Old 06-09-2024, 06:44 PM   #1326
SkinnyG
SkinnyG's Avatar
Re: SkinnyG's '61 Apache
Oh dang.
Fuel pump or fuel pump related.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, boosted-LS
1977 Silverado: Shortboxed & dropped, potato-potato
V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag
Lotus Super 7 Replica: Scratch-built street-legal rollerskate
SkinnyG is offline   Reply With Quote
Old 06-10-2024, 12:18 AM   #1327
SkinnyG
SkinnyG's Avatar
Truck is at home in the house garage, up on jack stands in anticipation of dropping the fuel tank.
Not tomorrow though - I have physio after work, and while I usually have dreams of coming home and working on stuff, I'm usually lucky if I can even tie my shoes after the IMS and elecro-shock.
Old 06-10-2024, 12:44 AM   #1328
caseyjones
Looks like you were on a nice drive until it wasn’t. Hope the fix is simple!
caseyjones is offline   Reply With Quote
Old 06-11-2024, 12:39 AM   #1329
SkinnyG
SkinnyG's Avatar
The fuel pump relay was clicking, and I tried bypassing the relay and powering the pump directly, but it wasn't working. I think it's the connection inside the tank. I remember building it going "this seems rinky-dink."
I re-did the internal connections , and it is now "robust."
Old 06-11-2024, 03:43 PM   #1330
verdell
verdell's Avatar
I went through a similar situation with the exact same fuel tank set up in my '60. After redoing (soldering) the sending unit connections and running a solid length of 10 gauge wire, it's running better than ever.
verdell is offline   Reply With Quote
Old 06-12-2024, 12:26 AM   #1331
SkinnyG
SkinnyG's Avatar
Old and busted "hot" connection for the fuel pump (I'm using a Walbro 450):
I removed that gray connector, and crimped/soldered/heat-shrunk all the wires to their respective pins, with 12ga wire to the pump. There should be no problem now.
Old 06-15-2024, 12:15 AM   #1332
SkinnyG
SkinnyG's Avatar
Back up to 8psi boost now, and with all eight cylinders properly firing ... HOOO BOY!!!!
I have a smile.
Old 06-15-2024, 07:57 PM   #1333
350TacoZilla
Great news man
350TacoZilla is offline   Reply With Quote
Old 06-16-2024, 11:46 AM   #1334
SkinnyG
SkinnyG's Avatar
The tank came out really easy - I designed it to be serviceable (and it worked!).
The straps (two nuts), the fill/vent hoses (hoseclamps), and the feed/return lines (two AN fittings).
Took maybe 30 minutes.
The bed on the other hand, that would take a LOT longer.
Old 06-16-2024, 09:06 PM   #1335
SkinnyG
SkinnyG's Avatar
Added a relay to turn on the cooling fan during AC. It's using the Trinary pressure switch off the accumulator. Not sure I'm totally happy with the result, but we will see.
You can just barely see the reorganized relays to the right of the rad.
Old Yesterday, 07:46 AM   #1336
joesscamaro
Glad you got it figured out and improved and back on the road.
joesscamaro is offline   Reply With Quote
