Old 07-09-2024, 06:17 AM   #1
cag
62 rear shock mount and brake questions!
good morning, anyone have the stock upper rear shock mounts in their truck yet? if so can i get a dimension from the back of the frame to center of shock mounting, and from the top of the frame to the center of shock mounting?? some idiot, (me) cut them off, i am trying to make the tinworks rear mount work.
any one have a dana 60 in their truck with drum brakes? where is a good source for brakes, hardware and drums??
thank you!!
cag is offline   Reply With Quote
Old 07-09-2024, 11:01 PM   #2
62bagger
62bagger's Avatar
Re: 62 rear shock mount and brake questions!
I used these mounts on my 62 that I think came from porterbuilt. I had to trim the width of the mount to line up with the bottom mount. I can a picture of the finished shock set up later tonight. Hope this helps.
62bagger is offline   Reply With Quote
Old 07-10-2024, 07:28 AM   #3
cag
That is what i am looking for!! how did you determine the location? also anymore pics would be great, what shocks are those??
so the brackets are not porterbuilt, i emailed them.... any chance you have info on them? can you check the wayback machine?? lol
Thank you!
Old 07-10-2024, 12:05 PM   #4
SkinnyG
SkinnyG's Avatar
I altered the existing mounts. I determined their location buy taking the springs out and bottoming the suspension, then compressing the shock and see where the mount needed to go. Bumpstops keep the shocks from making contact.
These pictures are before being fully welded.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, boosted-LS
1977 Silverado: Shortboxed & dropped, potato-potato
V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag
Lotus Super 7 Replica: Scratch-built street-legal rollerskate
SkinnyG is offline   Reply With Quote
Old 07-11-2024, 01:05 AM   #5
62bagger
62bagger's Avatar
I will check tomorrow to see if I have a receipt and pics.
Old 07-11-2024, 08:02 PM   #6
62bagger
62bagger's Avatar
the upper shock mounts are from no limit engineering and the rear shocks are CCP 4052G for lowered trucks
Old 07-12-2024, 06:31 AM   #7
cag
Thank you!!!!
Skinny, thank you too, my upper mounts were wallowed out and junk...
Old 07-12-2024, 06:32 AM   #8
cag
How did you determine the location for the upper mount??
Old 07-13-2024, 02:05 PM   #9
62bagger
62bagger's Avatar
Here are some photos of my rear shock mounts. I didn't have a specific location for the mounts. I wanted the shocks to be further forward from the original location so that they were not at the angle when stock. In the photo of the inside of the frame (Last Photo) you can see where I used a step bit to open the holes large enough to get a deep socket in to tighten the nuts on the back side of the mount. I also made a gusset for that portion of the frame. I'm not sure it was needed but I wanted to be sure.
If you have any questions, you can send me a PM. Post a picture of your truck
Old 07-16-2024, 09:59 AM   #10
cag
Thanks!!!!
WILL POST TRUCK SOON, SOON AS I FIGURE OUT....
Old 07-16-2024, 03:10 PM   #11
cag
what drop do you have on the rear?
Old 07-16-2024, 03:38 PM   #12
62bagger
62bagger's Avatar
Rear drop is 6", front is 4"
