Old 07-08-2024, 11:40 AM   #151
Chaparralman1974
Chaparralman1974's Avatar
Re: "BUILD: 1970 C10 LWB--->SWB “Jumping Cholla”
It looks even better in the sun Scott!
Clay
Clayton Sikes
Peoria, Arizona
1967 Chevy K20
Build Thread: https://67-72chevytrucks.com/vboard/...d.php?t=841272
Chaparralman1974 is offline   Reply With Quote
Old 07-08-2024, 01:32 PM   #152
loudchevy
loudchevy's Avatar
Originally Posted by Getter-Done View Post
Very Nice
If you have any Gearhead neighbors?
I know they were Impressed.
Thanks, most of my neighbors keep to themselves, I always have people giving thumbs up as they walk past the driveway. A couple have stopped as they drive by to chat.
Originally Posted by Shifty One View Post
Dang, that's sharp!
Clay
Thanks guys!
Scott
1970 C10 LWB-->SWB Under Construction https://67-72chevytrucks.com/vboard/...d.php?t=847605
2014 2500HD DirtyMax|Daily Driver|Stock
2003 Tahoe Stock
1985 K5 5.3LS/4L60E|8Lug 4:56|3/4 Ton Front|14BFF Rear|Roll Cage|Dove-tailed & Bobbed
loudchevy is offline   Reply With Quote
Old 07-09-2024, 01:16 AM   #153
SRU1436
Looks awesome!
SRU1436 is offline   Reply With Quote
Old 07-09-2024, 12:39 PM   #154
rodstored-72
chevy truck fan
rodstored-72's Avatar
agree Scott. the truck is looking FANTASTIC!! nice color choice too
rodstored-72 is offline   Reply With Quote
Old 07-11-2024, 09:41 AM   #155
loudchevy
loudchevy's Avatar
Thanks!
Scott
2003 Tahoe Stock
Old 07-11-2024, 09:59 AM   #156
loudchevy
loudchevy's Avatar
Yesterday I cleaned up the cab floor and scuffed it up, and taped the crap out of the door jambs/dash to get it ready for a coat of Raptor liner. I will still probably put down a layer of insulation between the carpet/rubber mat but I wanted to get the epoxy sealed up. I'm happy to have this last part of the cab done. I have all the pieces for the exhaust and brake lines that I want to get installed before the cab makes it to it's final home sitting on frame rails.
Scott
2003 Tahoe Stock
Old 07-11-2024, 08:24 PM   #157
nicklear36
nicklear36's Avatar
That looks so awesome!! Did you raptorline the kick panel area?
nicklear36 is offline   Reply With Quote
Old 07-12-2024, 07:24 AM   #158
Chaparralman1974
I like the Raptor Liner in the cab Scott! I was going to do dynamat in mine, but I may do this instead.
Clay
Clayton Sikes
Peoria, Arizona
1967 Chevy K20
Old 07-12-2024, 09:27 AM   #159
loudchevy
loudchevy's Avatar
Thanks, yes I sprayed the kick panel area as well. I figured I'd save some filler/sanding time by just raptoring those areas that will get beat up by shoes anyways.
Clay
Thanks, I might still do some kind of stick-on insulation over the raptor but that will be farther down the road. Until I get to that crossroad, I can enjoy the clean look of this.
Scott
2003 Tahoe Stock
Old 07-14-2024, 10:59 AM   #160
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Turned out really good.
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 07-14-2024, 12:56 PM   #161
chewychevy67
That is a real nice color you chose.
chewychevy67 is online now   Reply With Quote
Old 07-14-2024, 03:28 PM   #162
loudchevy
loudchevy's Avatar
Small progress weekend. Friday evening the boy and I got the TC pushed in the 700R4 and then got the trans bolted and torqued down to the engine. Then we fit the 454/700 between the frame rails for I hope, the last time. I needed a new transmission xmember so the exhaust would clear and not hang down below the frame rails. Speedway Motors had a decent one with some adjustability so I went and picked it up last week. Bolted it in between the rails and set the 700 on it with a poly mount.
On Sat I got an early start and started work on the trailing arm xmember. I used AZ Pro Performance's Dead End Exhaust Cut Outs so I could continue the exhaust between the height of the frame rails. I could've made the (2) pieces but for 100 bucks, they were worth saving time and just buying them. In hindsight, I should've bought their Trailing Arm xmemeber when I first was cleaning the frame up months ago. It looks like a nice peice.
Once the Dead End brackets were installed, I started to visually layout the mufflers and 3" exhaust in the rear to fit around the shocks and 12b rear. I think I should be able to get the exhaust kit I bought to work. I was going to try and re-use an old Flowmaster 40 that I had on the blazer but the offset needs to be wider and I only had 1, so would've had to buy one anyways.
I need to get some new header gaskets this week anyways so I'll pick out some new mufflers along with a number of other little pieces to keep progress moving. The garage was pretty warm in Phx, Fri/Sat worm me out. I took off today (Sun) from the garage to stay cooler and hang with the fam. More work to be done in the evenings for the week.
Scott
2003 Tahoe Stock
Old 07-14-2024, 03:29 PM   #163
loudchevy
loudchevy's Avatar
Thanks!
Scott
2003 Tahoe Stock
Old 07-16-2024, 09:02 AM   #164
clay68c10
clay68c10's Avatar
That color really pops in the sun, I love it with the white. Very classic.
