Old 07-10-2024, 01:09 AM   #1
doowopper
wheel swap question
Kinda thinking out loud. I have a '69 C20 (8 hole wheels). If I were to put disc brakes on the front do you reckon that '74 wheels would fit properly?
Thanks in advance.
doowopper is offline   Reply With Quote
Old 07-10-2024, 01:14 AM   #2
67 twins
Location: Herculaneum MO (20 minutes south of St. Louis
Re: wheel swap question
Yes
67 C10 283 T5 swapped longbed fleetside = wife's daily driver
67 C20 292 (originally a 250)4speed longbed fleetside w/original wooden bed=my project truck
67 C10 283+.060 (so a 292 as well)T5 swapped longbed fleetside=my DD
72 C1500 Sierra Grande 350 TH350 longbed fleetside=wife's fair weather truck
Can you tell we are fans of longbed fleetsides & 67s
Chris
67 twins is offline   Reply With Quote
Old 07-10-2024, 11:17 AM   #3
1970cstblazer
1970cstblazer's Avatar
Lightbulb Re: wheel swap question
The 3/4-1 ton wheel pattern didn't change until 2011 for the GM trucks
1970 K/5 Blazer CST 4WD, Bronze, 93k ACT. miles, 350, 4 speed, positraction, 16.5" x 8.25" wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration in progress...
1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor...
2017 Sierra 1500 SLT 4WD, Black, 41k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2...
2019 Canyon SLT 4WD, White, 60k miles, 3.6, 8L45, 3.23 LS, 18" wheels
Old 07-10-2024, 01:59 PM   #4
chevmn
One option I took was to go with 16x7 ford accuride wheels. Opens up a much better selection of tires.
chevmn is offline   Reply With Quote
Old 07-10-2024, 04:27 PM   #5
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Yep -- same.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 07-10-2024, 04:53 PM   #6
doowopper
Thanks for the replies. I should have been a little clearer. I know the holes will line up. I'm concerned about any interference between the wheel and disc brakes. Again, thanks.
Old 07-10-2024, 05:26 PM   #7
Stocker
20' Daredevil (Ret)
Stocker's Avatar
I think any (most? all?) 16" or larger-diameter wheel will clear disc brake calipers without any interference.
You don't say what size the '74 wheels are, but they were designed to work with disc brakes. You'll be okay.
Side note: Many years ago I bought a set of 15x8 wheels for my '72 K20. Had to do just a very minor bit of grinding on the calipers for them to fit.
- Mike -
RIP El Jay
Old 07-10-2024, 09:05 PM   #8
chevmn
No issues with disc brakes on the Ford accuride wheels I run, and they originally came from an early 90s 3/4 4x4 with disks. I looked long and hard for an aftermarket wheel, and I could not find a newer 8 lug wheel that looked decent (to me). I do like some of the old slotted mag wheels, but very tough to find.
Old 07-10-2024, 10:03 PM   #9
mr48chev
mr48chev's Avatar
I have to go along with Chevmn in that you want 16 inch wheels rather than 16.5.
Decent 16.5 tires are getting hard to find and expensive when you find them.
My ongoing truck projects:
Old 07-11-2024, 02:22 AM   #10
doowopper
Yup, they're 16". The stock rims are 16.5 and I agree, tires are hard to find.
