,2,3,4?
-400/400 1979 K25 350/SM465/205/44HD/14FF 1985 K20 400/400/208/10/14 1987 V10 TBI350/700R4/208/10/10 '85 Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=643968 |
06-02-2024, 10:04 AM | #3 |
Re: sm465
This website in the link below has a great Identification chart.
If you think it may have been swapped at some point. Link: https://www.drivetrain.com/parts-cat...on-rebuild-kit
06-02-2024, 11:25 AM | #4 |
Re: sm465
l,1,2,3
06-02-2024, 11:29 AM | #5 | |
Re: sm465
06-02-2024, 02:53 PM | #6 |
Re: sm465
Both These places have a good price for the rebuild kit.
The 2nd one has more parts and it's also About $100 more. Depends on how much yours needs and how far you want to go with the rebuild. Link: https://www.allstategear.com/SM465-T...show=30&page=1 Link: https://www.novak-adapt.com/catalog/...s/sm465-parts/
06-02-2024, 05:25 PM | #7 | |
Re: sm465
06-07-2024, 01:23 PM | #8 |
Re: sm465
You need a press (a decent sized one) to get the main shaft apart, along with some spreader plates that will fit under the gear. 2 ( i think ) of the gears are held on by the main shaft bushings, so the only way to get it apart is to press the gear off and the bushing at the same time. You also need a strong pair of snap ring pliers.
06-07-2024, 09:40 PM | #9 | |
Re: sm465