Speedway has really stepped into the truck world lately. That x-member looks like a solid piece.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 07-22-2024, 02:24 PM   #165
loudchevy
loudchevy's Avatar
Before I went and started on the exhaust, I wanted to confirm a radiator/fan setup would have enough room in front of the 454. I ordered a new aluminum from Champion and it showed up a few days later. I was going back and forth between a 2 & 3 row unit. I ended up buying the upgraded 2 row with 1" tubes to keep the depth of the radiator to a min. The 2 row should be more efficient than the 3 from what I have read and watched others speak about. Simple google calculator for pipe surface area to help confirm, 2 row with 1.0" tubes was around 178 inches squared as opposed to a 3 row with 0.63" that came to 168 inches squared. I also got the dual 14" electric fans, wiring, and relays, and 185 thermostat switch. 20 something bucks in stainless steel hardware, everything was bolted together and temporality set inside the core support.
There is a lot of play front to back with the mounts/bolts in the core holding it to the frame. I didn't mark where I bolted it down months ago when I had all the front pieces bolted to the cab on the frame, so I just verified that with the core/radiator/fan pushed as close to the front serpentine accessories on the BBC that everything cleared (overhead picture), it's tight but everything clears. Then for fun I pushed the core as far forward that I could just to see the max distance I might have (side picture). I was pretty relieved that everything cleared. I'm guessing the true location is somewhere in the middle of both tests spots.
Next up is exhaust. I have (2) Flowmaster 50 series mufflers, (2) MagnaFlow cats , and a pile of 3" builder exhaust pieces sitting in the garage ready for some progress to be made.
Scott
2003 Tahoe Stock
Old 07-22-2024, 02:26 PM   #166
loudchevy
loudchevy's Avatar
Thanks! Ya the Speedway x-member is pretty nice. It has a lot of adjustability built into it so the install was super easy.
Scott
2003 Tahoe Stock
Old 07-22-2024, 07:35 PM   #167
Chaparralman1974
Nice work Scott! Are we going to hear that motor rumble before Halloween? :-)
Clay
Clayton Sikes
Peoria, Arizona
1967 Chevy K20
Old 07-23-2024, 11:06 AM   #168
loudchevy
loudchevy's Avatar
Drivers side exhaust is mocked up. It took about 4 hours to get to this point yesterday afternoon.
I have a set of v-band clamps that I want to use between the cat and the exhaust cut outs in the x-member. They don't fit through the AZ performance dead-end cut outs, but I could unbolt the deadend's and the clamp will fit through the cut out section of x-member. These and the Flowmaster ball/socket flange at the header will make the exhaust totally removable from the truck, which is what I was shooting for.
Getting the header exit to line up with the deadend openings was a fun challenge going up and over in a short distance (the ball flange helped). The deadend to muffler was much easier since it was a straight shot with a little vertical rise. I think I will need to adjust where the bend is and move it closer to the muffler so the rear of the cab clears it. I wish I could've found some steel 3" pie cuts from a vendor to save some time, but I just cut my own with a porta band saw. All I was seeing online was stainless steel versions, which I didn't want to mix with the steel exhaust pipe I am using.
I think I have the rear layout figured out getting between the axle, shocks, trackbar, and rear mounted gas tank. I'm not sure where I want the exhaust to exit (either out the back or out the side) but it's going to have to wait until the bed gets cut down and set on the frame. I also have a O2 bung to throw in the line near the header. Might as well put them in now for future EFI projects
I hope to get to work on the passenger side mockup this afternoon.
Scott
2003 Tahoe Stock
Old 07-23-2024, 11:14 AM   #169
loudchevy
loudchevy's Avatar
Clay
Maybe by Labor day..... We'll see what happens. The motivation is there to work on the truck even with heat of the garage these days. I'm enjoying this part of the build as I really like to fabricate and problem solve. I've been looking forward to building this exhaust for a while now.
Scott
2003 Tahoe Stock
Old 07-23-2024, 04:37 PM   #170
rodstored-72
chevy truck fan
scott, progress is looking good!! I understand about the heat and being in the garage.... man!! I should have called you when I was needing help with my fabrication & problem solving!!
Old 07-24-2024, 10:05 AM   #171
loudchevy
loudchevy's Avatar
The passenger side is now mocked up. I moved the radius elbows feeding the mufflers back so they would clear the back panel of the cab. I still need to add my v-band clamps between the dead-ends and cats.
The Boyd Welding fuel cell is scheduled to be delivered on Friday afternoon so I should be able to get that installed this weekend. I'm probably going to exit the dual exhaust out the back. I can mockup that portion of the exhaust after the tank gets mounted. Still have brake and fuel lines to run before the cab gets set on the frame.
I had some emblems get delivered, I had to see how'd they look on the fenders
Scott
2003 Tahoe Stock
Old 07-24-2024, 10:06 AM   #172
loudchevy
loudchevy's Avatar
Thanks! The heat has been brutal especially with the mig torch in hand and welding mask over my face
Scott
2003 Tahoe Stock
Old 07-24-2024, 11:52 AM   #173
Chaparralman1974
Ok Scott.....the time has come to halt work on yours and come over here and help me for a bit....LOL!
I am in body work hell at the moment!!
Clay
Clayton Sikes
Peoria, Arizona
1967 Chevy K20
Old 07-25-2024, 04:18 PM   #174
loudchevy
loudchevy's Avatar
Clay
LOL. If you need help next week, I might have an afternoon available. My forearms and shoulders are cursing at me as I type this.
Scott
2003 Tahoe Stock
Old 07-26-2024, 10:37 AM   #175
KevinK7
KevinK7's Avatar
Just stumbled upon this build.
Amazing work!, ...and absolutely love the colors. Kudos on the great work, looking forward to following along
'68 C20 Utility 396 4sp (BuildThread: http://67-72chevytrucks.com/vboard/s...d.php?t=806904 )
'68 C10 50th
KevinK7 is offline   Reply With Quote
