Pitman Arm nut size
Can someone tell me what is the size of the nut that goes on the pitman arm? Pic is attached.
Thanks!
RIP to my son Dylan. 5/17/2002 - 8/18/2018 If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started. https://slothforpedcancer.org 68 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=223234 Last edited by skokie; 06-08-2024 at 07:19 PM. |
![]() Join Date: Mar 2003
Re: Pitman Arm bolt size
7/8'' fine thread.........1-5/16'' socket
RIP to my son Dylan. 5/17/2002 - 8/18/2018 If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started. https://slothforpedcancer.org 68 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=223234 |
What would I torque it to?
Thanks!
![]() Join Date: Feb 2009
The nut is torqued to 100-150 foot lbs. per the service manual, and 175 foot lbs per Moog. 135-140 with oil should be about right, but use search to verify.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
![]() Join Date: Jun 2022
This is the 70 manual, P661. You can get the pdf like I did from this site
1970 C10 Custom longbed 350/350 |
Interesting. I thought I read 100-150 ft. pounds someplace, and your chart made me question that. The assembly manual reads 100-150 ft. lbs., MOOG more than that. In hindsight, I think I'd have torqued it 135ish with oil, not 150.
I've always taken them to 120 and never had a problem
