06-25-2024, 08:12 AM | #1 |
4 speed to 205 questions
I’m changing my 68 Rockwell out to a 205. Do I just need the adapter for the 205 to the 4 speed? Will I need a different transfer case shifter itself? I have a couple laying around just not sure which one I would need to use.
06-26-2024, 11:39 AM | #2 |
Re: 4 speed to 205 questions
Does your 68 still have the SM420 transmission?
06-27-2024, 06:23 AM | #3 |
No it’s a sm465
06-27-2024, 07:24 AM | #4 |
A twin stick shifter makes things more Better.
Link: https://jb-custom-fabrication.myshop...-stick-shifter Link just for Ideas.
06-27-2024, 09:43 PM | #5 |
Born Psycho
if you need the adapter let me know , i've got a couple laying around i've kept as spares.
jerry moss 72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD 69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies. 73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog. 77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW BRENTWOOD,CALIFORNIA |
06-28-2024, 12:15 AM | #6 |
I'd guess the shifter would need to change and that much depends on what the 205 TC came out of. Not enough info to answer the questions.
07-03-2024, 01:10 AM | #7 |
To answer the question YES, you will need the 205 shifter, pivot bolt, link and connector plate that pins to the shift rails.
