06-15-2024, 09:44 AM | #1 |
1968 Air Cleaner BBC
Looking for a 68 Big Block air cleaner for my 67 conversion.
I'm Going for stock look on the conversion. Big blocks have shorter snout, larger area on inlet of snout. At least on cars they do. |
06-15-2024, 09:53 AM | #2 |
Re: 1968 Air Cleaner BBC
Link to ebay : https://www.ebay.com/itm/23539861219...Bk9SR7zdycKDZA
Your best bet would be Ebay or a swap meet unless you want to become a subscribing member then you could post a want to buy add
06-15-2024, 09:55 AM | #3 | |
06-15-2024, 10:41 AM | #4 |
Who Changed This?
Yup, look like my pic. I'd like one of those dual snorkel jobs but can't quite skin my wallet for it. Are you going to also install the tin for the exhaust manifold and heat tube?
06-15-2024, 12:37 PM | #5 | |
Next will be oem valve covers I bought. But, these later models don't leak.... |
06-15-2024, 03:38 PM | #6 |
The air cleaner housing on my 68 396, has no warm air tube, or any way to connect one. It also does NOT have the vacuum pod on the snorkel. It's just a plain single snorkel air cleaner housing. In fact it's smaller than the link pictured, 71/72 unit. You'd think it would be fairly big............unless mine is incorrect.
I've never seen a 68 unit for sale, here. I'd like to find one I could afford, mine is a little rough... |
06-15-2024, 07:44 PM | #7 |
Who Changed This?
Likely a unit from a year previous, before that heat tube was used. A smaller inlet size may mean that it was on a SBC. Then again, it could be a Federal emissions setup, Vs California emissions. That's long enough ago that I've forgotten the differences, even though I was an emissions tech in the '70s and '80s.
06-15-2024, 10:47 PM | #8 |
At the body shop.
Some swap meet breather I believe sbc air cleaner base.
And bought another base for the matching snorkle. Hole saw and a few tacs, dual intake for about $50
" That didnt make it any newer " " Dont antique the equipment " |
06-16-2024, 09:23 PM | #9 | |
I bought my 68 in 1980. Everything on it was stock...although wore out. |
06-16-2024, 10:15 PM | #10 |
Who Changed This?
My truck's air cleaner housing (the picture is mine) has the vacuum motor, but no indication at all that it ever had the sheet metal. Given that this truck ran hot from the very first day my FiL bought it, I'm betting he removed it. That, or when he had the engine rebuilt 40 years ago, it got left off. They put the heads back on opposite sides too, because the coolant temp sensor is on the passenger's side. I looked in both the service and overhaul manuals for '68 and neither shows that system. Your truck probably didn't come with it.
06-17-2024, 06:09 AM | #11 |
My Ebay link was just for Example.
Thats the first thing that popped up. Here's one on FB. This is in aPrivate group so may not open up for you. I can send pics. https://www.facebook.com/groups/5126...15337351858274 As mentioned, It does not have the Emissions stuff.
06-17-2024, 05:34 PM | #12 | |
Moderator
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
Tags |
aur cleaner, big block 396, big block 402 |
