Old 06-20-2024, 10:46 AM   #1
guyryan100
guyryan100's Avatar
JB TankWeld technique
Hi,
I have a leak in my 20 year old steel blazer tank, its located behind the strap, about 3 inches up from the bottom (its on the side of the tank). It is a 1/16" round hole. I don't detect any other weak spots.
I'm going to attempt the JB TankWeld product. I'm contemplating tightening a small screw into the hole, tightening it down through the JB stuff before it cures and pressing JB over and around the screw head, or skipping the screw and just using JB.
Obviously this low in the tank, the patch will have gas sitting against it at all times.
Has anyone attempted this technique?
Ryan
guyryan100 is offline   Reply With Quote
Old 06-20-2024, 11:49 AM   #2
kwmech
Re: JB TankWeld technique
I would pull it out and have it cleaned and a soldered patch put on from a radiator shop
Old 06-20-2024, 12:21 PM   #3
1970cstblazer
1970cstblazer's Avatar
Arrow Re: JB TankWeld technique
If this is a '69-'72 Blazer, the new tanks with correct filler neck are just over $200.
1970 K/5 Blazer CST 4WD, Bronze, 93k ACT. miles, 350, 4 speed, positraction, 16.5" x 8.25" wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration in progress...
1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor...
2017 Sierra 1500 SLT 4WD, Black, 41k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2...
2019 Canyon SLT 4WD, White, 60k miles, 3.6, 8L45, 3.23 LS, 18" wheels
Old 06-20-2024, 01:03 PM   #4
LNP
I have used JB Weld for tanks before it works well. The big key is to be sure the arear is clean of "everything". Sand it to help the JB bite in tight and use thinner to clean away any conminates from the area. I use regular JB at my shop to fix all kinds of stuff for customers. If done right it works great.
Harley
1969 Chevy C-10 Long Bed, 350cid, 700R4
LNP is offline   Reply With Quote
Old 06-20-2024, 04:23 PM   #5
Sheepdip
Sheepdip's Avatar
JB Weld is good stuff but....a patch is still a patch.
Sheepdip is offline   Reply With Quote
Old 06-20-2024, 05:03 PM   #6
guyryan100
guyryan100's Avatar
My plan is to give JB a try, if it fails at least I tried. This is a Blazer tank mounted under the bed of a 67 stepside, and has a custom fill tube that I would prefer not to have to recreate on a new tank, so my plan is to first try the patch, if that fails remove the tank and inspect it to determine Plan B.
Thoughts on using a screw vs just JB Weld?
Old 06-20-2024, 06:29 PM   #7
best view
This may sound silly but couldn’t you fill it with water then weld it
best view is offline   Reply With Quote
Old 06-21-2024, 09:58 AM   #8
LNP
Very true but like me not all of us can buy everything new.
Harley
Old 06-21-2024, 12:04 PM   #9
Wrenchbender Ret
The screw idea sounds good to me. If the screw stops the leak long enough the JBW will set up dry.
George
Wrenchbender Ret is offline   Reply With Quote
Old 06-22-2024, 08:43 AM   #10
cj847
cj847's Avatar
I used some kind of fuel tank epoxy stuff (might have been jb weld) on a tank a couple of years ago. Put it on while the leak as actively dripping. I sanded the spot and stuck it on. It worked great. About a year later another leak developed in another spot and I patched it the same way. Then I bought a new tank.
Summary: you don't need the screw. The stuff works great. But, start saving for a new tank. I highly doubt that is the only weak spot.
cj847 is offline   Reply With Quote
Old 06-22-2024, 01:43 PM   #11
Getter-Done
Getter-Done's Avatar
Since you do plan to patch it .
I would use the screw and JB weld.
Then put Seal-All over the Jb-Weld.
Seal all last a long time.
Link: https://www.amazon.com/Seal-All-3801.../dp/B008VK0JS4
84 Chevy K-20
Getter-Done is online now   Reply With Quote
Old 06-22-2024, 04:05 PM   #12
57taskforce
All about them K’s
57taskforce's Avatar
I’ve used JB a couple times on an old S-10 blazer gas tank. It was the clay type stuff they make specifically for gas tanks and it works really well even when it’s dripping fuel from the hole.
Tyler
'72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879
‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206
'98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's
‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue
‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0
