LS conversion with Saginaw 3 speed
Has anyone completed an LS swap using the Saginaw 3 speed to maintain the nostalgia of the 3 speed column shifter? If so how difficult is it and how well has it worked?
![]() Join Date: Apr 2016
Re: LS conversion with Saginaw 3 speed
I am also interested in this.
That would be a lot of work just to go bakwards. Kinda like setting up one of those expensive retro bluetooth USB radios only to run it in mono.
I have a feeling most folks who went through the effort to LS their truck wouldn't spend even more time and money sticking with a non-OD trans that has to be adapted and potentially mounted differently. I always figured LS-swapping an old car main advantage is opening up trans options. Hope you find an answer. |
#4 | |
My 68 C10 started out with a column 3 speed shifter. I'd be a bit worried since the 3 speed trans didn't have a trans mount and would the LS like the trans just hanging off the bell housing? Also trans/LS engine crank pilot bearing?
#6 | |
What screaming!
It’s only turning 2900 rpm. |
#8 | |
I have used four speeds with the Ls platform. There is a couple of issues that you will have. 1. You will need the scrog and Dickey pivot in the short version - roughly $60 through summit due to lack of a pivot provision on Ls . 2. You can use the stock bell housing but may need to trim an ear at the lower flat where the inspection cover bolts on due to interference with oxygen sensor in headers- the speed engineering are cheap and fit well for long tubes 3. The bell crank will have to be modified slightly by cutting 1/2 inch off side the goes into pivot at block and using a boring bar to make the pivot slide into the bell crank deeper. 4. Use ls7 pilot bearing, a 99 6.0 or 4.8 flywheel and clutch assembly, they will give full clutch coverage and are 10 spline units. 5. You will possibly need a longer drive shaft and also the shift linkage rods make need modification. You should be able to use stock crossmember for trans .6. Gauges may be issue for water temp, oil pressure can be made to work with stock cluster with no issue- Ict billet is your friend for brackets and assorted pieces. 7. Do it, it is yours and it is fun to figure out the pieces and parts. Finished 68 c10 last fall, did 62 nova wagon over winter and just installed a 4 speed in 68 Camaro with 5.3 this week using ALL stock components - had to have a 52.5 drive shaft, original was 50, modify the trans mount slightly and lengthen the original hole for shifter by 2” as well as move console forward 3”. It can be done! Have fun and get after it.
67 blue step side- bb 68 gold and white swb cst anniversary 68 custom swb hot rod Ls swap 69 swb cst 6 cylinder/ overdrive 69 black/black cst bb swb 70 orange and white cst Canada built truck swb bb 71 black and white super swb bb 71 red and white super swb 72 green and white super swb 4x4 62 nova wagon 400 series Ls swapped 68 Camaro 327/4 speed- 1 owner, original paint 66 Volkswagen bettle 69 auto stick Volkswagen Beetle |
#10 | |
Equal opportunity joke ofender
![]() Join Date: Oct 2011
here are some links with part #'s that were posted when I asked this question. I have actually started gathering some of the cheaper stuff to put on the shelf for when my 307 takes a dump.
https://67-72chevytrucks.com/vboard/...d.php?t=850302 .
Members I have met. Dually Jams, OlBlue60, ScottH, Tommyboy24, Dujobo, Warbucket, 2003 Silverado, Notsolo, my90k5, 6t727t2, Special-K ,Jack_71C10, tabarcus,72blazer_mud_bogger,pwdcougar,RSavage,EricSean,1Rippen6,invicta455,tennaragtop71,arks, Kendal,Bennett68C10, Perpendicular, Chainsawman, McGeesCustomMinis,ShortbedClayton,longblue72,6768chevylover,Tim71,Travisarmenta,Ol' Drippy,fleetmitch,georgieb51,Dave,bcnya2,Dadsburb https://paypal.me/6772GMtruckparts Most women like the strong, silent type… Fortunately for me, my wife prefers the out-of-shape, mouthy type. |
![]() Join Date: Jul 2000
Even if you can get it installed, a Saginaw 3-speed wasn't designed to handle a lot of torque. Even the late 70s/early 80s model with the tallest 1st gear ratio (for reduced torque multiplication) was intended to live behind a stock 350 that made 275 lb/ft torque or less.
So, I'd be concerned using one behind an LS engine, unless it was a stock 4.8 or 5.3. Then again, I've read were they are used in some dirt track race cars, but I wonder if those even use first gear.
Mike 1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
#13 | |
>>Definitely agree with all that but if you’ve ever run a three on the tree through the gears, you can’t put a price on that.<<
Ya, $0.00 There's nothing sexy, useful or nostalgic about shifting a "H" pattern on a column. I have driven many late 40s, 50s and 60s vehicles with a column shift and hated every one of them. Actually, I drove a few floor shift 3-spd cars and didn't like them much either. Swapping the 3-spd in my GMC for a SM465 put a smile on my face, even though I still had a 3-spd + granny. I do have use for that 1st gear granny on a number of occasions. Would I like a truck 5-spd? Sure, but never a 3-spd column. >>The inline 250 is definitely screaming at 65 lol.<< I swapped the factory 4.56 rear gear for 3.54 gears and drive in the fast lane at 75 all day with the AC on listening to the radio. I drive the GMC more than my 6.4 RAM 3500.
'67 GMC 2500, 292, 4spd, AC |
#15 | |
his quote was actually replying to my initial post and what makes that funny is that I actually daily drive an "off-brand" truck with an I6 and 3-on-the-tree. ![]() I wanted an OD manual trans but after a few years I realized I actually really like the extra space from not having a shifter on the floor, makes having 3 people in the truck bearable. My point is: while OP might be making things hard for himself, I understand what a guy likes about a column shift, I drive one every day. Side note: my truck is old and has 3.92 gears, it is slow and revvs relatively high for each given speed. and that sucks. |
#16 |
Senior Moment
![]() Join Date: Mar 2002
Quote Then again, I've read were they are used in some dirt track race cars, but I wonder if those even use first gear.
We ran a three speed in our B Mod Dirt car. 2019 Ca State Champion Used 2nd to get rolling then 3rd and to the floor. They don’t always last a season
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN 2013 GMC PU, Oldest Son 71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son 2019 GMC Diesil Dually. Youngest Son 2017 Toyota SUV Daughters car 2018 Traverse , Wife’s Ride Pittsburg Ca 94565 |
