06-23-2024, 07:18 PM | #1 |
Vacuum Gauge Installation
Here's a short video that gives an overview of the method I use to install a stock-style (reproduction) vacuum gauge in a factory gauge cluster. The only purchased items are the gauge and the decal material.
https://youtube.com/shorts/W6D0dcKrsCc?feature=shared |
06-23-2024, 10:01 PM | #2 |
Re: Vacuum Gauge Installation
Cool. I have a Moon Eyes Vacuum gauge on 919. Bought it in '77 after breaking in my first 292 build. Invaluable gauge when tuning up, a real eyeball on the engine's health when cruising. Also the first indicator of a broken exhaust valve spring.
My nominal with a .030-over 292 is 17.5''Hg. [SBCs with greater displacement might have more Suction.] Jumps into the 20s when engine-braking. Drops low on acceleration. Bouncing needle tells you a valve or lifter is blown. On a long cruise, you can see if you're getting better economy by easing the acellerator pressure and decreasing RPMs without dropping your Inches of Mercury. It's the Steam Gauge OBD. Have one for the '71 Jimmy that I haven't put on yet. An AutoMeter.
06-23-2024, 10:28 PM | #3 |
That is Cool.
So, you made your dimple dies out of delrin?
06-23-2024, 10:34 PM | #4 | |
06-23-2024, 10:41 PM | #5 |
I designed them using SolidWorks and then had them 3D printed out of PLA. The gauge cluster metal gets bent at 90 degrees at the bottom of the opening with a sharp corner, and 72 degrees at the top with a large radius. It was an interesting challenge to model that accurately and have the two bend profiles blend together smoothly.
I put grease on them during use, and they form the metal very easily. I'm not seeing any wear on them at this point. |
06-23-2024, 11:05 PM | #6 | |
Great work. I may try this with some delrin. Thanks for the Idea.
06-23-2024, 11:06 PM | #7 |
Explorer
Looking Good
Older than Some and Younger than Some, but I am still here ............... ____ .. ________//__{\____ /__(O)___//___/_(O)_/ |
06-24-2024, 07:45 AM | #8 |
You are definitely a craftsman. Very nice work.
1970 K/5 Blazer CST 4WD, Medium Bronze, 93k ACT. miles, 350, 4 speed, rear positraction, 16.5" x 8.25" HD wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration finally getting close to completion.. 1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor... 2017 Sierra 1500 SLT 4WD, Black, 45k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2... 2019 Canyon SLT 4WD, White, 62k miles, 3.6, 8L45, 3.23 LS, 18" wheels |
06-24-2024, 09:54 AM | #9 |
