Old 07-10-2024, 10:25 AM   #1
K10-Kansas
K10-Kansas's Avatar
PO welded brackets in front wheel wells. Why?
The previous owner welded a bracket, driver's and passenger side. Before I cut them off, am I right that they serve no purpose? It almost looks like they were intended to be a support for the inner wheel well. They are 1/4 inch from touching the wheel well. What could they have been for?
1971 C10 manual cab. 76 4x4 chassis. Cut short frame. Carbureted Blueprint 350, automatic 700r4. ~ James
K10-Kansas is offline   Reply With Quote
Old 07-10-2024, 10:53 AM   #2
1970cstblazer
1970cstblazer's Avatar
Lightbulb Re: PO welded brackets in front wheel wells. Why?
Never seen them before.
1970 K/5 Blazer CST 4WD, Bronze, 93k ACT. miles, 350, 4 speed, positraction, 16.5" x 8.25" wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration in progress...
1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor...
2017 Sierra 1500 SLT 4WD, Black, 41k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2...
2019 Canyon SLT 4WD, White, 60k miles, 3.6, 8L45, 3.23 LS, 18" wheels
Old 07-10-2024, 10:56 AM   #3
67C10Step
67C10Step's Avatar
These are the kinds of things I wish for a time machine. Go back and watch the thought process that lead to this. Some would be good to know, others probably very entertaining.
1967 C10
1980 Jeep CJ5
2020 Toyota 4Runner
2024 Toyota Tundra
67C10Step is offline   Reply With Quote
Old 07-10-2024, 11:50 AM   #4
truckster
truckster's Avatar
That would be a heavy-duty bracket if its only purpose was to support the inner fender.
I would say cut it off.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
truckster is offline   Reply With Quote
Old 07-10-2024, 11:57 AM   #5
HalfBrit
Looks like a home made upper mount for some extended travel shocks. "Not that there's anything wrong with that" LOL
HalfBrit is offline   Reply With Quote
Old 07-10-2024, 12:03 PM   #6
57taskforce
All about them K’s
57taskforce's Avatar
Exactly what my thoughts are. Extra shock mounts, after all… back in the 80’s it was cool to have at least 4 shocks on each corner
Tyler
'72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879
‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206
'98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's
‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue
‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0
Old 07-10-2024, 12:30 PM   #7
KQQL IT
At the body shop.
KQQL IT's Avatar
You think in 1970 something someone considered the truck living til 2024??
Old 07-10-2024, 12:37 PM   #8
kwmech
I'll go with the others on a home brewed upper shock mount
Old 07-10-2024, 01:15 PM   #9
K10-Kansas
K10-Kansas's Avatar
Oh, yeah, I bet that's what they are for. Thanks!
Old 07-10-2024, 01:23 PM   #10
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Hey! I remember the 80's! My K10 was double shocks all the way around....
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
Old 07-10-2024, 01:38 PM   #11
RichardJ
More than twice as thick as the frame and only attached at the bottom?
Can't see that as a shock mount.
'67 GMC 2500, 292, 4spd, AC
RichardJ is offline   Reply With Quote
Old 07-11-2024, 11:13 AM   #12
kwmech
Not every body does things right or in a fashion that makes sense
Old 07-11-2024, 11:16 AM   #13
57taskforce
All about them K’s
Exactly… clearly you’ve never met bubba or his welding machine!
Tyler
Old 07-11-2024, 11:18 AM   #14
57taskforce
All about them K’s
Yep them were the days. The blazer frame that my 57 sits on had dual front shocks from the factory.
Tyler
